Old 08-03-2007, 08:45 PM
mongooztt's Avatar
Dealer : Tuscaloosa Toyota Scion
2005 Toyota Tundra SR5 DC TRD 4x4
Last Online: 11-05-2008 03:16 PM
mongooztt is on a distinguished road.
Send a message via AIM to mongooztt mongooztt's Photo Albums
Default Seat rock fixed!!!
I just got finished dancing around my driveway like an idiot. I fixed that super annoying drivers seat rock. I know many people have this problem and will let everyone know how I did it.
After studying the rock for a while, I decided that I could apply some simple engineering skills and eliminate the problem. I figured if I could add a little bit of preload (via torsion) on the seat frame, then wherever the rock was taking place, it would stop. It worked.
I used some washers like these
Remove these covers on the rear of the seat (they just pull off) and remove the bolts that hold the seat down (2x 14mm).
I stacked the washers under the drivers side of the seat mount, between the foot and the floor of the truck. After trying two, then three washers, I still had a little movement. Four did the trick. The seat is rock solid! The added height on the drivers side twists the seat frame just enough to stop the rock.
I do have a few things to address though. I am going to Lowe's to get a longer bolt because the washers reduce the amount of threads that go in to the hole. Also, I am going to try and mill a little spacer as thick as the washers and the same surface area of the foot to spread out the load. Although I am confident that the seat is secure, it'll just be for piece of mind.
I hope this helps everyone who has the infamous '05 seat rock.
Jeremy
2005 DC SR5
TRD 4x4
silver sky metallic
K&N Drop-in, Toytec 2.5 lift, Mickey Thompson Classic Locks 16x8, Dick Cepek FC-II tires 285/75/16, UWS toolbox, custom catback.
Old 08-03-2007, 11:12 PM
Dealer : Larry Miller Toyota
2005 Toyota Tundra,
2007 Toyota Camry
Last Online: 08-01-2008 08:50 PM
craigaz is on a distinguished road.
craigaz's Photo Albums
Default Re: Seat rock fixed!!!
Sweet! This has always annoyed me, I'll be performing your mod this weekend.
Thanks on behalf of '05 owners everywhere!
Old 08-03-2007, 11:13 PM
The Phoenix's Avatar
Moderator
Last Online: Yesterday 03:03 PM
Images: 2
The Phoenix's Photo Albums
Is it only 05's that suffered this? I don't think I've experienced this in my 06.
Thanks for telling us this. I will add this to the FAQ.
Old 08-03-2007, 11:18 PM
mongooztt's Avatar
As far as I know, and as much as I've searched on the subject, it seems as only 05's are affected. I'm not sure, but I also believe it is only on manual seats.
Jeremy
2005 DC SR5
TRD 4x4
silver sky metallic
Old 08-04-2007, 12:35 AM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
Last Online: 11-16-2009 09:59 PM
Images: 6
UnSub will become famous soon enough. UnSub will become famous soon enough.
UnSub's Photo Albums
Be sure to get bolts which are of the same specifications as the originals. You could easily end up with bolts that would sheer off in an accident.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery
5.7 Killer
Old 08-04-2007, 11:38 AM
TundraBear's Avatar
Moderator
Dealer : Carson Toyota Scion
2005 Toyota Sienna,
2006 Toyota Tundra 4x2 Limited DC
Last Online: Yesterday 11:13 PM
Images: 6
TundraBear is on a distinguished road.
Send a message via Yahoo to TundraBear TundraBear's Photo Albums My eBay
i experienced this with my '02 access cab so i bought an '06 to fix the problem!
2006 Tundra Limited DC: UniChip | Ram Air Performance System | TrueFlow Sealed Air Intake | 24" Bassani X-Muffler with Quick Time Electric Cutouts | IS Rims w/ Michelin LTX A/T2 265/70R16 | SkidRow FSP | Hellwig Antisway Bar | Retrax Bed Cover | Bazooka VSE | front/rear parking sensors | power tailgate lock | debadged | tinted windows | 2x baby mod (car seat)
2005 Sienna: Purple Plazma Headlights | de-badged | 2x baby mod (car seat)
Old 08-05-2007, 12:17 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 02:50 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Your fix is a good one but feel that 4 washers will compromise the integrity of the seat in an accident and your idea of a different bolt is going to make you MUCH safer in an accident god forbid ya be in one!! I would limit the washers to 2 at the most and make sure you get the proper grade of bolts. I do not know what the proper grade would be, but i would go to my Toyota parts dealer and see if they could not get you a similar bolt! My experience with hardware is mostly with Aircraft hardware and we could not just add and subtract like you are doing because of the jail time we would be facing if something happened to someone because we used improper hardware and all you need is some new bolts and it's a shame Toyota can't fix this issue
Old 08-05-2007, 12:24 PM
mongooztt's Avatar
Thanks for your observations. I do agree with your concerns on the integrity of the seat in an accident. I am replacing the bolt with a longer one; do you think that a grade-8 would be suffice, or do you think the OEM bolt is stronger than that?
