how can u tell if u have a 2003 tundra 2wd with lsd- limited slip rear differential?
does it say that on the original window page vehicle specs ? or where?
and what differential oil should i use in 2003 2wd tundra rear diff?
thanx in advace.
thanx in advace.
If you have original window sticker yes it should say it if not have dealer check the vin.For fluid spec refer to owners manual it should have with lsd and without lsd.
Independent dealer at AMSOIL. http://www.amsoil.com/index.aspx?zo=5072667
You can look on the rear diff. It will have a sticker that says LSD oil only. If you have that you know you do. It will be on the window sticker too.
At least they have circled the problem.
This has been posted before, but you could wait for a rainy day, hit the gas in a parking lot, break the rear end loose, if the rear end kicks out, you have an LSD. I have a blast in the snow flat-tracking around the snow covered streets with it.
TRD package= LSD. you have lsd. and ALL limiteds came with LSD. use a 75w synthetic oil and add a little bottle of LSD additive.
2006 Black Limited 4WD TRD Tundra
Present.
2004 Phantom Gray Limited TRD Tundra
RIP.
Read the original post. The man has a 2wd. By the way, my 4wd original window sticker lists LSD as a seperate option with a seperate price. It was not listed as a part of the off-road package.
Surely, there is a way to visually inspect a rear diff and determine it is LSD besides looking for some lame-*** decal. What to the techs do?
Any fool can fix it right with lots of money.
The cool thing to do is fix it right with the least amount of money.
bump (I'm interested in the surefire inspection method too)
Have the dealer run the Vin. or go out in the mud. try and get one wheel stuck in some really slick mud so it spins freely and give it some gas. you will know if you have LSD.
You will hear the slipping tire having the breaks applied to it and the tire with traction will get more power and you will be free.
When doing this make sure you have some to pull you out incase you get stuck.
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
I've had the dealership check mine out and they stated really not much on the Vin to really state or tell since Toyota hasn't broaden the search which i find odd. Limited slip will usually tell on the back of the diff. Go drive your truck in the rain and try to do a burn out if both back wheel spin you have Limited slip![]()
Jack the rear of the truck up and spin the tires by hand. If it has an LSD both tires will turn in the same direction. If they spin in opposite directions then it is and open differential.
I have a feeling that washed out sticker looking area is the sticker that reads "lsd oil only." My sticker is almost worn off too. This would only be true if non-lsd trucks had a sticker that read "non-lsd oil" or something like that. There are actually 2 stickers on mine, one towards the middle and the other towards the drivers side (left). The middle is the lsd sticker.
Also, I'm pretty sure there was a post where you could look up your vin and see if it is lsd or not. If not on here, google it, I promise I wasn't on LSD when I saw it...
2005 2wd Tundra V8 AC SR5. 6" RCD lift, 315/75r16 ProComp Xtreme All Terrains, 16x8 Mickey Thompson Classic II's, Flowmaster 50 w/ no resonator, K&N 77 CAI, RAPS, Qlogic Box with 2 RockFos 8"s
Bone stock Limited 2wd '99 4Runner
Just burn out and look at the marks.:der:
3" Spacer, 285/75/16 M/T's, Dick Cepek Wheels, 14" Magnaflow, Unbelievable Stereo, 5100s in the rear, ICON Coilovers, Cambrug UCA's, Total Caos Poly steering kit and swaybar kit, Rock/back up lights, TRD LSD, CV Boot Mod, 130w ProComp Lights on a self made lightbar.....
