Can 5W-20 be mixed with 5W-30?
+ Reply to Thread
Results 1 to 13 of 13
Thread: Can 5W-20 be mixed with 5W-30?
  1. #1
    Supporter fastmhz's Avatar
    Join Date
    Feb 2002
    Location
    Cypress, CA
    Age
    31
    Posts
    720
    Liked
    1 times
    Images
    1
    Rep Power
    14
    Default Can 5W-20 be mixed with 5W-30?
    My friend left me about 1 quart of 5W-20 oil and I was wondering can I mix that with 5W-30 for my Tundra? Any oil experts out there think this is okay to do? It's Mobil 1 Synthetic and that's all I run now since I have over 100k on my truck. I don't want the 5W-20 to go to waste! Thanks again!
    2000 Toyota Tundra V8 Ivan Stewart Edition
    2.5" Shocks by Sway A Way (Camburg)
    King Coil Springs 650lb x 14"
    11pk Deavers w/ 5100 Bilsteins
    LT285/75R16 Nitto Terra Grappler Load Range D 122Q
    Weld Racing Renegade 16x8 3 5/8 BS
    JBA Titanium Coated Headers
    Eclipse AVN5435 Unit
    '05 Tail Lights
    Clear Corners
    TRD LSD soon!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Marauder's Avatar
    Join Date
    Jan 2007
    Location
    Mission Viejo, CA
    Posts
    831
    Liked
    3 times
    Images
    35
    Rep Power
    669
    Default Re: Can 5W-20 be mixed with 5W-30?
    That one quart wont matter. It'll thin it out a tad, but we are talking about 5 quarts of 30 weight to one quart of 20 weight. I doubt the truck will notice.
    2006 Tundra Access Cab V8 - TRD
    16x8 Konig Countersteer w/Nitto TerraGrapplers 285/75R16
    Bilstein 5100 front/rear, Wheelers 1.5" rear blocks
    Dynomax cat-back w/Cherry Bomb Pro muffler
    Pioneer headunit w/Alphasonic amp and Sochse speakers
    HID retrofit, Acura TL bi-xenon projectors w/BMW ZKW lenses
    Truxedo Truxport / Trail FX black steps bars / Line-X Xtra
  4. #3
    Veteran Member shall36's Avatar
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    42
    Posts
    910
    Liked
    4 times
    Rep Power
    12
    NO...The Truck will blow up!!!!
    No. should be fine. 5W-20 is a relatively new weight that I think got started with the Honda V-Tec engine line. This time of year, especially if you are in a cold climate, won't matter.
  5. #4
    Junior Member Marty358's Avatar
    Join Date
    Dec 2006
    Location
    Altoona
    Posts
    209
    Liked
    0 times
    Rep Power
    10
    I read somewhere you should never mix weights of oil. Use it in your lawnmower.
  6. #5
    Junior Member luckyguy101's Avatar
    Join Date
    Jun 2006
    Location
    Sacramento, CA
    Posts
    106
    Liked
    0 times
    Rep Power
    21
    In such situations, I have been known to add a quart of similar, but not identical, oil to my Toyota Supras. My cars have never presented any problems as a result of my somewhat cavilier actions! I say "go ahead and pour it in."
    2006 Tundra Access Cab Stepside W/4 Wheel Drive and TRD Off Road Package A.R.E. LSII Tonneau
    Westin Platinum Series Chrome Step Bars
    Custom Sports Grille
    265/60R18 Firestone Destination LE Tires on
    18" Chromed 4Runner Limited Wheels
    JVC KW-XG700 Double Din Head Unit W/Bluetooth
    Alpine PDX-4.150 Amplifier
    Polk Audio DB6500s (Front) & DB650s (Rear)
    Q-Logic Enclosure W/Image Dynamics 8" DVC Subs
  7. #6
    Junior Member KCfj40's Avatar
    Join Date
    Dec 2007
    Location
    Kansas City
    Posts
    102
    Liked
    0 times
    Rep Power
    8
    Mixing viscosities doesn't matter- your final "weight" is the average of whatever you add. My wife's car runs 10w30 and takes 4.5qts. I just buy the 4qt jug of 10w30 and top it off with 10w40 or 20w50 (for my Land Cruiser) - whatever's nearby when I'm changing the oil. The Land Cruiser holds 8 qts so I've always got some sitting around. Been doing this for years with no issues.
