  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 06-13-2008, 02:28 AM
5 Speed's Avatar
Dealer : Longo Toyota
Last Online: Today 12:20 AM
Images: 19
5 Speed will become famous soon enough.
5 Speed's Photo Albums
Do It Yourself New Hellwig Rear Stabilizer Bar Installation for Toyota Tundra 2000-2006
I created this along with the attached .pdf at the end so you can print it out and take it outside and wrench on your Toyota, enjoy the ride and hopefully I have made your instillation enjoyable. Please note: Please don't make fun of the rust on the underbelly of the Tundra, It will get some POR soon, Utah Highway Salt ;-{
The tools used for the install
3/8” Torque Wrench
3/8” Socket Wrench w/extension
5/8” and 11/16” sockets, 5/8” deep well would make it easier on the U-bolts
11/16” and 7/8” wrench
7/16” and ½” deep well sockets to assist bushing sleeve instillation
Hammer
Tape Measure
Inside the box you should find the bar and a box of necessary hardware.
I have the d-shaped bushings installed to show you exactly how the bar goes under your truck.
Note Orientation of bar!!!! The center hoop is flat on the ground resting on the center of the bar plus the two brackets. Note that the arms are in the air. This is how the bar should be installed. The side of the bar towards the ground is the side the faces the road and the side you are looking at that is up goes up towards the underside of the truck.
Inside your hardware box you should find the instructions, hardware, and grease.
Here are the nuts, bolts, washers, bushings, and bushing sleeves in the bag.
Here is the hardware inside the box.
I recommend assembling the rear connecting arms first insuring you have all parts ready to go before you get under the truck.
Notice that there are two different sizes of rubber bushings . The large bushing goes on the top of the connecting arm and the smaller rubber bushing goes on the bottom of the connecting arm. A little of the grease plus a little persuasion got them into their spot.
Note: I added the two red arrows showing exactly where the arms connect to the frame and the rear of the sway-bar trailing arm. Note that the top bolt is attached and the frame is sandwiched in-between the two large washers and there are thick washers on the outsides of the bolt head and the nut. The lower part of the arm is attached in-between the rubber bushing the thick washer. On the other side of the bolt there is an additional thick washer and nut.
The metal bushing sleeves need to be inserted inside the rubber bushings. Be sure to coat the inside of the bushing with the included grease. I used the two sockets to help drive the sleeves inside the bushings. Don’t hammer directly on the bushing, it will deform it. This took just a little tapping with the help of the grease to slide them.
Then I made sure that the sleeves were centered inside the bushing evenly on both sides.
Put the U bolts together to help visualize exactly how they go together and to make sure all bolts and hardware is ready to go before getting under the truck.
I hope it is here that I saved you sometime and will make this install easier. I hung the bar from the rear axle and found that with the bar centered the U-bolts needed to be 9 inches from the leaf packs. So I would recommend marking 9 inches and position each U-Bolt there. Be very careful to not crimp any brake lines.
Don’t be tempted to install the bar now, it is easier to install the connecting arms to the frame, then swing the bar up into position. I found it difficult to hold the bar up and attach the U-bolts. If you don’t jack your truck up and put it on jack stands or ramps, you might not be able to do this but it is a lot easier to get the bar into position with the arms connected.
Attach the top of the connecting arm to the frame. It will fit into the slotted hole right behind the large round hole. You can see the sequence from the outside. Starting with the head of the 1/2 “ bolt, then the thick washer then the connecting arm then the large washer, then the frame.
Now on the inside of the frame attach another large washer, a thick washer and the nut. Don’t tighten up anything yet.
Go to the other side and install the second arm.
Now attach the sway bar to the two control arms with the 7/16 x 2 ¾” bolt and thick washers hand tight. Again remember that the bar orientation from the beginning, if you install it upside down it will interfere with the e-brake cable.
You can see I attached the poly bushings to the bar, don’t forget to grease them before sliding them over the bar. If you can get your truck up in the air and swing the bar up into position it makes getting the U-bolts connected a lot easier. I removed the spare tire to ease the photographs plus I could sit up under the truck and work with ease.
Swing the bar up into position and attach U-bolt brackets.
Again make sure you are not clamping over any brake lines. I found that the 9 inches from each leaf pack was orientated directly in the center of the bar pivots. Here is a picture of the bar hanging down when I found the center of the pivot areas. You don’t need to do this.
Here is the bar in position ready to be all ready to torque.
I double checked that nothing was interfering with the bolts or any movement before tightening any bolts.
Torque the U-bolts to 35 ft. lbs. Keep the base brackets level to the base of the truck. Be careful not to over torque these and bend the U-bolts.
Tighten the Upper attachment arms to the frame rail to 60-70 ft-lb. The large washers will deform into the rectangle keeping the upper mounting points from moving.
I then adjusted the height of the supports to have the arm sweep up a little following the slope of the rear leafs.
Tighten the lower connecting bolts to the arm to 40 ft-lbs.
Tighten down the top nuts on the adjustment links to 70 ft-lbs.
Hellwig states that the outward hole on the bar is the normal position. I think this is a good place to start. Be sure to bounce test to check for any problems before going for a test drive.
I have a Four Wheel Camper on the back of my Tundra and I know this is going to help enjoy the journey.
