I've seen several after market wheel sets for sale with the claim that they will fit Chevy or Toyota. Is this true or is there a big "BUT" or "IF" somewhere I should know about? Thanks.
They have the same lug pattern, so they could possibly fit. You still have to make sure due to brake calipers and the offsett of the rims, backspacing, etc..
Main difference is center bore size. Toyota's need a larger center bore, many Chevy rims won't fit a Toyota for the simple reason the center bore on the wheel is too small.
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Camburg Uniballs with adjustable Bilsteins, Carson AAL, red/blue Bilsteins in rear, 265/75 Yokohama A/T, IS kit(minus bumper) and rims(hand polished), Billet Wing Window Latch Upgrade, TC Steering Bushings, RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. Stebel 300Hz Air Horn.
202k miles and counting......
2011 Honda Pilot EX-L, black with gray interior.
in a word... no
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
toyotas fit on chevys, but not all chevys fit toyotas
Center bore does not matter if the rims are lug centric...I've run Toyota bore and Dana bore, the Ivan Stewart rims are a different bore than the OEM alloys IIRC, and so on...since our trucks use ADD, and a FWD style hub, there's nothing sticking out of the upright that a wheel needs to clear except the centering cone and that will depend on what wheel you're using. Same in the rear...if it's lug centric, it doesn't matter as long as the pattern is correct.
As long as the pattern is 6 on 5.5" (or metric measurement 6 on 139.7), AND the valley between the mating surface and shell is deep enough to clear our calipers (roughly 3/4"), it will fit. Which OEM it was made for does not matter.
Most stamped steel rims DON'T fit because the center isn't dished enough to clear the caliper, but most aluminum rims DO fit. If you get lug-centric you don't have to deal with the centering cone, frankly it's a lot easier than the hub-centric OEM setup.
I have been using rims which are "technically" for Chevy bolt pattern for the last...oh...seven years, and recently got another set with the same spec. Ya don't think Toyota planned it that way, do ya?
-Sean
GFX by FreedomEagle50
Manual Hubs
OB's cup size: 36DD
"some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
As an example, I have a set of BOSS eagle alloys 18" with toyo proxes 285/60R-18 tires.
Knowing that the bolt pattern was the same, I put one of the BOSS wheels on just to see if it cleared hub opening, fit over brakes etc... Well it did appear to fit. But to be sure I took to a Belle tire dealer and had them fit them. I was right. They will fit. So until you can "try on" a set of wheels, don't rule them out.
IN2BA8
My buddies 38" swampers from his panel Wagoneer fit my Tundra and mine fit his. Except for the fact I cannot turn his wheel/tire on my truck, the shoe fits though![]()
New to the forum? CLICK HERE!
Questions about advertising? CLICK HERE!
Know the facts about Warranties and the Magnuson-Moss Act.
my Tundra mods list (click)
"in a word... no"
Shallow water in Florida maybe?
If they're MT Classic II's they should fit. Most people here get their 16x8's in a "Chevy" backspacing,it fills the wheelwells better than the backspacing MT recommends for Tundras.
My roomate bought my old MTs,he has a 90s Chevy pickup![]()
2000 Imperial Jade Mica Tundra SR5 V8 4WD - sold to my dad
2002 Thundercloud Sport Edition 4Runner - my "new" Toyota truck
the bolt patterent is the same, ALL toyota wheels will fit on a chevy, BUT not all chevy wheels will fit on a toyota, if they are hub centric to a chevy they wont fit a toyota, basically you have to try the wheel on,
IF THE WHEEL SAYS "BOLT PATTEREN, 6X5.5 AND ITS HUBCENTRIC IT WILL NOT FIT, ITS DESIGNED FOR A CHEVY, GET THE ONE THAT ISNT HUBCENTRIC