    You can't mix between regular/synthetic blend/full synthetic but mixing weights, especially if they're by the same manufacturer, is no problem.
    1968 FJ40 4x4
    2000 Tundra standard cab 4x4
    2008 FJ Cruiser 4x4
  8. #7
    Junior Member Tundragod's Avatar
    Join Date
    Jun 2002
    Location
    Rochester,MN
    Posts
    50
    Liked
    0 times
    Images
    2
    Rep Power
    13
    No mixing of synthetic blend?
    2000 AC V8 4X4 SR5 traded
    2005 DC V8 4X4 SR5
  9. #8
    Supporter 2XOverhead's Avatar
    Join Date
    Jun 2007
    Location
    Los Angeles
    Posts
    1,038
    Liked
    4 times
    Rep Power
    1233
    Quote Originally Posted by Tundragod View Post
    Syn blen is by definition a mix. But, I'd say why not just change the oil w/ the same type.
    MODS: Oversized Drain Plug.
    DIY: ATF Flush, w/ Pics.
    DIY: Coolant Flush, w/ Pics.
    Coming Soon?
  10. #9
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    42
    Posts
    910
    Liked
    4 times
    Rep Power
    12
    Quote Originally Posted by Marty358 View Post
    Use ONLY straight 30w in your lawnmower...seriously.
    Mixing weights is not a big deal. The bottom line is, are you getting a weight that's appropriate for you application and climate.
    Mixing synthetic and dino is not a big deal...it's just that you are diluting the synthetic with dino, which is a problem if you are doing extended drain intervals.
  11. #10
    Mech. Engr. / Mechanic single's Avatar
    Join Date
    Dec 2006
    Location
    Tulsa, OK
    Age
    57
    Posts
    824
    Liked
    9 times
    Images
    21
    Rep Power
    1222
    Quote Originally Posted by shall36 View Post
    My lawn mower calls for 15w40. Go with the mfg. rec.
    White 06 SR5 DC - Blinglights bedlights
    Pop A Lock tailgate lock - TRD aftermarket LSD
    Custom Back Up Lights - Factory Fogs added
    Hellwig 7700 Swaybar - Bilstein HD shocks
    Firestone Sport Rite Air Springs w/onboard air
  12. #11
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    42
    Posts
    910
    Liked
    4 times
    Rep Power
    12
    Wow...that's a new one. B&S, Techumseh, and the other run of the mill air-cooled lawn 4-stroke engines have used straight 30W for years. Remember, when that engine heats up, the oil drops to 15W. In warmer climates, not the best things for an air-cooled engine. Maybe some of the new engines with oil pumps can use the 15W oils?
  13. #12
    Junior Member funfinder4's Avatar
    Join Date
    Oct 2006
    Location
    Bryan,Tx
    Posts
    318
    Liked
    0 times
    Images
    4
    Rep Power
    9
    ...Remember, when that engine heats up, the oil drops to 15W. In warmer climates, not the best things for an air-cooled engine. Maybe some of the new engines with oil pumps can use the 15W oils?
    I think your a little confused how a multi weight oil works. When a 15W-40 heats up it's viscosity doesn't drop to 15 weight. It's viscosity does drop as heat is applied but it wouldn't drop anymore than a straight 40 weight oil would. The "15W" rating simply means that at a set temperature (0 degrees C ?) the 40 weight oil will act (have similar viscosity) as a straight 15 weight oil would. It's still thicker when cold (you can't change fluid dynamics entirely), just not as thick as a straight 40 weight oil would be at colder temperatures.
    My Honda lawn mower calls for 10W-30 and has had M1 in it since new. I'm thinking about putting 5W-30 in it next time as I've used up all my M1 10W-30. That way all the engines in my "fleet" will be on the same oil.
    FunFinder4
    '05 2500 Dodge DC 5.9L Cummins, cheap X2
    '05 Jayco Jayflight 27BH TT
    '06 Tundra DC TRD; Prodigy brake controller, Cyberdyne transmission gauge, ScanGauge II; Sold
    '05 T-160 Shadow Cruiser TT; Sold
    http://community.webshots.com/user/Funfinder4
  14. #13
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    42
    Posts
    910
    Liked
    4 times
    Rep Power
    12
    You're right....I'm bass ackwards...
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
