P1120 Accelerator Pedal Position Sensor Circuit Malfunction
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: P1120 Accelerator Pedal Position Sensor Circuit Malfunction
  1. #1
    Supporter Hispeed's Avatar
    Join Date
    Feb 2002
    Location
    Chandler,AZ
    Posts
    332
    Liked
    7 times
    Images
    32
    Rep Power
    75
    Default P1120 Accelerator Pedal Position Sensor Circuit Malfunction
    Good morning guys.
    I had to drive up to my sister's funeral this week (1000 mi trip), The truck performed flawlessly (as usual).
    This morning, I go out to get coffee and after two blocks, the engine refuses to respond to the gas pedal & throws a CEL (P1120 Accelerator Pedal Position Sensor Circuit Malfunction).
    I shut down,let it sit for a few minutes, restarted, and as others have reported, the truck worked normally again.
    Here's the question: Is this a module that I can replace, or should I bite the bullet & take it to the the shop? I have a 1000mi.drive home & I need to resolve this soon.
    Thanks,
    Hispeed
    '00 Thunder Gray Ltd 4wd TRD Oak Leather Interior
    Roll & Lock Tonneau
    All LED's Inside and Out
    '05 DC center console installed
    Map Light Mod
    Pwr Outlet Mod
    Ignition Chime Override Mod
    Arm Rest Mod
    Dual Magellan GPS's
    ScanGauge II
    Hurricanes Ivan and Dennis Survivor
    Bill and Scooter say: "Tundras' Rock!"
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Azgoldrat's Avatar
    Join Date
    Feb 2005
    Location
    Phoenix
    Posts
    95
    Liked
    2 times
    Rep Power
    11
    Default Re: P1120 Accelerator Pedal Position Sensor Circuit Malfunction
    Do a search for TLA or Throttle lever Assembly. I have posted on this before.
    3 #3 screws and and a 10mm to remove the engine cover and airbox clamps.About 20 mins total time.
    The part # I posted is for the 2000 and about 250 bucks it is a large Rheostat that the throttle cable attaches to on the pass side front of the throttle body.
    The dealer will try t sell you the whole manifold assembly for about $1400
    Ignoring it will put you in a Holy bat farts bat man situation.......But may not do it again for awhile. Your roll of the dice.
    Az
  4. #3
    Join Date
    Jul 2006
    Location
    Memphis, TN
    Posts
    202
    Liked
    3 times
    Rep Power
    9
    before you decide to change anything clean throttle body first. you can get throttle body clean from autopart.
  5. #4
    Junior Member slowyota's Avatar
    Join Date
    Aug 2002
    Location
    Utah
    Age
    33
    Posts
    306
    Liked
    25 times
    Rep Power
    127
    I'd bite the bullet. That exact unit just failed in my '00 and it took me 10 minutes to change out. Fixed my problem, and haven't had a CEL since (replaced on Wed.) Cost for the assembly was like $280.00.
    Sounds like it's a faulty part from Toyota...because a lot of people are starting to have this problem...
  6. #5
    Join Date
    Feb 2002
    Location
    Chandler,AZ
    Posts
    332
    Liked
    7 times
    Images
    32
    Rep Power
    75
    Thread Starter
    I bit the bullet.
    Like I said, I'm a thousand miles from home for a funeral so I let the local dealer do it.
    $280 for the part, 1 hr labor (@ $105 hr ) for the diagnostic and another hr for the installation. You would think they would at least give you a break on the diagnostic.
    Oh well, as trouble free as this truck has been for the past eight years, it's a pretty small price to pay overall.
    BTW, the throttle body was clean enough to eat off.
    Thanks for all your advice.
    Roll & Lock Tonneau
    Map Light Mod
    Pwr Outlet Mod
    Arm Rest Mod
    Dual Magellan GPS's
    ScanGauge II
  7. #6
    Join Date
    Jan 2008
    Location
    Micanopy Florid
    Age
    56
    Posts
    576
    Liked
    0 times
    Rep Power
    16
    Happy to hear you got it fixed. Have a safe drive home and GB.
  8. #7
    Join Date
    Dec 2010
    Location
    Rockwall, Texas
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by slowyota View Post
    Could you please give me the part number, a detailed description, etc. so I can purchase the part for my 2002 Tundra which has a CEL P1120. Also, do you have any pictures of where it is located?
