"Signs" of bad ball joints... any 2000-02 models have the issue? warning signs? - Page 3
+ Reply to Thread
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 52
Thread: "Signs" of bad ball joints... any 2000-02 models have the issue? warning signs?
  1. #31
    Forum Admin Tundradrenalin's Avatar
    Join Date
    Apr 2007
    Location
    Virginia Beach, VA, USA
    Age
    37
    Posts
    8,137
    Liked
    424 times
    Images
    240
    Rep Power
    5011323
    Default Re: "Signs" of bad ball joints... any 2000-02 models have the issue? warning signs?
    Quote Originally Posted by 5 Speed View Post
    Has anyone done a step by step to change out the ball joints on our tundra? They are 72 bucks a piece and I don't think they would be that difficult. Changed my timing belt on the V-6 with no problem, just haven't changed a ball joint before. I think I will just change mine out if they don't cost a ton. Anyone changed one themselves?
    Hey 5 Speed,
    The SSC (Special Service Campaign) for the ball joint recall, the copy that the dealer gets, has the instructions for replacing the lower ball joint in moderate detail. I might have a copy on my thumb drive with all my other TSBs and stuff. (can't use them at work anymore though):dry:
    But this SSC letter would be for Tundra models like mine, '05 and around that.
    New to the forum? CLICK HERE!
    Questions about advertising? CLICK HERE!
    Know the facts about Warranties and the Magnuson-Moss Act.
    Link to Amsoil -->
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #32
    Supporter Crazy Ivan's Avatar
    Join Date
    May 2007
    Location
    Landrum SC
    Age
    37
    Posts
    2,829
    Liked
    96 times
    Images
    64
    Rep Power
    54226
    they are very easy to change. You need 14mm socket, 19mm socket, pliers or flat screwdrivers, and heavy hammer. secure your truck/suv with jack stands. take wheel off. loosen 4-14m bolts, and loosen 1-19mm nut (on very bottom of suspension.) Then use your heavy hammer to hit on a side of connection, untill lower bolt joint becomes loose. remove nut, and move your suspension away, and unbolt 4-14mm bolts.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    2006 Toyota Tundra DC SR5 4x4 - TRD supercharged, TRD BBK, TRD exhaust, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, and many other mods.
  4. #33
    Supporter ricqik's Avatar
    Join Date
    Feb 2000
    Location
    Twin Cities, MN
    Posts
    1,475
    Liked
    42 times
    Images
    4
    Rep Power
    4574
    So when one buys the balljoint, they just have to put it in and tighten the nuts & bolts. Is there any pressing or special assembly or basically just a swap. I may need to do mine for preventive measures, currently at 155k.
    '00 tundra
    '06 sequoia
    '98 forester
  5. #34
    Join Date
    May 2007
    Location
    Landrum SC
    Age
    37
    Posts
    2,829
    Liked
    96 times
    Images
    64
    Rep Power
    54226
    Quote Originally Posted by ricqik View Post
    just a swap, no special tools required.
  6. #35
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,134
    Liked
    745 times
    Images
    22
    Rep Power
    12366
    It's actually easier if you use a press tool, and much less damaging than a hammer.
    Checker has a semi-adjustable piece, I think by the manufacturer "OEM", it's in a red case...it fits perfectly around the lower arm and over the stud of the lower ball joint. Took all of a couple minutes to set it up and pop it out with a breaker bar.
    Just make sure you use RED loctite (permanent) on the four bolts securing the knuckle to the spindle, and set them to the correct torque. Otherwise they'll work loose, shear off, and you will crash.
    -Sean
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  7. #36
    Veteran Member 5 Speed's Avatar
    Join Date
    Feb 2002
    Location
    Santa Barbara, CA
    Posts
    1,035
    Liked
    153 times
    Images
    20
    Rep Power
    6774
    Quote Originally Posted by Tundradrenalin View Post
    Hey 5 Speed,
    I would love to see the ssc. I would bet the replacement part is the same. I have to order some stuff and would put these on. Does the ssc have the torque settings? I think it would make me sleep better since I have had a 4 wheel camper on the back for the past 4 years.
