Originally Posted by buck351
I'm going to replace the rotors, pads and maybe the calipers on my 2002 Tacoma S-Runner (4x2). Since I don't have a manual I need to know what the torques specs are for the bolts that hold the rotor and caliper. Any help will be appreciated.
In the Haynes Repair Manual says:
Caliper pins/bolts Tacoma 2WD 65 Ft-lbs
Caliper Torque plate bolts (2WD) 80 Ft-lbs
wheel cylinder mounting bolts
84 in-lbs (note this is inches - pounds)
Wheel lug nuts 83 Ft-lbs
I hope this helps....
