KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Head light lens covers", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 02-21-2008, 09:09 PM
Dealer : Beaman Toyota Co.
rottun's Photo Albums
Last Online: 03-28-2008 09:49 PM
rottun is on a distinguished road.
Default Head light lens covers
My head light covers are no longer clear. I got a quote for $200 to replace each one. Is there anything else I can do to clear them without buying new ones?
Old 02-21-2008, 10:45 PM
Dealer : Salinas Toyota
hangpilot's Photo Albums
Last Online: 08-17-2008 12:51 AM
hangpilot is on a distinguished road.
Default Re: Head light lens covers
Have you tried polishing them. If you do not have the proper supplies/tools try tooth paste on a rag. I saw that on a car show somehwere. It may not make them look new but may help.
Old 02-21-2008, 11:15 PM
Invid's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
Invid's Photo Albums
Last Online: 07-07-2008 02:49 PM
Invid is on a distinguished road.
You can buy new ones on ebay for $65 each. Pep Boys sells a reconditioning kit that attaches to your power drill to polish scratches and dullness away for about $20.
Spintech 3332XL Muffler | Hellwig Rear Anti-Sway Bar | Updated 2005 Tail Lights | Updated 2003 Alloy Wheels | AMSOIL OAF-15 Oil Filter | Ultra-Strong Oil Filter Magnet | Synthetic Fluids all around | Line-X Bedliner | Osram Silverstars | Michelin LTX M/S tires | Custom Grille w/updated Body Panels | De-Badged | Optima Spiral Cell Gel Battery
Old 02-22-2008, 07:30 AM
benbeaux's Avatar
Dealer : Toyota of Richardson
2006 Toyota Avalon Desert Sand Mica,
2006 Toyota Tundra Desert Sand Mica DC
benbeaux's Photo Albums
Last Online: 08-14-2008 06:39 AM
benbeaux is on a distinguished road.
Kit#1 from here: Plastic Headlight Restoration Sandpaper from walmart auto section by the paint supplies, car parts stores or car paint supply shops. Definately use auto products, the other stuff is lower quality & may very well thrash your parts.
Mask off the area around the lights. Wet sand with 600 grit left to right until the lens is smooth. Wet sand with 1000 grit up & down. Wet sand with 1500 grit left to right. Alternating the directions helps you see what you've missed & just does a better job. For the wet part, I use a few drops of car soap in a quart squirt bottle of water. Keep it drenched while sanding. This floats away the debris & gives much better results.
When sanding is done, wash & dry the area to insure all sanding debris is gone. Polish with Plastx using the backing plate, pad & a drill. You can do it by hand, but it'll wear you out. It may take several apps of the Plastx to get the results you want.
This is the method I used on my Cousin's Camry & it worked great.
If your lights are heavily pitted, you'll need to start with courser sandpaper. 300 or 400 should work.
Here's some pics & slightly different method:
VWvortex Forums: DIY: Polishing PLASTIC...like headlights and tailights!
Old 02-22-2008, 08:08 AM
Dealer : Earnhardt Toyota
2006 Toyota Tundra,
2006 Lexus IS350
AZ IS350's Photo Albums
Last Online: Today 09:00 AM
AZ IS350 is on a distinguished road.
Meguiars Plast-X works well on cloudy headlights. It's much cheaper than buying replacement headlights and much easier than sanding/refinishing. It doesn't last forever, so you'll have to re-apply it periodically. It's around $8-9 a tube at sprawl-mart and a tube will last for quite a while.
Old 02-22-2008, 04:19 PM
KDTundra's Avatar
Dealer : Riley Toyota
2001 Toyota Tundra,
1999 Toyota 4Runner,
2001 Toyota RAV4
KDTundra's Photo Albums
Last Online: 07-23-2008 11:01 PM
KDTundra is on a distinguished road.
I had the stupidity to use a dish washing scrubby to remove bug gunk and scratched the hell out of my lenscovers. You live and learn!!
I ordered some plastic polish from Griot's (item #11186 @ ~$10.00) and polished each lens 5 times and it's almost like new.
Good Luck
Kev
2001 Tundra Access Cab, SR-5, 4X4, TRD Off Road Pkg., 4.7 L, Stellar Blue w/ ARE "Z" Series camper shell. Flowmaster Cat Back Exhaust System #17425.
1999 4Runner SR-5, 4X4 w/ "Highlander" Sports Package, 3.4 L, Imperal Jade.
2001 RAV 4 L, 2x4, 2.0 L, Black w/ silver trim
Old 02-22-2008, 05:54 PM
Dealer : Hoover Toyota Scion
2002 Toyota Tundra,
- Other - 66 chevelle zz430
bamafire's Photo Albums
Last Online: 08-15-2008 07:31 PM
bamafire is on a distinguished road.
I second the plast x. I bought replacement headlights for mine, but that was before I tried the plast x on the wife's Maxima. The stuff works!
Old 02-22-2008, 08:00 PM
T100_2_TUNDRA's Avatar
Dealer : Checkered Flag Toyota
2005 Toyota Tundra
T100_2_TUNDRA's Photo Albums
Last Online: Yesterday 08:06 PM
T100_2_TUNDRA is on a distinguished road.
The clear hard coat from the factory that is applied to the lens is what clouds up. It's there to help with strikes from road debris but over time it seems like it clouds up with exposure to UV. Polishing it down just removes it so its clear again, but the lens is more susceptible to damage. Pick your poison, clear and more chips or cloudy. I probably would go with clear, and take my chances on the chips.
Old 02-22-2008, 08:01 PM
Tundrav8yamaha's Avatar
Tundra Headquarters.com
Dealer : Mike Calvert Toyota Scion
- Other - yamaha,
2000 Toyota Tundra (totalled),
2008 Toyota Highlander HV Limited i4wd,
2004 Toyota Tundra Trd Off road Navi
Tundrav8yamaha's Photo Albums
Tundrav8yamaha will become famous soon enough.
