Transmission fluid change
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: Transmission fluid change
  1. #1
    Rookie jason2413 is on a distinguished road.
    Join Date
    Oct 2006
    Location
    San Jose, CA
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default Transmission fluid change
    I have an 06 AC and I know that I don't have to change it but if I hypothetically drained the transmission fluid, how would I go about refiling it? I looked at some directions Found on the forum with some bolt on the side but I didn't see it when I got under my truck. Anyone know anything about this?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Rotts is on a distinguished road. Rotts's Avatar
    Join Date
    Jan 2007
    Location
    Monroe
    Age
    40
    Posts
    54
    Liked
    0 times
    Images
    6
    Rep Power
    7
    Default Re: Transmission fluid change
    Yes it's on the right side approx. 24mm. I did mine about a month ago. You also have to take out the overflow plug which is a 5mm hex bolt on the bottom of the pan. It has a stand pipe so when the correct level is reached it flows from the stand pipe.
    I used a small siphon hand pump to do mine. Kind of a pain, so I will try to get a different pump next time.
    2005 Tundra DC TRD 4WD "Silver Sky"
    Fabtech Dirt Logic 2.5 with 2" aal in the rear
    American Racing 16x9's with 285/75/16
    Firestone Destination M/T, LSD, TRD Dual Exhaust, Westin nerf bars, Linex, Toyota bug guard, Husky floor mats, Prodigy brake controller,
    window tint, debadged
    2000 4-Runner SR5 4WD "Jade"
    31x10.50 Bridgestone Dueler A/T Revo's
    Stampede bug guard, Husky floor mats, brake controller, window tint
  4. #3
    Veteran Member stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx is a splendid one to behold. stevekx's Avatar
    Join Date
    Apr 2007
    Location
    home
    Posts
    618
    Liked
    0 times
    Rep Power
    12
    Filled mine thru the dipstick tube, a bit slow but did not have to be under the truck.
  5. #4
    Junior Member lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold. lalojamesliz is a splendid one to behold.
    Join Date
    Oct 2006
    Location
    bakersfield
    Posts
    279
    Liked
    1 times
    Rep Power
    16
    dipstick tube ?? well i read on pdf download from a web site i dont remember about this that the transmission fluid has to be a certain temperature when you fill it? and to know that.... well its a special toll from toyota.thats why i havent done this to my truck. anyone know if this is important? i also remember a transmission has to be a normal temperature when you check the fluid along with the car on.
  6. #5
    Veteran Member shall36 is on the right track. shall36 is on the right track. shall36's Avatar
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    40
    Posts
    910
    Liked
    3 times
    Rep Power
    10
    2000 to 2004 models (4-speed auto) have a dipstick tube (which is how you "normally" fill a transmission).
    2005 to 2006 models (5-speed auto) has NO dipstick tube (which is a new trend in trans units). Fill is done via a fill plug on the side of the unit. A hand held pump can be bought at Advanced Auto or Autozone to pump in the fluid. The pump screws onto the fluid bottle and you pump away. A marine lower unit gear oil pump also works nicely. You fill the unit 'till fluid dribbles out. Start the unit and fill to fluid dribbles out. I don't have the specs for this unit, but the "official" instructions probably specify that the fluid level be checked when the fluid is at a certain temperature.
    Stock fluid is Toyota Type T-IV. Amsoil Universal has worked fine for many of us. T-IV can be had for about $5/qt. Amsoil is about $10/qt (it's a full synthetic; T-IV is not). T-IV is Mobil JWS 3309.
  7. #6
    Junior Member c5engineer is on a distinguished road. c5engineer's Avatar
    Join Date
    Jul 2006
    Location
    Youngstown, OH
    Posts
    190
    Liked
    0 times
    Rep Power
    7
    This has been discussed before on the forum. It isn't as simple as fill till it comes out the hole. Someone had posted the pdf on the how to and it's very doable, but not 1,2,3. Search and ye shall find.
    2006 Tundra Double Cab 4X4
    Spectra Blue Mica
  8. #7
    Supercharged Member HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,522
    Liked
    5 times
    Images
    12
    Rep Power
    150
    Quote Originally Posted by jason2413 View Post
    If ya can't DIY just take it and haveit done but be cautious who does this because it can be messed up easilly! Very simple procedure if ya have tools and lift would be nice! PS 06 comes with WS ATF which is a Synthetic fluid and i will not touch mine till 50 or 60 K miles! This procedure can be done by Toyota with an evac machine and new WS ATF at most dealerships they just need 14 or so Qts and the machine!