  8. #37
    Join Date
    Feb 2002
    Location
    Santa Barbara, CA
    Posts
    1,035
    Liked
    153 times
    Images
    20
    Rep Power
    6774
    [QUOTE=Tundradrenalin;996936]Hey 5 Speed,
    Thanks a million for the ssc on the front lower ball joint, now here is my big question. If you price the individual ball joints they are about 72 bucks a piece from "Toyota Parts" - OnlineToyota Parts and Accessories. I have purchased from them since my tundra was new and their service and prices are great. If I put in the ssc part to order it is 199 dollars? What is in the kit that makes it 60 dollars more? Do you think the ball joints are different? This is the old ones vs. the new ones? Can't believe they would sell the old ones, I don't think a few cotter pins, and bolts could make the cost that much more? Maybe dust seals? Since it is a universal kit different for Sequoia? Has anyone seen the kit and what is inside? Thanks
  9. #38
    Supporter MrGrowl791's Avatar
    Join Date
    Apr 2002
    Location
    Toomsuba, MS
    Age
    59
    Posts
    34
    Liked
    0 times
    Rep Power
    14
    Recalls Summary
    Make / Models : Model/Build Years:
    TOYOTA / 4 RUNNER 2001-2002
    TOYOTA / SEQUOIA 2002-2004
    TOYOTA / TACOMA 2001-2004
    TOYOTA / TUNDRA 2002-2004
    Recall Number: 05V225000
    Summary:
    ON CERTAIN SPORT UTILITY VEHICLES, DUE TO A MANUFACTURING ISSUE IN THE FRONT SUSPENSION LOWER BALL JOINT, THERE IS A POSSIBILITY THAT THE SURFACE OF THE BALL OF THE JOINT MAY HAVE BEEN SCRATCHED. THE BALL JOINT MAY EVENTUALLY EXPERIENCE EXCESSIVE WEAR AND LOOSENESS, RESULTING IN INCREASED STEERING EFFORT.
    Consequence:
    THE LOWER BALL JOINT MAY SEPARATE FROM THE KNUCKLE CAUSING LOSS OF STEERING CONTROL AND A CRASH COULD OCCUR.
    Remedy:
    DEALERS WILL REPLACE THE FRONT SUSPENSION LOWER BALL JOINTS FREE OF CHARGE. THE RECALL BEGAN ON JULY 5, 2005. OWNERS MAY CONTACT TOYOTA AT 1-800-331-4331.
    Notes:
    TOYOTA RECALL NO. 50J. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
    So, 2001 Tundras are not included?
  10. #39
    Join Date
    Feb 2002
    Location
    Santa Barbara, CA
    Posts
    1,035
    Liked
    153 times
    Images
    20
    Rep Power
    6774
    The 2000 and the 2001 are not part of the recall, but I want to do the replacement so I don't have to think about it. Priced the joints and they are about 72 bucks each plus a few hours and I think we can sleep a lot easier, just trying to figure out what joints to replace them with.
  11. #40
    Join Date
    Oct 2009
    Location
    Massachusetts
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Here is what happened to my 2001 Tundra this morning while driving the kids to school. I was not on the highway or high speeds, thank goodness.
  12. #41
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    606
    Liked
    50 times
    Images
    7
    Rep Power
    2082
    Were there any symptoms prior to this event? Any heads-up that something was wrong?
  13. #42
    Join Date
    Oct 2009
    Location
    Massachusetts
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    No, none. My mechanic asked me if I heard a noise or anything and I had not.
  14. #43
    Join Date
    Aug 2006
    Location
    RI
    Posts
    97
    Liked
    3 times
    Rep Power
    9
    How many miles on it?
    I have a 2006....... 18,000 miles. I have not yet done the recall.
  15. #44
    Join Date
    Oct 2009
    Location
    Massachusetts
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Mine is around 180,000 miles.
  16. #45
    Join Date
    Apr 2007
    Location
    Age
    37
    Posts
    8,137
    Liked
    424 times
    Images
    240
    Rep Power
    5011323
    Quote Originally Posted by miadlor View Post
    Compare your VIN with those in the SSC (Special Service Campaign) and see if yours is affected.
    Here's the official letter: http://www.tundrasolutions.com/forum...recall-70b.pdf
    Link to Amsoil -->
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Replies: 0
    Last Post: 01-07-2007, 01:33 PM
  2. Upper Ball Joints Bad??
    By MATRDguy in forum Suspension & Axle
    Last Post: 10-03-2006, 03:43 PM
  3. Toyota Tacoma Bolsters Comfort And Convenience For 2007
    By TS Support in forum Toyota, Scion & Lexus News
    Last Post: 09-20-2006, 08:40 PM
  4. Camburg Upper A-Arm Install question.
    By auslandt in forum Lifting
    Last Post: 05-21-2006, 08:26 PM
  5. What do Ball Joints sound like/act like when they are bad?
    By Mike Donofrio in forum Suspension, Axles, Brakes
    Last Post: 06-07-2004, 02:30 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
