Does my 05 tundra TRD 4x4 have a limited slip diff stock?
Life's Short, Ride Hard!
Mods-
-2.5" Magnaflow cat back w/resonator removed w/ 3" tip
-295/70/17 Toyo Open Country Mud Terrains
-MO 957 series moto metals flat black
-rev Teck leveling kit 3"spacer in front, 1" spacer in rear
Future Mods-
-Headers
-Limo Tint All the way around
-Spray in bed liner
-Intake
-Throttle Body Spacer
-Light bar
-3 Hella Black Magics
-And A Crap Load More......$$$$
check the differential... it should say
05 should have one. i haven't seen an 05 w/ V8 without LSD. the sticker on them can come off, so just by looking you will not be able to tell unless the sticker is still on there.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
Check the VIN number at a dealer, i'm pretty sure the can tell you...damn i wish i had LSD or Locker:cry:
2005 Toyota Tundra Regular Cab V8 2WD
Im pretty sure your 05 trd has a lsd, its the same truck i have. There won't be a button either.
2005 DC TUNDRA TRD LMT. 4x4
Better ask sombody.
mines don't have a button either. but what i have noticed is that dblcabs with LSD that has that button is the non-TRD trucks. all TRD trucks i have seen does not have that button. my brother in law and my truck are the same, difference in color only. mines has the TRD option, his doesn't, he has a button, mines does not. dunno, it's weird...
01 Honda Civic
95 Acura Integra
Mine is a 4x4 NON-TRD with LSD and I do NOT have a button.
Mechanical LSD was a stand alone option on the Tundras, at least in '05. I checked the box for it. But there were some combinations that resulted in different types of LSD. The models with stability control have an electronic LSD (abs activated instead of mechanical). I believe the 2wd trucks also have the electronic LSD.
Those of you with the buttons, do you have stability control? I was under the impression those models have a button to turn it off.
'08 Nissan Pathfinder 4x4 (my DD)
'05 Honda Odyssey (her DD)
'03 Ram 3500 Cummins 6-speed dually (for haulin)
'05 Tundra DC 4x4 (gone)
My 4X4 has LSD
I believe all limited 4x4 came with the mechanical LSD(clutch plates in the diff) but not sure about non-trd versions.
