2002 Tundra timing belt.......replace?
+ Reply to Thread
Results 1 to 5 of 5
Thread: 2002 Tundra timing belt.......replace?
  1. #1
    Lurking Member Lend273 is on a distinguished road.
    Join Date
    Dec 2007
    Location
    Hickory
    Posts
    42
    Liked
    2 times
    Rep Power
    6
    Default 2002 Tundra timing belt.......replace?
    My 2002 Tundra has 140,000 trouble free miles on it.
    I have used Mobil 1 since the first oil change.
    My dealer keeps telling me I need to replace my timing belt.
    I'm of the opinion that "if it ain't broke, don't fix it".
    Should I replace the timing belt as he suggests?
    If so, are there other components that should be replaced at the same time?
    As a side note, pulsating front disc brakes seem to be a common problem on Toyota Tundras. Is there a long term fix for this problem?
    Thanks for your advice.
    Len in NC
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Cycleman6 is on a distinguished road.
    Join Date
    Nov 2007
    Location
    Swayzee, IN
    Posts
    237
    Liked
    0 times
    Rep Power
    6
    Default Re: 2002 Tundra timing belt.......replace?
    You will want to post this in the correct forum as you'll get better response. This space is for 07+ tundras, so guys around this part probally aren't real familiar with your question.
  4. #3
    Junior Member dafoot is on a distinguished road.
    Join Date
    Nov 2007
    Location
    mandan
    Posts
    221
    Liked
    0 times
    Rep Power
    6
    Yes. Replace the timing belt, like YESTERDAY! If the belt breaks, you will feel the pain in your wallet
  5. #4
    Supporter TX RN has disabled reputation TX RN's Avatar
    Join Date
    Mar 2007
    Location
    Rawlins, Wy
    Posts
    439
    Liked
    3 times
    Rep Power
    12
    Along with the timing belt, check the water pump. If your vehicle uses ethylene glycol as a coolant, you really need to check the water pump. Don't worry about Gen 1 vs Gen 2 post. Lots of us had Gen 1 Tundras. Good luck.
    Ride hard, die young and leave a good looking corpse. Now that I'm older...
    2013 DC 4x4 SR5 5.7 Barcelona Red TRD Off Road, Line-X Premium, Weather Tech floor liners...
  6. #5
    Join Date
    Nov 2007
    Location
    mandan
    Posts
    221
    Liked
    0 times
    Rep Power
    6
    Quote Originally Posted by TX RN View Post
    Good point on water pump. I also had 2 Gen. 1 Tundras. Great trucks!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
