02-04-2008, 09:51 PM
Assistant Administrator
2005 Toyota Tundra AC 4.7L 4WD, 2004 Toyota RAV4 Sport 2.4L 2WD
Last Online: Today 01:00 PM
10
DIY (Do-It-Yourself) & User Knowledgebase
This is what makes an owner's forum successful, member feedback and commraderie. Here is a list of D o-I t-Y ourself projects with instructions from other members.
Enjoy!
General Knowledge, Mods, How-To's Maintenance Help Topics
Member Install Guides
Camburg UCA, DIY Install (by: Derek24)
Recon LED Bed Lights, DIY Install (by: pistolpete)
Hellwig Rear Sway Bar (7700 series), DIY Install (by: 5 Speed)
Downey HD Sway Bar End Links, DIY Install (by: Tundradrenalin)
Superlift TruSpeed Speedo Recalibrator, DIY Install 2005 Tundra AC (by: Tundradrenalin)
Superlift TruSpeed Speedo Recalibrator, DIY Install 2000 Tundra AC (by: cajuntundra)
RAAMmatt Sound Deadener, DIY Install (by: dibble9012)
Brake Caliper, DIY Upgrade (by: MEvang)
Scangauge II, Install Guide
807096 Billet grille instructions.pdf
OEM Keyless Entry RS3000 Install Tundra00-.pdf
OEM Keyless RS3200 Programming Guide.pdf
Window Trim/Exterior Molding Replacement, DIY Install (by: MOREPOWER)
Wheel & Tires Other Useful Knowledge
If you have a DIY thread you would like to add, send a moderator a PM with:
the thread title
a link to the thread
the originator of the DIY
And we'll add it to the list. Also, if you stumble on any dead links, report them!
Thank you for your ongoing support!
Reason: Adding more stuff!
04-29-2008, 09:37 AM
10
TSB online (Technical Service Bulletins)
I've found a nice way to get all your TSBs online, the best way,
FREE .
This is for any vehicle year, make, model. Not just Toyota. Here's how:
1. First go here:
http://www.aboutautomobile.com/tsb
2. Scroll to the bottom of the page.
3. Find your vehicle year.
click it
4. Next find your vehicle make/model.
click it
(optional steps)
5. Copy/paste the NHTSA No.
6. Go to this website:
http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
7. Paste the NHTSA No. into the blank that says NHTSA Item Number.
search
You'll get a brief description from NHTSA, it'll help you in your searching, not so much repairing. I hope this helps!
Regards,
Tundradrenalin
My Truck: 2005 Tundra , 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP. Suspension & Tires: 285/75-16 BFG T/A'ko , Fabtech Coils, 1.5" Wheeler's blocks , Toytec Diff Drop , 1.25" Spidertrax [front] , 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links , Wheeler's Anti-Sway Kit , Hellwig 7700 Swaybar , Timbren Rear SES
Electrical: URD MAF Sensor Calibrator , Superlift Truspeed Speed Sensor Re-Calibrator , ScangaugeII , Full LED Conversion
Stereo: Alpine CDA-9886 , Alpine & Phoenix Gold amps, Q-Logic box w/RF subs , eDead
Cosmetic: Line-X Bedliner , Custom N-Fab Steps , Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve , Debadged (partially ), Bell Truck Trunk, Access Vanish Tonneau
B e an organ & tissue donor, register at Donate Life
04-29-2008, 05:12 PM
Dealer :
Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 05:26 PM
17
Re: TSB online (Technical Service Bulletins)
A Technical Service Bulletin (TSB) is a communication between Toyota and its dealerships that can serve as an update to Toyota publications, describe parts updates, or relay enhanced or new service procedures. Service procedures may explain diagnostic steps, implementation of recommended updates, or how to perform certain repairs.
Repairs that are outlined in a TSB are usually only performed when a customer reports a specific problem with their vehicle and the TSB identifies a fix/solution to that specific problem. Warranty repair is covered under the applicable Toyota Warranty if in effect.
~Glenn
09-09-2008, 10:45 PM
10
Re: DIY (Do-It-Yourself) & User Knowledgebase
Great site for FREE DIY Info dedicated to Toyota, Lexus and Scion. Includes detailed part numbers for reference!
http://www.toyodiy.com/
Just type in your VIN!!
The Fine Print:
This section provides detailed part number information, which can be helpful when ordering parts from your dealer, and to determine the total cost of your repairs. This is not an online store; the prices are approximate retail prices, and provided for reference purposes only. You cannot order parts from this site. Important! The part numbers are gathered from various sources and are not an exact copy of the electronic parts catalog. All part numbers and diagrams are provided for information purposes only, in accordance with the “fair use” laws. The data provided is not guaranteed to be accurate; you should always confirm the information with your dealer.
Linear Mode
