IAT sensor wire colors and location?
+ Reply to Thread
Results 1 to 8 of 8
Thread: IAT sensor wire colors and location?
  1. #1
    Junior Member rad21 is on a distinguished road.
    Join Date
    Jan 2007
    Location
    clearfield, ut
    Posts
    58
    Liked
    0 times
    Rep Power
    7
    Default IAT sensor wire colors and location?
    Does anyone know, on the V8, is the IAT sensor built into that sensor on top of the air filter box that has 5 wires into it, or possibly that sensor on the side of the air throttle body on the engine that has 6 wires into it? And if so can anyone tell me which color wires feed the IAT sensor? This is for a 2004 v8, I assume it is the same for all V8s around that year. Any help is apreciated!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub has blessed us with their presence. UnSub's Avatar
    Join Date
    Mar 2007
    Location
    Mesquite, TX
    Age
    61
    Posts
    986
    Liked
    0 times
    Images
    6
    Rep Power
    36
    Default Re: IAT sensor wire colors and location?
    The IAT sensor is an integral part of the Mass Airflow Sensor, located on the air filter box. The MAF sensor has 5 wires. The yellow wire with the green stripe is the output from the IAT and feeds terminal THA on the ECU. What are you doing?
    03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
    Scion Head Unit 08600-21802,
    Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
    Rhino Liner, Die Hard Platinum P5 battery
    5.7 Killer
  4. #3
    Join Date
    Jan 2007
    Location
    clearfield, ut
    Posts
    58
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    Thanx for the info. Is one of the other wires a common ground for the IAT sensor? After having read many threads and much discussion about using resistors to alter the input to the ECU from the IAT sensor, I wanted to experiment with bypassing the IAT with various resistor values or a variable resistor, for the effect of making the mix slightly leaner. I have more than enough power for commuting, and when not towing I wanted to experiment with possibly increasing MPG, even if power is somewhat affected. As a long time tinkerer, I guess that's my nature. Also being in a higher mountain state, I wondered if my mixture is richer than when at a lower elevation so perhaps those of us in thinner air might benefit. If you have any experience or answers to those questions, your input is much appreciated!
  5. #4
    Join Date
    Mar 2007
    Location
    Mesquite, TX
    Age
    61
    Posts
    986
    Liked
    0 times
    Images
    6
    Rep Power
    36
    I have edited my previous post to correct an error. This post contains info in that post plus additional info.
    Red is 12 volts from 10 amp EFI fuse. It carries power to all oxygen sensors also.
    BLK with white stripe is ground to MAF sensor.
    Yel with green stripe is MAF sensor output to THA input of Engine Control Module.(intake air temp circuit)
    Black with yellow stripe is MAF sensor output to E2G input of ECM. I do not know what this wire does or if it could be a ground. It does not come from ground but rather from the MAF sensor. I cannot find a description of it's purpose.
    Red with white stripe is MAF sensor output to input VG of ECM (intake air volume circuit)
    Let us know how your project works out. Good luck.
    5.7 Killer
  6. #5
    Rookie cory04tundra is on a distinguished road.
    Join Date
    Aug 2008
    Location
    magnolia, tx
    Posts
    3
    Liked
    0 times
    Blog Entries
    1
    Rep Power
    0
    I dont want to sound stupid but i dont understand your post. i hooked mine up to the yellow and green wire and the red and white wire and from what i gathered i thought was the right thing to do was i wrong? any help would be appreciated.
  7. #6
    Veteran Member Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606 has done just about everything...and then some. Boosted27606's Avatar
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    1,070
    Liked
    4 times
    Images
    12
    Rep Power
    1043
    Quote Originally Posted by cory04tundra View Post
    I don't understand your post either .............. but I do understand the previous post.
    When you say: I HOOKED MINE UP TO THE YELLOW.......
    what are you talking about ??
    and what are you trying to accomplish ?
    Enjoying the awesome 5.7 L engine
    TRD rear Sway Bar, Billet Grille, Heated Seats, Westin Bull Bar and Skid Plate, HELLA driving Lights, Chrome handles and mirrors,
  8. #7
    Rookie danlute is on a distinguished road.
    Join Date
    Nov 2008
    Location
    iowa
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    It appears he is trying to install a performance "chip" they connect to the IAT sensor....curious to see if it does increase mileage......
  9. #8
    Rookie debrown53 is on a distinguished road.
    Join Date
    Mar 2011
    Location
    Spokane
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Hi all, I have the 4.7 and looking to do the same thing, install a chip on the IAT and am trying to determine which wires to attach to. Attempted using the ohm meter but the configuration of the plug and wiring to the connector make it very difficult (impossible) to make a positive connection to follow the directions. What I am looking for are the wires to transfer the sensor data to the ECU.
    Thanks for any help.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