Send a message via AIM to Tundrav8yamaha Send a message via Yahoo to Tundrav8yamaha
i have covers on mine. Headlights New are $90 per side. Also try Auto Zone I resurfaced my Dads Older 99 Avalon with 1000 grit to 1500 gritt to 2000 to 2500 grit and then Plastic polish and it looked like brand new.
Sig gone so long
Old 02-22-2008, 08:04 PM
Dealer : Toyota of Vineland
TundraXX's Photo Albums
Last Online: 07-26-2008 10:00 AM
TundraXX is on a distinguished road.
My Dad just did the lenses on his 00 Maxima with plain old polishing compound and they look great. I'm going to try it on my wife's Pathfinder...
(if it works then I'll do my Tundra)
Old 02-23-2008, 10:19 AM
Dealer : Bert Allen Toyota
2003 Toyota Tundra
Justin727's Photo Albums
Last Online: Yesterday 05:20 PM
Justin727 is on a distinguished road.
Send a message via AIM to Justin727
Not trying to go a little off topic here but do the 05-06 AC head lights fit in the 00-04 aside from the fact that is has a spare little orange light in it?
1988 PT67 Toyota Supra-far from stock toy
2003 Tundra- stock "Family" truck
1998 Ford Explorer AWD- Gone Miss it
MmMmM Boosted
Old 02-23-2008, 10:34 AM
Greenie's Avatar
Greenie's Photo Albums
Last Online: Today 03:05 PM
Greenie will become famous soon enough.
Where did you purchase your covers, online, locally or catalog? Do they affect light output?
I noticed an AVS logo in the corner. Is that the preferred brand?
Old 02-23-2008, 11:32 AM
atbspinner's Avatar
Dealer : Toyota of Greenville
atbspinner's Photo Albums
Last Online: 04-07-2008 12:42 PM
atbspinner is on a distinguished road.
You can also use the clear adhesive film to protect from chips. I bought some off ebay for $2.25 per linear foot. You just have to cut it to fit but it is a cheap way to protect the lenses. Look here: eBay Store - Clear Bra: Precut Window Tint, Computer Cut Tint, Bumper Protection
Old 02-23-2008, 02:11 PM
- Other - yamaha,
I received them from performance products.com cost was fourty five dollars .this doesn't effect light can't tell there on.I like them so far.
Sig gone so long
Old 02-24-2008, 01:49 PM
BAD BONEZ BJ's Avatar
Click Username, View Profile
Dealer : Priority Toyota
1993 Toyota Truck,
2006 Toyota Sienna XLE in Pear White,
2003 Toyota Tundra AC Limited 4WD,
1998 Toyota 4Runner Trade-In,
2004 Toyota Sienna Trade-In,
2004 Toyota Prius Trade-In,
2006 Toyota Highlander HV Trade-In,
1998 Toyota Celica Sold,
- Other - '81 Tercel - Sold
My eBay BAD BONEZ BJ's Photo Albums
Last Online: Today 08:11 PM
BAD BONEZ BJ is on a distinguished road.
Send a message via AIM to BAD BONEZ BJ
Hey, thanks! I didn't realize they also came as clear, just saw the smoke ones and know they are illegal here.
Back to the subject - I picked up a Headlight Repair Kit at my local Walmart, cheap. Worked great, three foil packs, if I remember right. Followed instructions, cleaned, polished, and sealed.
My problem was hazing on the inside of aftermarket blackout replacement headlights bought off ebay. Couldn't fix them and they failed my state inspection, so I went back to the stock headlights. Check photo album for pic of lights before they went bad.
2003 Tundra Access Cab Limited 4WD w/ all factory packages, Black-debadged. was stock 31K on 5/9/05, now 55K
Click USERNAME, View Public Profile!
Performance:
* UNICHIP module * AEM Brute Force Intake * AEM DryFlow Filter * K&N DryCharger * AirRaid TBS * JBA Titanium-Ceramic Headers * JBA Y-Pipe * Gibson CAT-Back Dual Extreme Exhaust * PulseStar Pulse Plugs * Fitch Fuel Catalyst System * Optima D35 Yellow Top * Argus Battery Bug * Fumoto F103N Oil Drain Valve *
Exterior:
* Extang Full-Tilt Tonneau * Loading Zone Cargo Divider * Topline Tailgate Step * Mr. Gille Upper & Lower Billet Grille * WAAG Bumper Guards, front & rear * HT Side Step Nerf Bars * AVS Hood Protector * WeatherTech Vent Shades * JDM Black Taillights * TurnSmart Solar-power Mirror Turn-Signals * Altec 48" Line-of-Fire LED Light Kit * Altec 53" Screamer Amber Side Marker LED * PIAA Backup/Work Lights * 35 % Tinting * Bully LED Third Brake/Cargo Light *
Interior:
* Gentex Auto Dimming Compass/Temp Rear View * Garmin's Nuvi 660 GPS * Scan Guage II * Passport SR7 Radar/laser shifter * Passport G-Timer GT2 * P.I.E. Adapter
Wheels/Tires:
* Moto Metal M0951 Gloss Black 17 in. Alloys * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
* Bilstein HD Shocks, F&R * Hellwig Rear Sway Bar & Helper Springs * TCS Poly Steering Rack Bushings * Wheeler's Front Sway Bar Bushings * Timbren SES Kit, Front & Rear * SpiderTrax 1.25" Wheel Spacers *
Brakes:
* TRD Big Brake Kit (front) *
BAD BONEZ BJ
Questions? Please use the Contact Us link. Dealer Hunter JPV Photography Consumer Electronics Hunter
