  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-01-2007, 08:38 AM
Last Online: 09-13-2007 06:47 AM
etcthorne is on a distinguished road.
etcthorne's Photo Albums
Default Technical Write-Up - Squeaking Leaf Spring Fix
Well, sort of technical anyway....
I had a "creaking" and "Chirping" leaf spring on the Driver's side. Didn't have to drive the truck to hear it - simply bouncing on the rear bumper adequately demonstrated the maddening creaking noise. While inspecting things to see if anything was amiss, I noticed the leaf spring clamp on the forward end - closest to the front of the truck - was only attached at one side. The inboard side was hanging in the air.
Being a big, studly guy, I sprayed a metric butt-ton of white lithium grease all over and between the leaves (as best I could) and that clamp, and all along the leaf spring. I then Used a C-clamp to close that clamp up tight.
Went for a test drive and had the worst squeaking you ever heard (X1000 times worse than before I had tightened the clamp).
After about an hour of looking through this board for hints (or fingers pointing at me for being stupid re: what I had just done to the spring and clamp), I got the bright idea that maybe those leaves need to move, and by closing that clamp as tightly as I had done, maybe I put the spring into a position where it could not move.
Walked out to the truck with a BFS (Big Freaky Screwdriver), layed it across the top of the clamp diagonally, where you can get some leverage, and loosened it up a bit.
Then, I wedged the BFS between the sides of the clamp and the spring itself and pulled and moved things a bit.
After each try, I would mount the rear bumper and bounce a bit (be nice now, this is a family board). After a couple of tries at wedging the BFS in the side of the clamp and moving the spring laterally back and forth, the creak was gone. Mind you, I did this little wedging and moving thing on the front and rear brackets.
So, I'm thinking the combination of the Metric Butt-Ton of lithium grease, using the BFS to loosen the clamp I had just tightened to the point I could have left a charcoal brick in there and come out with a diamond, and jacking the actual leaf springs side-to-side actually fixed this problem.
Drove around for about 50 miles yesterday - no noise. Went out and washed the truck (bounced on the bumper again) - no noise. I think the key is not to tighten the clamps to the point the spring cannot move or adjust.
I hope this helps someone.
Mark
2004 V8 Tundra Access Cab
Old 09-01-2007, 08:46 AM
Default Re: Technical Write-Up - Squeaking Leaf Spring Fix
Oh, by the way, I priced leaf springs from Toyota yesterday in a moment of despair until I fixed it - those suckers are over $500.00, so don't break 'em.
In another intestering bit of irony, my Platinum extended warranty will not cover a squeaking leaf spring, or so Toyota told me yesterday.
Old 09-02-2007, 11:10 AM
The Phoenix's Avatar
Moderator
Last Online: Today 03:03 PM
Images: 2
The Phoenix's Photo Albums
Thanks for the help Mark. I've added your thread to our 1st-gen FAQ
Old 01-03-2008, 08:35 PM
Ashley83's Avatar
Dealer : Mike Johnson's Hickory Toyota Scion
2003 Toyota Tundra
Last Online: 02-05-2009 02:43 PM
Ashley83 is on a distinguished road.
Send a message via Yahoo to Ashley83 Ashley83's Photo Albums
That sucks because my leaf springs just started squeaking.
Old 01-23-2008, 04:02 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 07:07 PM
Images: 17
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
I'm new to the forum, so first, a hearty hello all from Riverside, CA.
I had the same problem. My service manager told me that it is a common problem, especially after a dry summer. He also said that the only REAL way to do the job properly is to work on it when the truck is LIFTED up off the wheels. It is then possible to gain access to the gaps between the spring bars and get the heavy duty grease into the space. He said that the ole WD-40/grease trick while it is sitting in your driveway will, for the most part, just make the squeek worse. He's right!
Old 01-23-2008, 09:59 PM
El Jeep's Avatar
Dealer : Desert Toyota Scion Of Tucson
2005 Toyota Tundra,
2004 Toyota Land Cruiser
Last Online: 11-21-2009 10:01 AM
El Jeep is on a distinguished road.
El Jeep's Photo Albums
Check your rear shock mount bushings as well. There is a TSB on this. If your truck is under warranty they take the bushing out, flip it over, install it again. No more squeaks.
2005 Tundra Double Cab 4x4
2001 BMW M5
Old 02-02-2008, 02:53 AM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Last Online: Yesterday 02:40 AM
Images: 7
Hi Volt will become famous soon enough.
Hi Volt's Photo Albums
I have a squeak on the driver's side of my '01. Finally found that one of the noise pads on the end of the sping pack was missing ( plastic piece between ends of springs ). This causes metal on metal rubbing and a squeak. The end of the leaf in question has slight lip which allows a big screwdriver to be wedged it with a few taps of a hammer. I then applied some antisieize compound in between the leaves at the point the bushing is missing. Remove the screwdriver carefully of you will get a shot of the antisieze compound shot out at you. This fix lasts for close to a month.
Old 02-02-2008, 04:47 AM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: 11-18-2009 11:10 PM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Nice write up, thanks.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/109538-technical-write-up-squeaking-leaf-spring/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 08-29-2009 10:44 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-02-2009 10:43 PM
2005 rear leaf springs squeaking again tguil Tacoma 10 08-20-2007 05:40 PM
Leaf spring fix to ride bounce (not bed bounce) GeneralSpring Tundra 16 08-07-2007 10:22 PM
Leaf Spring Clunk?? Portugue Suspension & Axle 12 07-03-2007 10:28 AM
05 Rear Leaf Spring TSB tbrown78 Tacoma 13 07-09-2005 12:29 AM
Tundra Offroad Mods and Tech DevinSixtySeven Off-Roading 15 05-24-2004 10:22 AM
