I am so glad I stumbled across this post. I just ordered the parts ($55 total with shipping) and they should be here by the end of the week! I can hardly wait.
UPDATE:.......just put the molding on. Took five minutes.
I do not recommend the use of a screwdriver to pry the molding up. We all know how thin the Toyota paint is and the screwdriver gave me a reminder. Just grab the molding with your hands (or a pair of pliers) and give it a good pull.
It also seems that when you install it you also have to make sure that you start by pushing the molding a little bit (1/4 inch) under the front side window trim molding for it to line up correctly at both ends. See the arrow in the pic.
Looks 1000 times better with the new molding!!!!
Now just finish it off with some 303 and you are good to go for a while!
