LinkBack (4) Thread Tools Display Modes
  #31 (permalink)
Old 05-03-2008, 01:19 PM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: 11-17-2009 03:30 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
Default Re: Scangauge II Install (so easy a caveman could do it)
if you can't find the codes for the hp, i will look for them , and post them for you, by tommorrow.
it's just been a few bad days for me. i exhausted.
i just burried a friend.
gorilla
  #32 (permalink)
Old 05-03-2008, 01:23 PM
Boosted27606's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2006 Toyota Tundra,
1998 Lexus GS300 Silver,
- Other - 93 MITSU Eclipse
Last Online: Yesterday 04:00 PM
Images: 11
Boosted27606 is a splendid one to behold. Boosted27606 is a splendid one to behold.
Send a message via MSN to Boosted27606 Send a message via Yahoo to Boosted27606 Boosted27606's Photo Albums My eBay
oh Wow
ThanX Gorilla
Sorry about your loss
Incidentally, I do have the code for HP for the scangauge, I just dont know HOW TO enter it. I pushed MORE ...etc........ MORE everywhere and did not find a spot that said: ENTER CODE now.......
Boosting happily ...
List of mods ( growing Daily ): L.E.D.s inside , Camper Shell with inside lights, Back up sensors and Camera , Subwoofer and Amp , Scangauge II , Hellwig Rear Bar , Billet Rear windows hinges, K&N Air Intake , Heated Seats, Tailgate assist bar, Westin Bull Bar and Skid Plate, Under hood lights, 1.25" Spidertrax spacers in Front, 1.75" wheeladapter spacers in back, Ultimate window tint, Multivex Mirrors.
  #33 (permalink)
Old 05-03-2008, 01:50 PM
2005 Toyota Tundra
if you call the company they will put on the phone the master mind of this item.
just make sure when you call the company you have a full tank of gas.
it will be a perfect set up, than.
thats what i did, when i called him, he told me to call him back when my tank was full. which i did and within 5 minutes or less. it was all done.
your gone a love it for sure.
might want to dyno your truck to make sure the hp #'s are correct. i had to lower mine. i was getting a high # which i loved, but it was fake. so i wanted a real #. so i learned how to adjust it. so my #'s are at 326ish now.
thats engine Hp/or brake, flywheel hp not rear wheel.
hope it helps, thanks for the kind comments.
it helps
gorilla
  #34 (permalink)
Old 05-05-2008, 08:47 AM
2006 Toyota Tundra,
Images: 11
Thanks Gorilla, you are the ..... MONKEY !! I mean , The MAN !!!
  #35 (permalink)
Old 05-08-2008, 01:47 PM
JD and Beastlet's Avatar
2005 Toyota Sequoia Limited 4x4
Last Online: 11-20-2009 10:12 AM
JD and Beastlet is on a distinguished road.
JD and Beastlet's Photo Albums
Originally Posted by arseum View Post
The transmission temp is only available for Ford's currently...
http://www.scangauge.com/support/pdfs/XGAUGE.pdf
That's what I thought after reading the .pdf. I use my Sequoia as a tow vehicle... if they got tranny temp codes I would jump all over this thing.
2008 Starcraft ST 2700BH behind 2005 Toyota Sequoia Limited 4x4.
Linked by ProPride 3P 1400, stopped by Prodigy, guided by Garmin nüvi 760.
2006 Fleetwood Sun Valley - sold March 2009 / 2006 Dodge Caravan - traded April 2008
  #36 (permalink)
Old 05-08-2008, 07:10 PM
2005 Toyota Tundra
hi,
maybe i'm missing something here, don't get me wrong the more info the better.
but if your towing, what would be the reason for the guage.
mostly just to let you know, your burning up the tranny.
by having the tranny temp to high.
so you would have to pull over wait till it cools down and than start your trip again, in about a hour or 2.
i would think it would make more since to me, to increase the size of the tranny cooler or add a 2nd 1 to keep the tran's temp as low as possible.
are many of you blowing through tranny's that much because they are running so hot by towing?
mostly every tundra that comes with a tow package has a tranny cooler right?
is it that it's not large enough?
i'm sure you can get 1 made that will do more than you will ever need.
the only issue i see, is where are you going to put it?
i would love to know the reason, i'm always willing to learn something new.
gorilla
  #37 (permalink)
Old 05-08-2008, 10:40 PM
I'm not expecting the tranny to blow up - I just like to keep an eye on these things. In any case the Sequoia has an A/T Warning light that's designed to come on when the fluid starts to get too hot.
As for coolers, I agree - I don't think you can overcool a tranny so the bigger the better. There's one on it now and we'll have to see how it does this camping season.
Gee, if only the Scangauge II had a tranny temp gauge function, I could monitor it that way...
