This is a discussion thread titled "Turn Signal Problems", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 06-03-2008, 11:11 PM
Dealer : Frontier Toyota
jhill7's Photo Albums
Last Online: 06-18-2008 11:41 PM
jhill7 is on a distinguished road.
Default Turn Signal Problems
Re: 2001 Tundra. My turn signals seem to be activating hazard warning lights. At times the signals work properly but most of the time not. I thought it might be the TS/Hazard flasher but Toyota parts department didn't think so. Has anyone had this problem or know what the fix might be?
Old 06-04-2008, 10:17 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
LGL002's Photo Albums
Last Online: Today 04:10 PM
LGL002 is on a distinguished road.
Default Re: Turn Signal Problems
First thing I'd look at is in the front and rear lamp housing areas. Could be as simple as a poor connection between a bulb and the contacts in a lamp socket or a wiring connector near them. Usually crossover problems like that are from a poor ground or connection in those areas. Pain in the butt to check but it is the first place to look.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Old 06-04-2008, 10:58 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
UnSub's Photo Albums
Last Online: Today 03:38 PM
UnSub is on a distinguished road.
Larry
Larry has a good idea. If the problems is what he says, I think the flashing lights would be at less than full brightness. When the truck is on, the power to the lights is at the flasher at all times, waiting for the flasher to be grounded by the turn signal switch, either left or right, to pins 5 or 6 respectively on the flasher. If you don't find the problem looking at what Larry suggests, or if you are lazy like me, I would buy a flasher and see if it fixes the problem. If the flasher is expensive, I would do what Larry said first, because I am also thrifty (cheap).
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Nav system, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Line, 5.7 Killer
Old 06-08-2008, 02:13 PM
Thanks for the input. I've checked the turn signal lights as suggested but didn't find anything. The flasher unit is expensive ($53) and not returnable so I hate to buy it if it's not the problem. Thanks again for the suggestions.
Old 06-08-2008, 11:15 PM
UnSub's Avatar
$10 for one that fits your truck at Autozone.
Old 06-09-2008, 11:51 AM
Dealer : Toyota Scion South
gator2764's Photo Albums
Last Online: Today 11:45 AM
gator2764 is on a distinguished road.
OK, not exactly the same problem but I did have a problem with the turn signals staying on and it turned out to be the light hook up for the trailor. If you have the tow package try disconnecting the box that is mounted in the rear of the bed(underneath)