  9. #8
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    40
    Posts
    910
    Liked
    3 times
    Rep Power
    10
    OK...see this link:
    This unit is a bit different from other makes (e.g. ZF) without a dipstick tube. There is an overfill plug in the bottom of the pan which is connected to a stand tube. This tube will drain fluid to the correct level. The key here is getting the fluid temperature in the proper range, which is why the linked instructions talk about drain-off, refill, drain-off.
    Not rocket science, but not as easy as the dipstick.
  10. #9
    Lurking Member nvrpc is on a distinguished road. nvrpc's Avatar
    Join Date
    Mar 2007
    Location
    Ripon
    Posts
    27
    Liked
    0 times
    Rep Power
    7
    Quote Originally Posted by shall36 View Post
    Well I have been under this truck three times today in daylight and there is no fill plug on either side of this transmission where the manual says it is but there is a very big hex head in the tail shaft section of this transmission. Could this be the fill plug. I have a 2006 Tundra SR5 2WD 6 cylinder 5 speed automatic. Can any please tell me where this fill plug is and I DO NOT have a dip stick. Thanks
  11. #10
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    Quote Originally Posted by nvrpc View Post
    Hope this helps you:
    http://www.ncttora.com/fsm/04-06-Tun...a/atf/adju.pdf
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  12. #11
    Join Date
    Mar 2007
    Location
    Ripon
    Posts
    27
    Liked
    0 times
    Rep Power
    7
    Quote Originally Posted by Highwaylizard View Post
    I thank you however there is no such fill plug in this location on my transmission on either side. The only plug I can find that ever close to this is located on the tailstock where the drive shaft plug into the transmission on the right hand passenger side. See pitures. Is this big plug on the tailstick MY fill plug
    Attached Thumbnails Attached Thumbnails Transmission fluid change-img_1929.jpg   Transmission fluid change-img_1930.jpg
  13. #12
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    What year truck and what engine please?
  14. #13
    Join Date
    Mar 2007
    Location
    Ripon
    Posts
    27
    Liked
    0 times
    Rep Power
    7
    It is a 2006 Tundra extended cab 2WD 6 cylinder VVT I can give you the VIN# if that will do any good. 5TBRU34186S484305 Maybe I have some freak of nature truck that Toyota made out of parts from 2WD and 4WD parts at the years ends. Please let me know. I forgot to mention I have more information here http://lexington.craigslist.org/cto/2393520028.html
  15. #14
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    It is a 2006 Tundra extended cab 2WD 6 cylinder VVT I can give you the VIN# if that will do any good. 5TBRU34186S484305 Maybe I have some freak of nature truck that Toyota made out of parts from 2WD and 4WD parts at the years ends. Please let me know. I forgot to mention I have more information here Tundra 2006 SR5 Extended Cab
    That explains it.
    Here:
    2004 to 2006 Toyota OEM Repair Manuals
    Save the file to your computer - that way if for some reason this gets taken off the net you will have it.
    and for the V6:
    http://www.ncttora.com/fsm/04-06-Tun...1grfe/comp.pdf
    Still trying to track down a diagram which shows the filler bolt
  16. #15
    Join Date
    Mar 2007
    Location
    Ripon
    Posts
    27
    Liked
    0 times
    Rep Power
    7
    That explains it.
    Here:
    and for the V6:
    It still does not show the fill plug anywhere in the graphics. Thanks. I'll keep looking around for more information on the 1GR-FE transmission
  1. Extending Automatic Transmission Life
    By Transdude in forum Engine & Drivetrain
    Last Post: 12-13-2009, 07:34 PM
  2. 2006 Avalon Automatic Transmission Fluid Change
    By Mike Murrell in forum Avalon
    Last Post: 09-29-2007, 08:01 AM
  3. Transmission Fluid Change
    By RCraig in forum Engine & Drivetrain
    Last Post: 06-30-2006, 07:01 PM
  4. HELP?!?! first fluid change
    By markobeans in forum Engine & Drivetrain
    Last Post: 05-15-2006, 11:05 AM
  5. 2002 transmission fluid loss
    By ddctundra in forum Engine & Drivetrain
    Last Post: 02-11-2006, 12:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
