Old 08-30-2007, 09:17 PM
- Other -,
Last Online: 11-22-2009 10:55 AM
adamjt is on a distinguished road.
adamjt's Photo Albums
Default 2001 v8 fan clutch = loud?
My fan clutch didn't seem to be working up to par anymore...so I ordered the listed Hayden fan clutch for it. Its a 2001 v8.
With the toyota clutch (i dunno how long it wasn't working well) the fan would only spin on high speed when I first started it up and lasted for maybe 10 seconds. Never heard it go fast again, when when the engine got pretty hot.
With the Hayden clutch, the fan spins fast and loud until I get going about 40 mph the first time, then it kicks to low. When I come to a light and stop after that, it will spin up fast again as I accelerate through first gear, then will kick to low.
Is the original toyota fan like this as well????? when its working right.....don't wanna return it and spend $125 on the toyota one to find its the same way.
Old 08-30-2007, 10:14 PM
- Other -,
Default Re: 2001 v8 fan clutch = loud?
anyone know what company makes the stock fan clutch?
Old 08-30-2007, 10:28 PM
Dealer : Downtown Toyota Scion of Spokane
Last Online: 02-06-2008 12:09 AM
mike91 is on a distinguished road.
mike91's Photo Albums
That was the first thing I noticed when I bought my tundra. I hate that sound. After I installed my cold air intake, I could no longer hear that noise. Even if the CAI doesnt give me performance atleast it sounds better than that noisy fan. Oh and that sound is a ver common thing on toyotas. I have noticed the fan on my buddies tacomas, and older trucks too. I hope this helps. Just dont let it over heat.
Old 08-30-2007, 11:04 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Yesterday 11:52 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
The Hayden fan hub sounds like a centrifugal controlled unit whereas the Tundra unit is controlled with a bi-metal temp sensitive plate into a vicious fluid engagement hub. It should only engage when the incoming air to the hub off the radiator reaches a preset temp or when the engine is first started. The Hayden must dis-engage when it feels the engine rpm is high enough to indicate highway speed for cooling air.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Solution to loud radiator fan noise? T100 Tide1 Aftermarket Products 0 09-16-2006 11:13 AM
2001 tundra v6 5spd clutch 4wd bjamin Engine & Drivetrain 2 03-21-2006 07:03 AM
Electric Fan w/ Variable Speed Controller Installed... bamachem Engine & Drivetrain 0 06-16-2005 12:41 PM
2005 Tacoma and still use clutch fan sl3000gt94 Engine & Drivetrain 15 02-25-2005 05:00 PM
fan clutch upgrade for towing? CODan Towing 7 06-08-2004 03:27 PM