    Thanks
  9. #8
    Veteran Member CoachRon's Avatar
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    24
    Posts
    566
    Liked
    67 times
    Images
    26
    Rep Power
    6591
    Quote Originally Posted by tariqansari View Post
    My dad's 2002 (V8) has been acting up lately and he's also getting the P1120 code. I've searched and searched and I keep getting mixed answers. Is the P1120 code for the Throttle Position Sensor or the Accelerator Pedal Position Sensor?? Also, I know where the TPS is, but where is the APPS? Is it where the throttle cable connects to the throttle body on the passenger side??
    2000 Tundra SR5 2WD... Camburg UCAs, Camburg 2.5" coil-overs, Deaver 10-packs, Bilstein 5100s, Moog LBJs, BFG A/T 285/75/16s, TRD bead-lock wheels, K&N air filter, 18" MagnaFlow muffler, clear corners, Sylvania fog/headlights, full LED conversion, Kenwood head unit & 6-3/4" 3-way speakers, Sound Ordnance B-8PT 8" subwoofer, Coverking neoprene seat covers... so far...
  10. #9
    Join Date
    Dec 2010
    Location
    Holiday Island, Ar.
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    part #22060-50011. APPS sensor. Got mine online for $223.00 plus $13.76 shipping. www.kalamzootoyota>com My tundra is a 2000. Should not make a difference. V8-2w drive.
  11. #10
    Join Date
    Dec 2010
    Location
    Holiday Island, Ar.
    Posts
    2
    Liked
    0 times
    Rep Power
    0
  12. #11
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,326
    Liked
    3115 times
    Images
    47
    Rep Power
    162921
    The APPS (accelerator pedal position sensor) is on the passenger side of the throttle body, houses the coiled return spring for the throttle plate, has an electrical connector, mounts with three screws, and is the terminus of the accelerator pedal cable at the throttle. It is installed by placing it about 20 degrees left of its final position and rotating it clockwise until it touches the throttle valve shaft, tightening the screws, and reconnecting the throttle cable. Here is an pic of the actual component:
    The TP (throttle position) sensor is on the driver side of the throttle body, also has an electrical connector, and is mounted with two screws and a hold-down clip. It is installed by placing it about 15 degrees to the right of its final installed position and rotated counter-clockwise until it touches the throttle shaft, then loosely tightened. Then, you need a scanner (maybe the scanguage can readout the data...) to set it to between 14.4-16% of throttle valve opening percentage. Here is a pic of the component:
    The Chilton manual has excellent sections (with pics) on removing/replacing these components. If you can unscrew a screw and follow simple directions, this is a 15 minute job.
    I do suggest, however, before replacing either of these components, a thoroughly cleaning of the throttle body and, just as importantly, cleaning the electrical connectors and reseating them with a good coating of dielectric grease. I'd guess that failures of these components are largely tied to external fouling, both at the connector as well as via the throttle plate, rather than an internal failure of the component itself.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  13. #12
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    24
    Posts
    566
    Liked
    67 times
    Images
    26
    Rep Power
    6591
    Thanks for the information! Now... the P1120 code... which one is that for? Or do you have to test both of them?
  14. #13
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,326
    Liked
    3115 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by CoachRon View Post
    P1120 = The ECU is registering a fault with the APPS (which I think is a range-of-motion problem), usually caused by fouling somewhere on or around the throttle plate.
  15. #14
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    24
    Posts
    566
    Liked
    67 times
    Images
    26
    Rep Power
    6591
    Dang, that's an expensive part to replace. I'm glad it's not my truck! I'm gonna see about cleaning all around the throttle body this weekend when we replace his starter. Do you think cleaning would help, or would you eliminate the risk of it failing and just replace it?
  16. #15
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,326
    Liked
    3115 times
    Images
    47
    Rep Power
    162921
    I would do a thorough throttle body cleaning first. Pay particular attention to the edges and pivot shaft areas on the throttle plate. Then I would pull both connectors and gently scrub them out with WD-40, a toothbrush, and a light blast of MAF cleaner, lightly pack them with dielectric grease, and reconnect.
    If the problems persist, then I would remove each component, clean and lube the throttle plate attachment arms, lube the protruding throttle plate shaft, and reinstall.
    If that doesn't do it, then replacement is the right call.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