I am also going to make a block to put under the seat foot to eliminate the washers all together. The washers were just to test if my idea would work.
Jeremy
2005 DC SR5
TRD 4x4
silver sky metallic
Old 08-05-2007, 12:46 PM
2qik2see's Avatar
Dealer : Pohanka of Salisbury
Last Online: 11-26-2008 10:05 AM
2qik2see is on a distinguished road.
2qik2see's Photo Albums
Talking Re: Seat rock fixed!!!
grade 8 would be perfect. i'm not sure but i don't believe factory bolts are grade 8. i was in an accident 8 years ago in a tercel and the seat bolts were sheered right in two. just the back ones though. the fronts were only bent.
Old 08-05-2007, 05:59 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Yesterday 11:12 PM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Bring the bolt into the Lowes hardware section and check the pitch. The M8 bolts have a 20, 30, 40, 50 pitch, and that makes all the difference. I just swapped my skidplate bolts out because I F'd them from removing too much.
I'm not too sure what the "rock" you are referring too. Have I not experienced it b4 or am I just not noticing it?
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 08-05-2007, 07:09 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
my 06 drivers chair does not rock but the passengers side back rest vibrates bad with no one in it even on a good road, as if their are any in NM
Not too sure which bolts to use like i said i would go with a automotive quality bolt myself. maybe no difference but i have a good budy as a parts man at a dealearship and he would allways hook me up with this type of issue? Good luck!!
Old 08-06-2007, 05:43 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: Yesterday 06:08 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
I believe automotive grade is grade 5. Grade 8 will be more then enough. I would not stress about the safety of putting 4 washers under 1 bolt in the seat as long as the bolt is longer (like you are doing)
heck go with a F911 bolt and be done with it
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 11-16-2007, 09:23 PM
Dealer : Toyota Scion of Garden Grove
Last Online: 11-16-2007 09:30 PM
sameezyfosheezy is on a distinguished road.
sameezyfosheezy's Photo Albums
my driver seat on my 06' tundra doesnt rock but it shifts every now and then.. makes a funny clicking noise why is that?
Old 11-17-2007, 08:15 PM
Tundraspv's Avatar
Tundra fan!!
Dealer : Orleans Toyota
Last Online: 11-22-2009 11:06 PM
Tundraspv is on a distinguished road.
Send a message via AIM to Tundraspv Send a message via Yahoo to Tundraspv Tundraspv's Photo Albums
There was a TSB on this, and I had mine fixed!!!
2006 Tundra,double cab, Limited, with the TRD package. It is Spectra Blue Mica. UPGRADES: all lights are HIDs, Gaylords X-2000 hard tonneau cover, and I have an extra 4 ports hard wired in. Alpine CDA-9886, w/iPod integration, BT & Sirius.
Old 11-18-2007, 07:56 AM
Dealer : Glens Falls Toyota
2006 Toyota 4Runner,
2005 Toyota Tundra
Last Online: 10-03-2009 08:51 PM
bidman67 is on a distinguished road.
bidman67's Photo Albums
just brought my truck in for service and mentioned the seat issue and the service manager ordered a whole new seat frame to be installed...hopefully will fix the problem.
2005 Tundra SR5 Double Cab 4x4
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/106905-seat-rock-fixed/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-24-2009 09:33 AM
Getting to the rear speakers in 2003 Corolla? Rickjamesbish Corolla Matrix 8 01-24-2007 09:47 PM
Which seat covers? / Cleaning seats stevegittings Tacoma 13 11-16-2006 10:52 PM
uncomfortable seats for big men lhazen Interior & Exterior 24 12-16-2005 08:07 AM
Seat Replacement lhazen Interior & Exterior 2 12-11-2003 12:19 AM
Child Seat/Booster Seat Red Rider Interior & Exterior 17 07-05-2002 01:22 PM
