P0770- Shift Solenoid
+ Reply to Thread
Results 1 to 13 of 13
Thread: P0770- Shift Solenoid
  1. #1
    Join Date
    Jul 2007
    Location
    San Diego, Ca
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Question P0770- Shift Solenoid
    I just got a check engine light coded P0770. I've done some research and apprently there are three 3 solenoids that may be triggering the check engine light. It's worth mentioning that when I come to stop and the transmission lever (Automatic) is in "D"rive or "R"everse the truck immediately stalls out. However when the truck is in park and neutral the truck idles fine and does not turn off, but just a soon as any moving gear is engaged the truck immediately turns off. I never had any transmission problems before and there's no hard shifts.
    Any ideas as to which solenoid needs replacing?
    Has anyone changed these solenoids on their own? Suggestions?
    Is it bad, other than a bit dangerous, to drive my car home (I'm 450 miles away)? Will more damage be done to the transmission? The local dealership told me the transmission would blow up.
    I also have a P0135 code (Bank 1 sensor 1 and O2 sensor heater circuit malfunction) showing up but these are the O2 sensors and, well, I'm pretty sure it's unrelated to my transmission issue. Right?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter The Phoenix's Avatar
    Join Date
    Oct 2006
    Location
    TundraSolutions.com
    Posts
    2,495
    Liked
    4 times
    Images
    2
    Rep Power
    142
    Default Re: P0770- Shift Solenoid
    Interesting to see the dealership isn't afraid to be blunt with you. Do I think your transmission will blow up if you drive it? No. Is it a possibility? Of course.
    Personally, I'd rather have it checked out just to see what is really wrong with it. Unfortunately it will be rather costly to have any shop drop the transmission and replace the solenoid. Your dead o2 sensors aren't really related to the tranny issue either, and those too are costly. Today isn't your lucky day
  4. #3
    Join Date
    Jul 2007
    Location
    San Diego, Ca
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    I am more than willing, interested and capable of getting into the trans pan myself. I think one of the three is located in the trans pan and the other two are located on the side of the housing, but not sure how to correctly diagnose which of the three is faulty.
    Any ideas of why the truck turns off when a gear is engaged? is it a fail-safe of sorts?
    yeah, the O2 sensors seem to be problematic on tundras. I've already replaced one O2 sensor and the ex manifold (b/c it was frozen on). I expect I'll have to change all of em in the next few thousand miles.
  5. #4
    Join Date
    Oct 2006
    Location
    TundraSolutions.com
    Posts
    2,495
    Liked
    4 times
    Images
    2
    Rep Power
    142
    I admire you for your courage on tackling this project yourself, that is if you don't mind the huge mess of trans fluid that you will have to dispose of. But other than that, doing work on the trans won't be that bad. I'm not sure of exactly which solenoid has taken a plunge either.
    The only "fail safe" I can think of is something related to the parking pawl ( Parking pawl - Wikipedia, the free encyclopedia ) that might be causing the truck to stall. If your vehicle is moving at xx MPH and the transmission lever is slammed into park, I believe the parking pawl will not engage and the vehicle shuts off. I can only recall this happening to me one time in my 94 chevy beretta (which killed two transmissions within 6 months btw) but I'm not positive it happens on the Tundra as well. Best bet is to call a transmission specialist in your area. They are specialists for a reason.
  6. #5
    Join Date
    Jul 2007
    Location
    San Diego, Ca
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Yeah I might have to take it to a professional but I really enjoy working on my own truck.
    Does anyone know how to correctly diagnose which of the three solenoids is faulty?
  7. #6
    DH
    DH is offline
    Supporter DH's Avatar
    Join Date
    Mar 2007
    Location
    Bel Air
    Posts
    408
    Liked
    7 times
    Rep Power
    717
    If it were mine, I would start with the easiest and cheapest first.
  8. #7
    Junior Member kwhite1124's Avatar
    Join Date
    Feb 2006
    Location
    Byron
    Posts
    105
    Liked
    0 times
    Rep Power
    10
    I am a professional. 20 + years in the trans game. The only solenoid that will stall the enginge is the TCC solenoid. It has the convertor clutch applied at all times. Replace the solenoid and you should be golden!!
    Good luck!!
  9. #8
    Veteran Member shall36's Avatar
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    42
    Posts
    910
    Liked
    5 times
    Rep Power
    12
    A couple of thoughts for you.
    Professional manuals for your trans might be found here:
    ATSG Transmission Repair Manuals .
    I looked at the '03 FSM and the code P0770 doesn't show up. It does have a diagnostic flow chart for various transmission codes, but P0770 isn't in there. Could be that things were changed from '00 to '03.
    Now, check this out...I did find a post on a Toyota Camry about code P0770, which indicates torque converter lockup solenoid failure. This absolutely jives with the previous post about a locked-up converter stalling the engine. BTW, the lockup converter basically eliminates the slip associated with auto transmissions, improving fuel economy. In any event, read this post and see what you think:
    Toyota Repair: 1995 Avalon P0770
    Also, check out this TSB:
    # TSB #02402 -- MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0770 STORED. *TT (NHTSA ID #10000657, DECEMBER 23 2002)
    Also, check out this thread on TS:
    http://www.tundrasolutions.com/forum...-engine-light/
    I've also attached the FSM excerpt for the valve body. Sounds like you need to remove and clean solenoid SL. BUT, this will not necessarily cure the problem. As for functionally testing the solenoid, you could ohm it out...the wiring diagram shows it as a coil with power coming from the ECM and the other lead going to ground. I assume it's a 12V solenoid, but I don't know that I would apply 12V to check operation without knowing that for sure. There are hydraulic line pressure tests that can be done to verify proper operation.
