Need help, 98 tacoma popping noise while turning.
+ Reply to Thread
Results 1 to 4 of 4
Thread: Need help, 98 tacoma popping noise while turning.
  1. #1
    Join Date
    Jul 2006
    Location
    Chantilly
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Need help, 98 tacoma popping noise while turning.
    Hello, I have a 1998 Tacoma extended cab with the offroad package. Just recently I have noticed a popping sensation that seems to eminate from the left front tire. I can feel the popping up through the steering column. Also, when I go over a bump with that tire, there is an extra little rattle when the wheel reacts.
    I recently put the car in park while running, rolled down my window, got out of the car and crouched down near the front tire. I reached in through the window to turn the steering wheel, and I could feel the tire shudder with the popping sensation when I turned the wheel from left to right and back again.
    Obviously something is worn out. Is it the left front tie rod, steering linkage, or something else? it is getting progressively worse
    any help is appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jul 2006
    Location
    Chantilly
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Re: Need help, 98 tacoma popping noise while turning.
    I forgot to mention that can also feel a slight thunk/pop when I accelerate from a stop.
    Should I also be checking the rack/pinion as well as the CV axle?
  4. #3
    Supporter LGL002's Avatar
    Join Date
    Jan 2003
    Location
    West Fargo, ND
    Age
    74
    Posts
    2,236
    Liked
    15 times
    Images
    17
    Rep Power
    1319
    If your truck is a 4x4 it sounds like the constant velocity joint in one or both of your front half shafts has failed. So far my Tundra has been good but I had several Nissan Maxima's (front wheel drive) that sounded and felt like you described when a CV joint failed. If yours is two wheel drive I'd guess a wheel bearing failure or ball joint.
    Larry
    2003 Camry SE V6 Navigation, Sirius, Lunar Mist
    Optima 34R battery
    Turn signals are meant to indicate intent not result.
  5. #4
    Join Date
    Jul 2006
    Location
    Chantilly
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    It is a 4wd with manual locking hubs.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Brake noise. Help
    By strongarmtundra in forum 1Gen-Brakes
    Last Post: 07-24-2006, 05:14 AM
  2. Belt Noise
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 05-11-2006, 04:31 PM
  3. 02 Tacoma makes noise
    By kingchris626 in forum Tacoma
    Last Post: 04-29-2006, 10:32 AM
  4. Tacoma: 05 Tacoma Wiper Problems
    By NicksToy in forum Audio & Stereo
    Last Post: 05-17-2005, 02:11 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