Old 06-13-2008, 04:56 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Yesterday 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Default Re: Do-It-Yourself New Hellwig Rear Stabilizer
Outstanding DIY thread. Added to the Install guides section of the DIY (Do-It-Yourself) & User Knowledgebase sticky thread.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 06-13-2008, 05:19 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Thumbs up Re: Do-It-Yourself New Hellwig Rear Stabilizer
Outstanding work!
Bravo !!
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Old 06-14-2008, 01:39 AM
Cian's Avatar
Dealer : Elmhurst Toyota
Last Online: 11-20-2009 08:49 AM
Images: 25
Cian will become famous soon enough.
Cian's Photo Albums
WOW! Awesome write-up!
THANK YOU!
THANK YOU!
THANK YOU!
2001 SR5 Access Cab 4.7V8 4x4
OEM: FJ Rims; bed-liner; alarm; running boards; all-weather mats; door sill protectors; 13WL brake caliper upgrade
TRD: color-keyed mirror covers, embroidered signature mats
OTHER: Bridgestone A/T Revos; NGK Iridium IX spark plugs; Skid Row front skid plate; Fumoto drain valve; Vibrant resonator; Magnaflow exhaust tip; Form-Fit deflector; Brembo rotors; Trfytoy window latches; Undercover tonneau; Wheelskins leather steering wheel cover
PENDING: TRD coils, Bilstein shocks; TRD Kazuma LSD; Hellwig sway bar
Old 06-14-2008, 08:35 AM
bmann's Avatar
Dealer : Toyota Of Portland
2004 Toyota Tundra
Last Online: 10-07-2009 07:43 AM
bmann is on a distinguished road.
bmann's Photo Albums
Nice work!! I want to add this to my truck.
2004 Access Cab 4x4 V8 7828A, Phantom Gray Pearl, All Weather Package, Aluminum Wheels, Chrome Arch Molding, Fog Lights, Towing Package, SR5 Extra Value Package.
Extras: Line-x sprayin liner, WeatherTech WeatherFlectors, Performace Products side steps chrome over SS, Retrax Bed Cover,Lund Interceptor bug shield.
Old 06-14-2008, 08:18 PM
5 Speed's Avatar
Images: 19
Just a little update. The truck tracks very nice. Even with the 700 lb camper on back I can really tell the side sway is no where what it used to be. We are going to go for a back road drive tomorrow and I will give you a better report. Going to Costco in weekend traffic is not a fair opportunity to see what this bar will do. Now I am want to know how much larger the new front bar is?
Old 06-14-2008, 08:21 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 01:27 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
Don't bother with the front bar. What you have up there now is good enough.
Old 06-16-2008, 07:17 PM
Greenie's Avatar
Dealer : Hoover Toyota Scion
Last Online: 11-20-2009 06:52 PM
Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything.
Greenie's Photo Albums
Excellent DIY 5 Speed. Thanks for your efforts.
Looking forward to getting one for my 2001.
Old 06-16-2008, 10:35 PM
El Jeep's Avatar
Dealer : Desert Toyota Scion Of Tucson
2005 Toyota Tundra,
2004 Toyota Land Cruiser
Last Online: Yesterday 10:01 AM
El Jeep is on a distinguished road.
El Jeep's Photo Albums
Great write up! Thank you!
2005 Tundra Double Cab 4x4
2001 BMW M5
Old 06-18-2008, 09:36 PM
cleanb13's Avatar
Dealer : Boch Toyota South
Last Online: 11-20-2009 05:38 PM
Images: 20
cleanb13 is on a distinguished road.
cleanb13's Photo Albums
Super detailed write up!!! Thanks
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Magnaflow 11226 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
Old 06-20-2008, 01:34 AM
5 Speed's Avatar
Images: 19
Default Why did my DIY not make it into the poll?
Why did my DIY not make it into the poll? I would vote for it!
Old 06-20-2008, 11:19 AM
Dealer : GO Toyota
2002 Toyota Tundra
Last Online: 10-15-2009 09:33 AM
rthistle2 is on a distinguished road.
rthistle2's Photo Albums
Do you know if the new bar has hit the market? Cost?
Old 06-20-2008, 01:54 PM
Dave@Hellwig's Avatar
Dealer : Visalia Toyota
Last Online: Yesterday 10:51 AM
Dave@Hellwig is on a distinguished road.
Dave@Hellwig's Photo Albums
We will be having a group buy on this forum next month. Price will be about the same as the current 7641 bar.
Old 06-20-2008, 02:41 PM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
Last Online: Today 12:01 AM
Images: 2
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch RitcheyRch's Photo Albums
Looks like they changed the design of them from when I added mine many years ago.
Excellent write-up.
Old 07-15-2008, 09:33 PM
5 Speed's Avatar
Images: 19
Just a 3000 mile update. I went on a road trip to Montana and back with the new Hellwig bar and it performed perfectly. It is amazing how little body roll I have on the flat onramps even with the camper on the back, in fact it is easy to forget it is back there. There was no squeaking and I did not have to adjust or tighten anything. I am so happy with the results and think it should be required for heavy campers just for safety.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/135578-do-yourself-new-hellwig-rear-stabilizer/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-23-2009 08:43 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-02-2009 10:49 PM
