Re: loosening coolant drain nut
If you are talking about the V8, there are two plugs to drain the block and one for the radiator. Each drain on the block has a spigot for you to attach a 5/8 internal diameter hose onto to minimize coolant spilling. Then, you use a 10mm socket and loosen the nut to allow the coolant to drain through the spigot. You don't need to take the whole nut out. Even after fully draining both sides and radiator, I still didn't get all 13 quarts out of the system.
There was already Super Long Life (pink) coolant in mine, so I refilled with new pink. Check if you have the Super Long Life (pink) or the Long Life (red) and stick with the same coolant.
2003 4Runner V8 2UZFE
