Old 06-10-2007, 04:16 PM
Dealer : Berglund Oak Ridge Toyota
Last Online: 01-02-2008 08:45 PM
eclipsepb25 may have some regrets.
eclipsepb25's Photo Albums
Default cold air intake problems/resetting the ECU, please help!!!
so earlier today i decided to put on my cold air intake system on my 2000 tundra 4.7 V8. everything looked fine, all the hoses were connected along with the mass airflow sensor.i left the battery disconnected for about 45 - 60 minutes figuring it would be enough to reset the ECU. well i started her up and it sounded normal and when i let the key back to idle it just shut off. i did it again and same thing. next time while i was starting it i gave it a slight bit of gas and it started up like normal and was idling fine. the only problem now is that the check engine light was on. i checked all the hoses and clamps and there seem to be no vacuum leaks and everything was snug and tight. after all of this i just put back the stock intake and filter back on just like it was before AND THE SAME PROBLEM!!!! so i just went ahead and put back on the cold air intake again and left the battery undone for about 45 - 60 minutes and checked everything and it was doing same thing where it would only start up when i gave it a little gas. does anyone have any tips, helpful information, or no exactly how long i should wait for the ECU to reset its self. also, is there a manual way to reset the ECU? please, please, please help me out! thanks
Old 06-10-2007, 07:20 PM
Salty_Dog's Avatar
Assistant Administrator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 06:33 PM
Images: 587
Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future. Salty_Dog has a brilliant future.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
Default Re: cold air intake problems/resetting the ECU, please help!!!
Put the stock intake back on. Run it for a few days and the Check Engine light should go out. The ECU will "learn" what it is supposed to do from the MAS.
Then, take the aftermarket intake to the nearest river, and throw it away. If you do a little research here on TundraSolutions, you'll see that most people have not had a lot of success with intakes. Toyota engines are so well tuned from the factory, that it is hard to get much more out of them with low cost bolt-on options.
Save your money for a good set of headers and exhaust.
Salty Dog
It's all a bunch of tree-hugging hippie crap.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Kenwood KCA-BT200 Bluetooth Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog and a New Puppy Who is not much of a Deterrent
Old 06-10-2007, 07:49 PM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: Today 06:11 PM
Images: 16
Big_Al1 is on a distinguished road.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
What kind of CAI is it I just disconnected battery while installing my trueflow like the directions stated and all was good.
Old 06-10-2007, 08:16 PM
Tundra90731's Avatar
Dealer : Longo Toyota
2003 Toyota Tundra
Last Online: 09-19-2009 11:27 PM
Tundra90731 may have some regrets.
Send a message via Yahoo to Tundra90731 Tundra90731's Photo Albums
I have a 63 Series K&N CAI on my 2003 Tundra Access Cab.....Have had no lights come on...Or any other issues....Also installed a 24" Magnaflow muffler...EXCELLENT PERFORMANCE!!!!
2003 Toyota Tundra, Stratosphere Mica, K&N 63 Series Cold Air Intake, Line-X Liner, Tinted Windows...Spin Tech 3333XL Muffler!!!
Old 06-10-2007, 08:20 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie is on a distinguished road. Eddie is on a distinguished road. Eddie is on a distinguished road.
Eddie's Photo Albums
The check engine light may be on for another reason,may just be coincidence you installed an intake. Are you sure everything is plugged in properly? What kind of intake? You may have fouled the MAF if the filter element is too oily.
Old 06-11-2007, 07:09 AM
Salty_Dog's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Images: 587
Don't forget the infamous O2 sensors, either.
Salty Dog
Old 06-11-2007, 09:32 AM
the filter is not too oily and i cleaned and made sure the MAF was all good, and i also cleaned the throttle body
Old 06-11-2007, 10:00 AM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
Last Online: 02-18-2010 11:50 PM
Images: 6
UnSub is on a distinguished road. UnSub is on a distinguished road. UnSub is on a distinguished road.
UnSub's Photo Albums
You might want to invest in a code reader. They are fairly cheap, will tell you the code and will reset the code.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery
5.7 Killer
Is the cold air intake worth the money? brad hartwell Engine & Drivetrain 16 10-08-2009 08:33 PM
Cold air intake midnight_pass Forced Induction Systems 22 03-31-2008 04:24 PM
Finally a cold air intake for 07 2.4s drtruff19 Camry 0 06-05-2007 10:38 PM
Cold air Intake Team Yexas Engine & Drivetrain 7 10-12-2006 12:58 AM
Ram air intake??? silverTRD Engine & Drivetrain 3 01-21-2004 08:26 PM
