How do I find out if I have Limited Slip
+ Reply to Thread
Results 1 to 10 of 10
Thread: How do I find out if I have Limited Slip
  1. #1
    Join Date
    Jun 2008
    Location
    Grapevine, TX
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default How do I find out if I have Limited Slip
    Everyone,
    I know this may sound ignorant, but I am trying to change my differential fluid and I need to find out if I have LSD or a standard. What is the best way to find out....VIN number, labeling on the differential, etc. Thanks for your help
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jun 2008
    Location
    Grapevine, TX
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Re: How do I find out if I have Limited Slip
    your the man, thanks
  4. #3
    Supporter redrdr67's Avatar
    Join Date
    Feb 2002
    Location
    Montebello, Ca
    Posts
    43
    Liked
    0 times
    Images
    1
    Rep Power
    14
    Find some dirt on the road, step on the brake pedal, mash the throttle 'til tire spins, get out of truck, and see if there's two burnout marks. It's alot funner.
  5. #4
    Supercharged Member FIVEPOINTSEVEN's Avatar
    Join Date
    Oct 2007
    Location
    Clearwater Beach
    Posts
    4,495
    Liked
    7 times
    Images
    17
    Rep Power
    31
    Quote Originally Posted by redrdr67 View Post
    Yup...This is an easy way to find out...Or do it on pavement and see where the rubber marks are.
    2015 Tundra 1794 Edition Crewmax 4x4
  6. #5
    Junior Member TP121's Avatar
    Join Date
    Apr 2007
    Location
    In my house
    Posts
    139
    Liked
    1 times
    Images
    3
    Rep Power
    9
    I have a limited 5.7 and the toyota listing sheet list the auto LSD but when I do a burnout I only have one tire spinning? WTF
    2007 DC 4X4 5.7 Limited Black with Red Rock Interior, TRD Dual Exhaust
  7. #6
    Junior Member truckman261's Avatar
    Join Date
    Dec 2006
    Location
    Nowhere
    Posts
    281
    Liked
    0 times
    Rep Power
    9
    Easy if you have a 5.7, you have an automatic (electronic) limited slip. Your rear end is technically an open differential, because Tundra uses the ABS for the Limited Slip.
    Tundra Truck Pro
    MODS: Line-X, Sirius, Dual Flowmasters
  8. #7
    Join Date
    Dec 2006
    Location
    Nowhere
    Posts
    281
    Liked
    0 times
    Rep Power
    9
    Quote Originally Posted by TP121 View Post
    First if you're going to do a burnout make sure you disable VSC and TRAC and the Auto LSD. Otherwise you are just going to burn through your brakes quicker. Second you would only have one tire because at that point you've got and open rear diff and only one wheel is gonna spin.
    Tundra Truck Pro
  9. #8
    Jedi Ninja in Training mxsjw's Avatar
    Join Date
    Jan 2007
    Location
    Lakewood, WA
    Posts
    8,309
    Liked
    13 times
    Images
    12
    Rep Power
    79
    moving to Gen 1
    Beer please!
  10. #9
    Join Date
    Jul 2007
    Location
    Minneapolis
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    I'm glad this got moved to Gen 1, because there is some mis-information here for the older trucks.
    DrunkDuck5 indicates he has a Gen1 2006; there are two ways to have limited slip: mechanical or electronic.
    If mechanical lsd is present and working, putting the rear end on stands and turning one wheel will result in one of two things: Wheel will not turn at all (if truck is in park and driveshaft cannot turn) or, if trans is in neutral (and driveshaft can spin) the entire rear end will turn the same direction as if there is no differential. In effect, the left and right axle shafts are mechanically locked together via a clutch pack in the third member. The wheels will not spin in opposite direction as indicated. Of course, the easiest way to tell is the "lsd oil only" sticker on the rear of the differential.
    Electronic limited slip is via the VSC system. A switch will be present on the dash, usually to the left of the 4WD selector.
  11. #10
    Supercharged Member HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Images
    12
    Rep Power
    578
    Quote Originally Posted by drunkduck5 View Post
    Everyone,
    yes it does sound strange, you either are missing the label on the rear diff or you have not looked for it? It is on the back side and if it has been torn off, just get someone here to do a VIN# search for ya! just PM them your VIN # lotta great Toyota Proffesionals on TS and they will help when ya ask! or call any dealer they should run it for ya with not to much pain! So no window sticker or did ya buy used or just lost window sticker? It has it marked on sticker!
    I guess this all confused ya? http://www.tundrasolutions.com/forum...archid=2625020
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
