Front shock/struts
+ Reply to Thread
Results 1 to 8 of 8
Thread: Front shock/struts
  1. #1
    Rookie jpmac is on a distinguished road.
    Join Date
    Jun 2009
    Location
    Summerville, SC
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Default Front shock/struts
    I just bought a 2001 tacoma per runner/trd. The shocks are shot and I am confused , are the front shocks or struts and if they are struts does the frontend need to be realined??
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer has earned a bachelors in rep power. Splicer's Avatar
    Join Date
    Mar 2006
    Location
    Jefferson State
    Age
    63
    Posts
    1,298
    Liked
    73 times
    Rep Power
    16859
    Default Re: Front shock/struts
    You posted in the Tacoma forum, which is for 2005+ Tacomas... your 2001 would be in the 1 Gen-Tacoma forum. But since you're here, and I believe the basic layout is the same, they are coilover shocks, not struts. You'll need a spring compressor to change the shocks, but as long as you don't get pre-loaded shocks to alter your ride height, you won't need an alignment.
    Here's a thread that should be helpfull. Shock replacement
    Edit: Where are my manners? Welcome to TS from N. Calif!
  4. #3
    SAS'ed #5 dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    34
    Posts
    6,232
    Liked
    156 times
    Images
    119
    Rep Power
    11613
    The front are struts and the rear are shocks.
    Struts bear the load of the vehicle and emcompass a shock with a coil spring around it. Shocks do not bear the load of the vehicle.
    BTW - I moved the thread to the 1 Gen Tacoma forum.
  5. #4
    Join Date
    Mar 2006
    Location
    Jefferson State
    Age
    63
    Posts
    1,298
    Liked
    73 times
    Rep Power
    16859
    Quote Originally Posted by dyogim View Post
    No, sorry, not correct at all. The thread I linked in my post above has a couple illustrations that should help clear up any misconception.
    This is correct, and the front shocks on the Tacoma do not bear the weight of the vehicle. Again, refer to the link I posted. Tacoma's front shocks are coilovers, but are clearly not struts. Tacomas have a double A-arm (or double wishbone, if you prefer) front suspension with coilover shocks.
  6. #5
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    34
    Posts
    6,232
    Liked
    156 times
    Images
    119
    Rep Power
    11613
    Coilover or strut is a short term for "coil spring over strut" or "coil-over-oil"
    Simply put a strut is just different version of a shock. So, yes the front end uses a shock but, in a different way.
    "Struts are simply shock absorbers used as major structural members. For struts, the shock absorber is placed inside the coil spring." - edmunds.com
    In order to not further debate (which is a good one that has been long discussed). I'll stop by saying we are both correct. Just using the terms differently.
    jpmac - to your alignment question. It's recommended to have it checked after you replace your shock/strut. Some places won't even charge you if the front end is still within spec.
  7. #6
    Join Date
    Mar 2006
    Location
    Jefferson State
    Age
    63
    Posts
    1,298
    Liked
    73 times
    Rep Power
    16859
    It's all good, agree to disagree as to terminology is fine with me. I realize that a lot of folks, including some in the business who should know better, commonly refer to any coilover shock as a strut, even though it bears no weight.
    Final illustration, if anyone missed it (or if anyone cares)
    Double A-Arms with coilover shock:
    Strut:
  8. #7
    Supporter lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford's Avatar
    Join Date
    Feb 2002
    Location
    Houston, Tx
    Posts
    1,733
    Liked
    0 times
    Rep Power
    15
    In simple term. With four wheels off the ground. If the strut is removed, the geometry of the suspension will be out of range (other than travel).
    2005 Tacoma AC 2WD 2.7L 5M
  9. #8
    TOYTEC LIFTS.COM
    Guest
    you should just lift your truck and make it easy...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
