Old 06-06-2008, 03:52 PM
Dealer : McGeorge Toyota
Last Online: 06-06-2008 03:52 PM
bchuck72 is on a distinguished road.
bchuck72's Photo Albums
Question Remote Programming
I just purchased a remote control to replace a lost one for a 2001 Tundra. The directions said I needed to press the programming button, which is located somewhere in the truck (under dash, seats, etc.). Does anyone know where this is and if that is what I really need to do?
Help!!!
Old 06-07-2008, 08:42 AM
Tundrav8yamaha's Avatar
Banned
Images: 100
Default Re: Remote Programming
Help!!!
nope there is a series of directions that range from opening and shutting the door and locking it and unlocking it...
Old 06-07-2008, 08:51 AM
knucklebusted's Avatar
Dealer : Gary Force Toyota
2003 Toyota Tundra
Last Online: 11-18-2009 07:35 PM
knucklebusted is on a distinguished road.
knucklebusted's Photo Albums
Not sure if the 2001 is anything like the 2003 but here's the instructions for that one:
TOY451
1. Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
2. Perform these steps within 5 seconds
1. Insert the key into the ignition (don’t turn it) Pull key out
2. Insert the key into the ignition (don’t turn it) Pull key out
3. Perform these steps within 40 seconds
1. Close, then open the drivers door.
2. Close, then open the drivers door.
3. Insert the key into the ignition (don’t turn it) and pull it out.
4. Perform these steps within 40 seconds
3. Insert the key into the ignition and leave in the ignition.
4. Close the drivers door
5. Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
6. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds
1. Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
2. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
7. Open drivers door
2003 Tundra AC TRD 4x4, Hellwig Rear Bar, Aluminum dog-bone window latches
Old 06-07-2008, 12:36 PM
Ando140's Avatar
Dealer : Beechmont Toyota
2002 Toyota Tundra SR5 V8 AC TRD LSD
Last Online: 10-31-2009 10:23 PM
Ando140 is on a distinguished road.
Ando140's Photo Albums
the button should be a little green button that's inside a small hole on the ECU which should be located pretty much directly above the brake pedal.
Look for a white junction box wrapped in electrical tape, the ECU should be above that box and is grey colored and attached to the same bolt as the junction box. Look for the hole where you can see the green button around the seam on the box.
Worst case, you can take off the driver's side kick plate, which is 4 bolts, then remove the vent duct (slide it to one side and pull it out), then you should be able to see the ECU. If you don't have the alarm, you'll have to do some rewiring before the programming will work.
Oh, I should mention that I'm assuming you have the RS3000, FCC ID on the remote should be BAB237131-022 if it's the RS3000.
Old 06-07-2008, 09:56 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 08:43 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Help!!!
Hello,
Please utilize the STICKY topics. They are there for a reason. Your answer can be found in the DIY (Do-It-Yourself) & User Knowledgebase sticky thread.
Welcome to Tundrasolutions!
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Tags
remote programming
