Re: Compression???
Spec 'good' compression should be 178 psi or higher in all cylinders.
Spec 'minimum' compression should be around 127 psi in all cylinders.
The compression / pressure difference among all the cylinders should be no more than 14 psi.
Three of your four cylinders are below minimum spec, and the difference among cylinders is 'way out of spec.
To help determine what may be wrong, you can pour a small amount of engine oil into the spark plug holes of the 'low' cylinders and re-run the compression check. If adding the oil results in better compression on the 'low' cylinders, this would indicate the rings are shot. If adding the oil makes no difference, it would indicate the problem is elsewhere (probably the valves or head gasket).
