HID help H4 hi/low
+ Reply to Thread
Results 1 to 6 of 6
Thread: HID help H4 hi/low
  1. #1
    Rookie kenadian07 is on a distinguished road.
    Join Date
    Jul 2006
    Location
    orlando, fl
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    Default HID help H4 hi/low
    Hello All,
    I was looking forward to my HID, finally got it, but when I installed it, it doesnt light up. Only the high beam comes up and not the low beam, which I obviously need. Please let me know what I should look for, or is the kit defective??
    Thanks.
  2. #2
    Junior Member ridehigh is on a distinguished road. ridehigh's Avatar
    Join Date
    Nov 2006
    Location
    Whittier, CA
    Age
    25
    Posts
    142
    Liked
    0 times
    Rep Power
    7
    Default Re: HID help H4 hi/low
    Most H4 HID kits are not high/low. If the kit is high/low it is usually HID Low and Halogen High. There are kits out there that are HID High/Low, the bulb itself is on a actuator the moves the bulb forward and back in the headlight assembly to give you the High/Low beam. These kits are usually quite a bit more expensive than regular HID kits.
    Ken
    2000 tundra V8 access cab:
    4'' RCD lift, 1.5 Progressive AAL w/ 1'' block, Billet Grille, Rhino Liner, Volant Cold Air Intake, Airaid Throttle Body Spacer, Magnaflow muffler turndown w/ resonator removed, Mickey Thompson Classic Locks 16x8, Nitto terra Grapplers 285/75/16
  3. #3
    Crazy Ivan that travels a lot Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan wants you off his porch. Crazy Ivan's Avatar
    Join Date
    May 2007
    Location
    Landrum SC
    Age
    35
    Posts
    2,847
    Liked
    98 times
    Images
    64
    Rep Power
    48313
    can you post pictures or link for your HID kit?
    2006 Toyota Tundra DC SR5 4x4 - TRD supercharged, TRD BBK, TRD exhaust, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, and many other mods.
  4. #4
    Lurking Member GRON86 is on a distinguished road.
    Join Date
    Oct 2007
    Location
    TUCSON,AZ
    Posts
    44
    Liked
    0 times
    Rep Power
    6
    Exclamation Re: HID help H4 hi/low
    Had The Same Problem With My Truck. Installed The Low Beam Hid's Then My High Beams And Fog Lights Stoped Working. The Thing Is. You Have To Get A High/low Beam Kit For The Tundra. It S A Bit More Expensive But You'll Need This In Order To Keep Your High/low Beams And Fog (if You Have Equipped) Working. Make Sure You Get The 3 Prog Connector. Hope This Helps. :d
  5. #5
    Join Date
    Jul 2006
    Location
    orlando, fl
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Hello, the connector is 3 prong, just no idea why the low beam wouldnt work. I had Hid on my integra, and it was a plug and play, no issue like this.
    GRON86, you mentioned that you installed low beam hid's, i have both, so I dont think its the same issue. I will post the link to my hid later since I am working on this at the moment.
  6. #6
    Join Date
    Jul 2006
    Location
    orlando, fl
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Issue is solved, I will put up pictures and link to where I bought it from tomorrow.
    Thank you everyone!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
