Re: replacing power window switch
Try pulling up on the switch with your hand first, and then use something
to pry it out with, you shouldnt have to remove the door trim panel, if you
just pull up on the switch assy, it should pull out and then just plug your
new one in. I work in a bodyshop and I know this is how you do it, let
me know how it works out..
