This is a discussion thread titled "squeeky squeeky from front wheel", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 05-13-2008, 02:12 PM
Dealer : Price Leblanc Toyota
2004 Toyota Tundra
lmoreau's Photo Albums
Last Online: 11-11-2008 08:47 AM
lmoreau is on a distinguished road.
Default squeeky squeeky from front wheel
Anyone have an RPM-dependant squeekysqueeky sound that comes from the front of the truck? It does away instantly when the brakes are applied, or sometimes if I don't hear it and lightly tap the brakes, it will start...it's not the fan belt.....
Old 05-13-2008, 02:13 PM
imjin's Avatar
Defiant ut Terminus
Dealer : McGeorge Toyota
imjin's Photo Albums
Last Online: Yesterday 02:36 PM
imjin will become famous soon enough.
Default Re: squeeky squeeky from front wheel
I had a similar annoying squeak up front that I eventually tracked down to a heavy rubber shock bushing that had worn out on the Bilstein.
Mods: Mickey Thompson Classic II | Cornfed 2.5" Lift | Differential Drop Spacers | 930 Inner CV Boots | ProtechEZLift Limit Straps | Spintech Sportsman XL Muffler | Brembo Front Brake Rotors | A.R.E. Z-Series Cap w/ Thule Rack | Stubbs Rock Sliders | Hellwig Anti-Sway Bar | 285/75/16 BFG All Terrain TA KO's | VIAIR 400C Air Compressor w/ 2.5 gal tank | Front clear corner lamps | Odyssey PC1700T battery | Optima Red Top 75/35 battery (backup starter) | Hellroaring 95300A Isolator/Combiner | Truspeed Calibrator
Old 05-20-2008, 11:14 AM
bkelile's Avatar
Dealer : Boyle Toyota
2004 Toyota Tundra
bkelile's Photo Albums
Last Online: 05-20-2008 11:20 AM
bkelile is on a distinguished road.
I had a similar problem, at least by the way you described it, and it turned out to be a squeaky timing belt. I noticed the sound when releasing the gas and coasting, or if I was parked I would give it a little gas and once I released it, there was the sound. You might want to check it that way, and if it is that, there is a spray you can buy which will make it go away. Hope that helps.
Old 05-20-2008, 12:35 PM
Dealer : Kolosso Toyota
ra1nman's Photo Albums
Last Online: 09-11-2008 04:40 PM
ra1nman is on a distinguished road.
Funny that you mention that. I figured the same thing out on my truck this weekend when I was rocking it. Whenever I hit any bump even in my driveway it would chirp and squeak so much it sounded like a bird's nest was under my there and would drive me nutz. I shot some WD-40 down from the top of the shock and fixed it for about a week. For the longest time I though it was my ball joints drying up.
Old 05-20-2008, 12:37 PM
imjin's Avatar
Defiant ut Terminus
Mine got EXTREMELY noisy going over bumps whenever the shocks would be put to use. That's what prompted me to look at it. Ended up having to replace the shocks. LOL, I did the same WD40 trick too that lasted about a week.
Old 05-20-2008, 01:42 PM
Boosted27606's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2006 Toyota Tundra,
1998 Lexus GS300 Silver,
- Other - 93 MITSU Eclipse
My eBay Boosted27606's Photo Albums
Last Online: Yesterday 11:23 PM
Boosted27606 is on a distinguished road.
Send a message via MSN to Boosted27606 Send a message via Yahoo to Boosted27606
Timing belt ??? you sure about that ?
maybe the regular belt but I doubt you want to spary the timing belt with belt lube. If that belt makes noise, I suggest you replace it ASAP
Boosting happily ...
List of mods ( growing Daily ): L.E.D.s inside , Camper Shell with inside lights, Back up sensors and Camera , Subwoofer and Amp , Scangauge II , Hellwig Rear Bar , Billet Rear windows hinges, K&N Air Intake , Heated Seats, Tailgate assist bar, Westin Bull Bar and Skid Plate, Under hood lights, 1.25" Spidertrax spacers in Front, 1.50 " wheeladapter spacers in back, Ultimate window tint.
Old 05-20-2008, 03:23 PM
T100driver's Avatar
Dealer : Hoy-Fox Toyota
2002 Toyota Tundra
T100driver's Photo Albums
Last Online: 11-24-2008 02:33 PM
T100driver is on a distinguished road.
Did you check the brakes? I'm in the same situation I think I need new brakes.
Old 05-20-2008, 04:27 PM
Dealer : Larry H. Miller Toyota
slowyota's Photo Albums
Last Online: Yesterday 11:17 AM
slowyota is on a distinguished road.
I had the EXACT same problem. Turned out to be warped rotors. They had warped just enough that when the rotor rotated part of the rotor contact the brake pad and whala, squeeky squeek.
So bought new rotors and pads and it fixed the problem. I'm guessing your problem is the same since it goes away when you touch the brakes.
