Old 09-12-2007, 08:10 PM
Dealer : Folsom Lake Toyota Scion
2004 Toyota Tundra,
- Other - AC LTD 4X4 TRD
Last Online: 09-21-2009 06:28 PM
evenfall is on a distinguished road.
evenfall's Photo Albums
Default DIY: Slack in drink holder II: My Solution
Ok, here's my solution.
I went to Home Depot and selected two grey 2-1/2 inch conduit couplers from the electrical department. My interior is grey, so fine. Cost: about $5.00
Th cup holders have a taper in them and I determined that if I cut a ring off the coupler just 7/8ths inch wide, it would do what I wanted. You might want to go thicker than 7/8ths, but I did not want them flush or proud. I wanted a slight recess.
The couplers have letters embossed in one end so I used the end which was blank and measured down 7/8ths of an inch and put some small tick marks with a sharpie. Then, using blue masking tape I laid a tape line along the tic marks and cut to the line with a Japanese Ryoba Saw. I selected this saw as it cuts on the back stroke and leaves a small kerf and a clean cut. The tape makes an easy to see removable guide line to cut to as you are cutting on a radius. It makes optical alignment of the saw on the pipe coupling easier and isn't permanent.
As a strong note of warning. You could choose to use a Chop Saw to make this cut, but many blades have a lot of hook angle. This coupling is very short. It is smaller than you want to hold close to a saw blade and the likelihood of the blade catching on PVC is high. Doing this could result in a very dangerous situation including the loss of fingers. Rotating blades catching and hooking is even true when cutting safe lengths of PVC. I would not advise cutting the ring off with a powered saw should you choose to make these ring adapters. I do not feel it is a safe practice.
Clean up the cut edges with a mill file. You could use sandpaper on a block too if that is what you have.
Here is Photo 1 showing the drink holders, the full coupling, the cut coupling showing the tape line I cut to, the ring I want to use and a soda can with a thermos insulator on it:
The ring is a compression fit. Here is photo 2 of the 7/8's ring installed as far in as it will go:
The inside diameter of the ring is nearly the same as the bottom of the cup holder.
And here is photo 3. Both rings installed and taking up the slack around both a regular soda can and the Thermos insulator on a soda can:
It really does take up a lot of the slack. there is just a little with the thermos insulator, a little more with the soda can. My Coffee mug will fit inside the ring as well. Water bottles like the ones from Costco, "Kirkland" brand, will fit in the thermos insulator so the will also fit inside the rings.
As I said, the rings are a compression fit and so they pull out with ease and can be stowed inside the console if larger drinks like fountain soda cups are in use.
I feel this solution will corral a lot of drinks a lot better than what is there in the first place. Like I said in my initial post, these consoles are pretty active and it is not uncommon to have your drink splash a long ways from the room they have to move in there. I consider this a huge improvement.
You may be able to find vinyl paint which matches your interior, should you choose to paint the rings you make. Auto body supply stores are a good, maybe best source for these paints if you buy local. Otherwise you can also find them online.
There were many really good suggestions in this thread and I thank you all for participating. Your ideas helped me with mine, and with your help, this is what I came up with. Of course some further slack reducer methods could be used in conjunction with this method and some great ideas were mentioned. Thanks again.
~evenfall~
~Phantom Gray Pearl~
Last edited by Tundradrenalin; 05-21-2008 at 09:21 AM. Reason: repaired photo links
Old 09-13-2007, 12:14 PM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
Last Online: Today 04:58 PM
Images: 9
longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light.
longwoodklon's Photo Albums
Default Re: Slack in drink holder II: My Solution
Great idea. I just finished upgrading my window latches to the metal ones trftoy made, looks like this will be my next project.
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 185k miles and counting......
Old 09-13-2007, 12:25 PM
Boboy's Avatar
Dealer : Arlington Toyota Scion
2006 Toyota Tundra Limited - Salsa Red,
2000 Toyota Camry XLE V6 Super White,
- Other - 2005 Honda Civic SE
Last Online: 09-18-2009 01:21 AM
Images: 2
Boboy is on a distinguished road.
Boboy's Photo Albums
That's pretty slick! I've been following this thread for some reason, it's like driving by a car wreck.
Old 09-13-2007, 12:33 PM
Salty_Dog's Avatar
Assistant Administrator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 08:45 PM
Images: 578
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
My interior is tan.
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 09-13-2007, 01:21 PM
The Phoenix's Avatar
Moderator
Last Online: Today 03:03 PM
Images: 2
The Phoenix's Photo Albums
Originally Posted by Cyberbilly View Post
My interior is tan.
Time for spray paint
Added this to the FAQ!
Old 09-14-2007, 11:27 AM
Gatorman76's Avatar
Dealer : Coggin Toyota Scion of the Avenues
2005 Toyota Tundra
Last Online: 11-05-2009 06:35 PM
Gatorman76 has blessed us with their presence. Gatorman76 has blessed us with their presence. Gatorman76 has blessed us with their presence. Gatorman76 has blessed us with their presence.
Send a message via ICQ to Gatorman76 Gatorman76's Photo Albums
My son saw my cupholder sitting on the hump in my regular cab. He said, "dad, you might be a redneck if your cupholder is a roll of duct tape". Hey! the center hole is just the right size for a can of whatever and the weight keeps it placed. Mine's a work truck with vinyl floors so if something spills, who cares. It wipes right up.
2005 reg.cab long bed. A/C, 5 sp auto, cold weather pkg. V8, 4WD, LSD, Desert Sand. 245-75-16 Firestone Destination AT. Extang Trifecta tonneau. Rugged Liner bedliner, Lund vent visors. Classic Accessories back seat gun case, rear breather mod., Garmin Nuvi 200. Clean Breaze rear sliding window screen. Deer head antennae topper.
http://s215.photobucket.com/albums/c...man76_photos/?
Old 09-14-2007, 09:42 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Last Online: Yesterday 02:40 AM
Images: 7
Hi Volt will become famous soon enough.
Hi Volt's Photo Albums
Nice Job Evenfall !
My interior is tan.
Dry your eyes, you can by vinyl paint to match car interiors.
Old 09-16-2007, 01:44 AM
Cian's Avatar
Dealer : Elmhurst Toyota
Last Online: 11-20-2009 08:49 AM
Images: 25
Cian will become famous soon enough.
Cian's Photo Albums
Default Re: DIY: Slack in drink holder II: My Solution
Okay, that was pretty innovative.
2001 SR5 Access Cab 4.7V8 4x4
OEM: FJ Rims; bed-liner; alarm; running boards; all-weather mats; door sill protectors; 13WL brake caliper upgrade
TRD: color-keyed mirror covers, embroidered signature mats
OTHER: Bridgestone A/T Revos; NGK Iridium IX spark plugs; Skid Row front skid plate; Fumoto drain valve; Vibrant resonator; Magnaflow exhaust tip; Form-Fit deflector; Brembo rotors; Trfytoy window latches; Undercover tonneau; Wheelskins leather steering wheel cover
PENDING: TRD coils, Bilstein shocks; TRD Kazuma LSD; Hellwig sway bar
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/110605-diy-slack-drink-holder-ii-my/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 08-13-2009 04:04 PM
Too much slack in the drink holder evenfall 1Gen-Tundra 23 09-12-2007 10:34 AM
