Old 04-16-2008, 12:07 PM
Dealer : Bill Penney Toyota
Last Online: 01-30-2010 06:23 PM
papalou56 is on a distinguished road.
papalou56's Photo Albums
Default burned out dash bulbs
Thanks to info on T/S I've replaced the "drive" bulb in the dash. 15 minutes out and back in. Now I need to replace the bulbs behind the AC/Heater knobs. How do you get to those? I think the outside bezel is just supposed to snap off but I'm afraid I'll scratch something . I've got a 2000 Tundra EXCAB.
Thanks for any help I get. Papalou
Old 04-16-2008, 12:43 PM
alottolearn's Avatar
2008 Toyota Tundra,
2010 Toyota Tundra SR5/TRD CM P.Mica
Last Online: Today 04:15 AM
alottolearn is a splendid one to behold. alottolearn is a splendid one to behold. alottolearn is a splendid one to behold.
alottolearn's Photo Albums
Default Re: burned out dash bulbs
an excellent step by step found here:
Dash LED Swap - Goodbye Amber... - Toyota Tundra Forum
2010 Tundra Crewmax SR5 TRD 5.7l 4x4
(Pyrite Mica) Color Keyed Door Handles Line-x bed liner Kenwood DNX8120 head unit Truxedo Lo Pro QT Box Cover Heated Seats
December 22, 2009
2008 Tundra Crewmax SR5 5.7L 4x4 (Black)
Pro Compustar 2-way 900MHz remote start Black Headlight Mod Line-X bedliner Kenwood DNX8120 Head Unit
Homelink Rearview Mirror OEM back up camera
Fully De-badged Color-Matched Grille Surround Truxedo Lo Pro QT Box Cover Sequoia Door Handles (w/BMW style orange LEDs)
New Short Block (June 2009)
Old 04-17-2008, 03:30 AM
Dealer : Power Toyota Irvine
Last Online: 01-26-2010 04:41 PM
Acolytes is on a distinguished road.
Acolytes's Photo Albums
The ac/heater knobs are even easier. Pull off all three knobs and you'll see 2 screws. undo those, then push the top of your vents in at the top (vents on the side of your radio) and it will expose 2 more screws. undo those. Get a little flat head pocket screw drive and pop off the cluster and you're there.
Old 04-17-2008, 12:35 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Yesterday 10:29 PM
Images: 215
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Exactly what he said. Except the last step, no need for a screwdriver. You can just wiggle it back and forth just slightly. It'll loosen up enough so you can pry it off with your fingertips. Very simple, you won't break anything.
After that, the climate control panel is right there. Remove the wire harness and have at it.
New to the forum? CLICK HERE!
Questions about advertising? please send an email to sales@autoguide.com
My Tundra uses AMSOIL, everywhere.
Old 04-17-2008, 09:52 PM
Tundraman10's Avatar
Dealer : Toyota Of Boardman
2000 Toyota Tundra,
- Other - 1999 Chrysler 300M
Last Online: 03-08-2010 08:35 PM
Images: 454
Tundraman10 will become famous soon enough.
Tundraman10's Photo Albums
My drive light has died on me 2 times. The 1 time the dealer charged me $150 just to install the bulb. About 6 months later, the bulb died again. I said the heck with it. I'll leave it as it is. My luck disassembling the guage cluster will result in me having to spend a crap load of money tryting to fix my stupid mistake.
2000 Toyota Tundra SR5 Access Cab 4x4 Black
www.cardomain.com/id/tundraman10
http://www.tundrasolutions.com/galle...&cutoffdate=-1
Just call me Chris
Old 04-17-2008, 10:12 PM
Images: 215
you can do this man. it is not hard. just takes a small amount of patience.
Old 04-18-2008, 08:44 AM
Hispeed's Avatar
Dealer : Big Two Toyota & Scion of Chandler
Last Online: Today 08:14 AM
Images: 31
Hispeed is on a distinguished road.
Hispeed's Photo Albums
Once you've done it, you'll kick yourself for paying someone else $150.
All it takes is a 10mm, a phillips head, a LED replacement bulb, and about 15 minutes total.
'00 Thunder Gray Ltd 4wd TRD Oak Leather Interior
Roll & Lock Tonneau
All LED's Inside and Out
'05 DC center console installed
Map Light Mod
Pwr Outlet Mod
Ignition Chime Override Mod
Arm Rest Mod
Dual Magellan GPS's
ScanGauge II
Hurricanes Ivan and Dennis Survivor
Bill and Scooter say: "Tundras' Rock!"
Old 04-18-2008, 08:13 PM
Cian's Avatar
Dealer : Elmhurst Toyota
Last Online: Yesterday 12:36 AM
Images: 25
Cian will become famous soon enough.
Cian's Photo Albums
I'm gonna have to do this too. Also, from what others recommended if you're gonna replace 1 you may as well do all the ones behind the knobs. I'm gonna have to get behind there anyway to install a PA12.
2001 SR5 Access Cab 4.7V8 4x4
OEM: FJ Rims; bed-liner; alarm; running boards; all-weather mats; door sill protectors; 13WL brake caliper upgrade
TRD: color-keyed mirror covers, embroidered signature mats
OTHER: Bridgestone A/T Revos; NGK Iridium IX spark plugs; Skid Row front skid plate; Fumoto drain valve; Vibrant resonator; Magnaflow exhaust tip; Form-Fit deflector; Brembo rotors; Trfytoy window latches; Undercover tonneau; Wheelskins leather steering wheel cover
PENDING: TRD coils, Bilstein shocks; TRD Kazuma LSD; Hellwig sway bar
Old 04-18-2008, 08:15 PM
Cian's Avatar
Images: 25
Cian's Photo Albums
Btw, that link above is for the Gen 2.
Old 04-25-2008, 09:36 AM
First I want to thank boatbuilder who told and showed us how to get to the instrument cluster to change those lights. I also had to change the lights in the radio/ temp cluster. To get to those all you need is a phillips head screw driver. Push the air vents in at the top. There is a screw behind the top of each vent. Next pull the heater/AC knowbs and remover the screws behind each one. You will now be able to remove the assemblyand get to the bulbs. Have fun and save $90.00 in labor at the dealers.
Old 04-25-2008, 08:18 PM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: Yesterday 03:43 PM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
It's nice to say thank you. But no need to start a whole new thread.
Threads merged.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