    I've attached two excerpts from the '03 FSM. The first shows how to remove the valve body to get to the solenoids. The second shows how to troubleshoot the solenoids. My guess is that code P0770 has been replaced by codes P0741 and P0743, both of which cover the lockup system.
    This is definitely doable by someone with good skills and some decent tools. As for the mess, I drain the pan using the plug, drop the pan, drop the screen, put the pan back up and wait an hour. That gives the fluid plenty of time to drain and drip from the valve body. Not a big mess if you do it right.
    Attached Files Attached Files
  10. #9
    Join Date
    Jul 2007
    Location
    San Diego, Ca
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks K and Shall. I appreciate you sharing the knowledge. I've located a replacement TCC solenoid dropped the pan and the valve body, and doing the work now. I'll let you know how it goes. Hopefully once I've cleaned the valve body, fluid, solenoids of any metal the problem will be resolved. Of course just as that '95 Toyota Avalon posting mentioned I'm at risk of having the transmission fail entirely as indicate by the very small amount of metal stuck to the pan.
  11. #10
    Join Date
    Sep 2002
    Location
    Hudson, NH
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Shall36 - thanks for the documents that you attached !!
    Can you help with a little follow-up ?
    1) Is it just the solenoid labeled "SL" that deals with the torque convertor lock-up ? I can't find a Toyota document that details the definition of S1, S2, SL, and SLT. Called the dealer to get new solenoid for TCC operation - they just FAXed over the same diagram and said "Let us know which one it is" .....
    2) Toyota p/n and approx price for the TCC Solenoid ? I saw somebody (ChileVerde ?) post that they had the part in hand perhaps you can help out.
    I don't have a Trouble Code indicating, but have the symptom of stalling out because convertor always engaged.
    Thanks !!
    Paul
  12. #11
    Join Date
    Mar 2008
    Location
    LAs Vegas, still
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Hey guys,
    About code P0770.
    This is not a malfunctioning solenoid. FYI solenoid "E" is solenoid "SL". But this is not the problem. The problem is that Toyota uses metal valves in their aluminum valve body and the valves wear out the bores in the valve body. Toyota sells two sleeves. One for the Lock-up valve and one for the pressure control solenoid valve. Part numbers are 35215-30020 and 35417-35010. They are about $55 for the pair. To repair the valve body you will need to remove it from the vehicle and remove the sleeves that are already in there. Replace them with these new, updated ones and that will do the trick. They also offer a new valve body for about $850. Ok, so then they also say that you will need to replace the computer after this upgrade, but I haven't seen it necessary in any of our repairs.
    Dinger
    Aamco Transmissions
    N. Las Vegas.
  13. #12
    Rookie reb101's Avatar
    Join Date
    Nov 2008
    Location
    Houston, Texas
    Posts
    19
    Liked
    0 times
    Rep Power
    0
    I also have a P0135 code (Bank 1 sensor 1 and O2 sensor heater circuit malfunction) showing up but these are the O2 sensors and, well, I'm pretty sure it's unrelated to my transmission issue. Right?[/quote]
    I had something simular with 02 sensor going out after a transmission fluid change... my truck was running strong before this shop jacked it up. I knew they had something to do with my sensor going out... but why did it?
    wyatt747@gmail.com
  14. #13
    Join Date
    Nov 2008
    Location
    Houston, Texas
    Posts
    19
    Liked
    0 times
    Rep Power
    0
    Default need some advice... trans. problem / 2001 Tundra v-8
    trans. drain / refill....
    My truck was running great and fast before I had a trans. fluid change at Highway 6 transmission here in my area.
    I thought it would be a good idea to get my transmission fluid changed at 100K miles; went to a transmission shop here and fig. it would be a simple service like an oil change, paid $49.95
    Now my truck has a loss in power, doesnt coast like it did before when exiting the freeway at 70 mph... it slows faster now. It used to run very fast on the street... could hold its own very well. And to make matters worse, my rear oxygen sensor went out also the day after this service.
    I am wondering, is it possible that this trans. shop put the wrong fluid in my transmission to make it act like this? It almost feels like I am pulling a trailer now, to describe the sensation... very upsetting...
    I have been trying to drive it hard to shake free what ever is holding me back; and no... its not my emergency brake.. =o)
    Any suggestions / emails would be greatly appreciated; I luv this truck! =0)
    ps) should i just get a trans./ flush from the dealer? never did that before, only the drain / refill.
    wyatt747@gmail.com
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Transmission shift solenoid
    By tundrabob58 in forum 1Gen-Tundra
    Last Post: 02-03-2011, 02:48 PM
  2. Shift pattern
    By nhparrot in forum Transmission
    Last Post: 03-07-2007, 08:55 AM
  3. Replies: 0
    Last Post: 12-14-2006, 01:17 PM
  4. The shift lever
    By nhparrot in forum Interior & Exterior
    Last Post: 09-11-2005, 07:45 PM
  5. Help me shift my Tundra?
    By farmerkd1 in forum Transmission
    Last Post: 10-17-2004, 07:28 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
