Transmission won't shift when cold..
+ Reply to Thread
Results 1 to 12 of 12
Thread: Transmission won't shift when cold..
  1. #1
    Junior Member PRTaco's Avatar
    Join Date
    Feb 2006
    Location
    TN
    Age
    37
    Posts
    50
    Liked
    0 times
    Rep Power
    10
    Default Transmission won't shift when cold..
    My '01 DC Tacoma with 3.4L autotrans will not shift into drive when cold. The shifter goes through reverse goes into Drive but the transmission does not engage drive. If I let off the brakes, the truck inches along, regardless of throttle input. No weird noises or odors. Transmission fluid is at good level.
    If I let the truck warm up, then it shifts normally. Once underway after initial crankup, no problems. It shifts fine while driving. The colder it gets here in TN, the more times it happens on initial start up in the mornings.
    Toyota shop gave me the usual 5 minute 'we can't mimic it and the fluids are fine'. The truck has 98K miles on it.
    Any takers?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    "Rosco" Thread Derailer Flashgordon's Avatar
    Join Date
    Apr 2006
    Location
    Da Yooper Eh?
    Age
    54
    Posts
    5,778
    Liked
    92 times
    Rep Power
    220718
    Default Re: Transmission won't shift when cold..
    I'd first start off with a fluid change. With 98k miles and if it's never been done, thats the easiest thing to try.
    Good luck!
    Drink more. It probably won't help you understand better, but it just might, and that's a chance worth taking....
    Author;
    Dr. Bundy-AKA-"The Good Doctor"
    "you can take the man out of the ho, you can not take the ho out of the man..."
    Author;
    Our Cigar Smoking Scotch Drinking Lesbian Friend-"Dikkie"
  4. #3
    Veteran Member ICON's Avatar
    Join Date
    Nov 2005
    Location
    Monson,ma
    Posts
    564
    Liked
    3 times
    Images
    8
    Rep Power
    266
    I highly doubt a fluid change will help any, chances are the pump might be bad or something in the valve body isn't happy. You need to have someone w/a scanner and the knowledge of how to read and interpret info from the scanner plus how to demand certain things from the vehicle to pin point the problem. I'd first make sure the fluid level is ok but i think that's all you'll be able to do yourself. W/a scanner you can see what's being commanded by the ECM and what's not happening with the tranny. Good luck.
    '06 AC SR5 4x4
    '05 Honda Foreman 500S 4x4
    '04 Honda Shadow Sabre 1100
  5. #4
    Supporter sequoiasoon's Avatar
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    45
    Posts
    1,232
    Liked
    3 times
    Images
    8
    Rep Power
    13
    I had a Ford Exploder that I had the tranny rebuilt on. There was a piece of dirt/varnish that was stuck in the valve body. When cold it would not downshift to first gear. Started and moved fine but stop signs/traffic lights within the first 5 minutes would result in a second gear start. Once warm the metals would expand enough to clear around the block.
  6. #5
    Join Date
    Feb 2006
    Location
    TN
    Age
    37
    Posts
    50
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Quote Originally Posted by ICON View Post
    I just returned from the Toyota shop here. The transmission was due for a 30K flush. The fluid looked normal, nothing out of the way. Tech said he ran a scanner and nothing showed abnormal.
    I guess I get to rent a car one night and let them have it overnight so it can get cold and let them figure it out. Thanks for your replies. Not exactly holding my breath for any change in the transmission after the flush change. We'll see.
    Thanks for all your guy's help.
  7. #6
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    45
    Posts
    1,232
    Liked
    3 times
    Images
    8
    Rep Power
    13
    Quote Originally Posted by PRTaco View Post
    Big hint!!! Make sure you drop it off the night before and that they leave it OUTSIDE. When I had the problem they could never find it. They had the car for at least a week and it "never" did it. Owner even took it home 2 nights, "never" did it. They were right! The problem was they always kept the cars inside the shop at night and the owner kept in his garage. Both were heated and at 50+ degrees it was fine. I parked in front of their garage door and met them in the AM. Let them drive it COLD and TA DA! No first gear.
  8. #7
    Join Date
    Feb 2002
    Location
    Newport News, VA
    Age
    31
    Posts
    86
    Liked
    0 times
    Rep Power
    14
    Quote Originally Posted by sequoiasoon View Post
    Do you remember what the diagnosis was for your vehicle?
  9. #8
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    45
    Posts
    1,232
    Liked
    3 times
    Images
    8
    Rep Power
    13
    They said there was a piece of dirt stuck in some part of the valve body keeping one of the solenoids from closing.
  10. #9
    Join Date
    Feb 2002
    Location
    Newport News, VA
    Age
    31
    Posts
    86
    Liked
    0 times
    Rep Power
    14
    Heh..re-read one of your previous posts. Sorry for making you repeat.
  11. #10
    Join Date
    Feb 2006
    Location
    TN
    Age
    37
    Posts
    50
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Update on initial post:
    Transmission fluid was normal color and level. It was due for a change anyways, so I went with transmission fluid change / flush.
    Problem solved and its been much colder since the problem came up in the first place.
    Hope this helps someone else out there.
  12. #11
    Join Date
    Dec 2008
    Location
    Broomfield, CO
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I'm having this exact same problem with my 01 Tacoma v6. When its cold out (<20 f) the vehicle will go into reverse and back out of the garage just fine. When I try to shift into drive, nothing happens. No click, no surge, nothing. Pressing the accelerator causes it to crawl along, but the transmissions isn't really grabbing. The temporary fix has been to shift down to 1st and back into drive serveral times. Eventually it always engages.
    Approximately 7500 miles back I did a flush with Amsoil ATF. I checked the fluid the first time this problem happened around a week ago and it was a quart low. I topped it off but the problem continues. Has anobody every heard of the amsoil not performing well in extrmely cold temps?
    Did you ever resolve this issue? My (pregnant) wife drives this vehicle and I need it to be reliable.
  13. #12
    Join Date
    Oct 2006
    Location
    Austin, TX
    Age
    41
    Posts
    481
    Liked
    4 times
    Rep Power
    9
    Flushing trannies every 30K miles or drain/fill pan every 15K miles is the best insurance for long lasting tranny. Don't even look at the fluid color,shape,form -- just follow the above schedule and it will last a lifetime (provided one does not abuse it). Its like an oil change, do you skip on it, so is the tranny, cannot skip any lubricating part in the vehicle.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Extending Automatic Transmission Life
    By Transdude in forum Transmission
    Last Post: 03-28-2014, 01:39 AM
  2. Shift pattern
    By nhparrot in forum Transmission
    Last Post: 03-07-2007, 08:55 AM
  3. Override Transmission won't shift when cold
    By vannle in forum 4Runner
    Last Post: 08-02-2005, 12:57 PM
  4. Transmission quick to shift gears when cold?
    By unixadm in forum Transmission
    Last Post: 05-31-2002, 01:08 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
