Old 04-04-2008, 09:44 AM
Dgerre1's Avatar
Dealer : Bohn Brothers Toyota
2004 Toyota Tundra
Last Online: 03-20-2009 04:37 PM
Dgerre1 is on a distinguished road.
Dgerre1's Photo Albums
Default Spacer Question
I know people usually don't speak well of spacers, but what is the smalest spacer possible? All I need is 1/2" really to stop a very slight bit of rubbing on the UCA (it doesn't touch when static, has about 1/2" on clearence) It rubs a small bit during driving, not much at all. ANNNNYYWAY I want to know who has had good experience with spacers and what I should get? Remember I want the smallest spacer possible so that I don't make a huge change.
Also, this may sound dumb, but do the spacers go on all 4 tires? If it's such a small change maybe I only need them on the front??
Old 04-04-2008, 12:18 PM
integraGSR's Avatar
2005 Toyota Tundra
Last Online: 11-06-2009 11:58 PM
Images: 14
integraGSR will become famous soon enough.
Send a message via AIM to integraGSR integraGSR's Photo Albums My eBay
Default Re: Spacer Question
yes, they do have just a 1/2" spacer. lets say you get the toyotec 3", it comes with a 2.5" in coil spacer and another .5" lift that goes over the top of the coil assembly.
here is an example. http://www.toyteclifts.com/images/pr...4topspacer.png
it's 59.99 from toyotec, Tundra Shopping Cart for Toyteclfts.com, and you will need to remove the strut support and replace the studs with newer, supplied, longer studs. scroll down to the "top plate spacers/stud"
you can probably get away with just installing them for the fronts, as the rear will need something different, an add a leaf or lift shackles.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
Old 04-04-2008, 12:21 PM
Salty_Dog's Avatar
Moderator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 05:12 PM
Images: 577
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
You can buy 1/2 inch spacers but if you go that route, you should upgrade the wheel studs to something 1/2 inch longer also.
Salty Dog
JDM is the new Rice
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 04-04-2008, 12:24 PM
Fissile's Avatar
Dealer : Star Toyota
2003 Toyota Tundra
Last Online: 08-18-2009 10:05 AM
Images: 3
Fissile will become famous soon enough.
Fissile's Photo Albums
I believe he's asking about wheel spacers, not coil spacers. I don't know much about them but I imagine you won't find one thats thinner than the lugs on the wheel or else it wouldn't fit at all.
Edit: I'm thinking of adapters, and typing slow; Cyberbilly's got it.
Old 04-04-2008, 12:38 PM
Dgerre1's Avatar
2004 Toyota Tundra
Yes I am talking about wheel spacers. I spoke to the guy at wheeladapter.com He is a little pricey but he says that they are 100% safe and have no adverse affects on your drive (vibrating, etc). Has anyone used his? Or any spacers...I only need to move them out a very small ammount, but it looks like I am going to need to use an 1" spacer.
If anyone has them or any other type of spacer, let me know what you use and how they have worked.
Old 04-04-2008, 03:07 PM
integraGSR's Avatar
2005 Toyota Tundra
Images: 14
whoops! anyhow, i myself have some wheel adapter also. i have a 1.5", bought them from a member here for 40(!!) bucks. they are from marlin crawler, Marlin Crawler : Heavy Duty Axle Parts and Accessories (scroll down to the "Toyota 6-Lug Wheel Spacers"). so far i have not had any problems with them at all. no vibration whatsoever. i'm sure that fred from wheeladapter.com has quality stuff, but for 300 bucks, i chose to buy some decent ones and not the most expensive, although like i said, they are probably a better fit. as for the ones that i have, you HAVE to make sure that you center the rim before you tighten them down, or you WILL have vibration problems. but you can tell if it does not go on right anyways.
01 Honda Civic
95 Acura Integra
Old 04-05-2008, 08:42 AM
Salty_Dog's Avatar
Moderator
2001 Toyota Tundra,
2002 Toyota Corolla
Images: 577
I've had a set of his adapters for over a year with no problems at all. Yeah, he's a little expensive (OK, quite a bit expensive) but remember that these are holding your wheels and tires to your truck, and if one were to have a problem, it could speel catastrophic failure.
Would you feel safer with a set of ebay specials or a set custom made by a guy who builds race cars for a living?
Salty Dog
JDM is the new Rice
Old 04-05-2008, 11:35 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 07:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
get em while they are still in stock!
Spidertrax back in stock!
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