  #38 (permalink)
Old 05-09-2008, 05:31 AM
2005 Toyota Tundra
i would check ebay for the other types. and call those companys and ask them if they have the tranny temp guage that works with the toyota tundra/sequoia?
and i would even go as far as this. why don't you see if the 5.7 tranny coolor would fit. since it is a much larger engine and tranny. it should have a much larger tranny cooler. if it does somehow fit.
WOW, i'm sure now more than ever before you would be able to tow cross country without a issue.
now the other types of scanguages that i have seen can get expensive. if i remember correctly, they went as far as 500.
but before i would spend that much on 1, i would see if the 5.7 cooler or any other type would be worth it's weight in gold. by keeping your tranny so cool, it would never ever be a issue.
just a thought.
good luck on your search
gorillla
  #39 (permalink)
Old 06-12-2008, 07:23 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Yesterday 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Guess what I got today?
I think this weekend I'll do hispeed's mount idea. Looks like the best option for ease of view and so forth.
I agree with USAFTUNDRA, so simple. And the HP XGauge add-a-gauge was a piece o'cake. Took me a whole 20 seconds. That's a lie. It was more like 35
Thanks for the great threads on the ScanGaugeII everyone.
Anyone add all those O2 sensor ports on the add-a-gauge? Seems unecessary for 8 new ports to add.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
  #40 (permalink)
Old 06-12-2008, 09:46 PM
2005 Toyota Tundra
hi, i mounted mine right on top of my steering column.
and ran the wire through the steering column and under the dash. so you don't see any wire.
the scan guage is long and wide & not high, so there is no restriction of the guages. and it's so easy to use this way. it's just like looking at the guages. many installed them down below, but for you to look at it your looking down , eye's off the road. so that wasn't a option for me. just my opinion.
gorilla
  #41 (permalink)
Old 06-12-2008, 11:47 PM
stormtrooper01's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 08-22-2009 12:03 AM
stormtrooper01 is on a distinguished road.
stormtrooper01's Photo Albums
that thing looks pretty sweet. I just did an impulse buy and got one.
  #42 (permalink)
Old 06-12-2008, 11:51 PM
plugnickel's Avatar
2005 Toyota Tundra,
2002 Toyota 4Runner
Last Online: 07-28-2009 10:11 AM
plugnickel is on a distinguished road.
plugnickel's Photo Albums
Originally Posted by Brad's Dad View Post
Nice mounting job. I'm considering purchasing and this idea works!
Are you able to get transmission temperature to read out on your Scangauge II? I emailed the company with that question about my '06 (as well as how many cords I'd need for our 4 vehicles) and never heard back. Tranny temp is one reason I'd buy the Scangauge for sure (not to mention code reading on the 4 vehicles in our family).
Thanks for the great post and any info on tranny temp.
Fred
I sent Scangauge an email for the same question. NO ANSWER. Thanks for letting us know that it won't do the transmission temp.
YOU must watch this video:http://www.usawakeup.org/
http://www.blackfive.net/main/
  #43 (permalink)
Old 06-13-2008, 05:09 PM
Images: 205
I haven't seen a code made for the xgauge add-a-gauge for transmission temp. They'd probably post an update on their website once it comes out, if it comes out.
  #44 (permalink)
Old 06-15-2008, 04:27 PM
bjg411's Avatar
Dealer : Frontier Toyota
2006 Toyota Tundra TRD 4 Wheel Drive,
2001 Toyota Corolla Type S
Last Online: 11-12-2009 10:50 PM
Images: 34
bjg411 is on a distinguished road.
bjg411's Photo Albums
Hey I got a quick question I just ordered mine the other day should be here soon, but my question is that I put larger tires on my truck and have yet to calibrate the speedometer, is the scan gauge going to give me false readings or does it some how calcualte from different measures
See more photos at http://tundrageeks.com/forum/vHoist....iew&gid=101219
  #45 (permalink)
Old 06-15-2008, 05:51 PM
2005 Toyota Tundra
hi, my suggestion is for you to contact the company directly, for that question. there might be something for you to do. or since it read's, exactly what the obd2 port reading are, it should be dead on.
i have 20" tire's and rim's and my scan guage is dead on.
the only thing that needed to be adjusted is the HP. that was way off, from my dyno.
it was reading 377HP but my dyno was 326HP off by 51HP less than what it was showing me, so i wanted it to be dead on or as close as i could get it to the real #.
all other reading's were good enough.
gorilla
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/120449-scangauge-ii-install-so-easy-caveman/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 08-03-2009 10:15 PM
New Tundra Guy - TTORA Forum This thread Refback 02-07-2009 02:23 PM
Cup holder GPS mount This thread Refback 01-21-2009 01:50 PM
Scan gauge 2, where to put it - Page 2 - CustomTacos.com Forum This thread Refback 08-21-2008 10:52 PM
