  #31 (permalink)
Old 07-14-2009, 01:34 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Default Re: ScanGauge Owners Stop-In Please!
Thank you ScanGuageII!!!
Without you, my gauge needles would be all jacked up. I removed my needles to scrub off the green tint, replaced them, then... "P00F!" all jacked up zeros and incorrect readings. Luckily the SGII was there to give me some accurate readings at idle of the RPM, Voltage, and FWT. Now I'm back in business; the tach is even more accurate now than before. Whew!
FWIW, I did take pictures of the needles on the gauges before I stripped them off, but obviously I missed some fine print. I took pics while the truck was off, not at idle. D'oH!
But now everything is fixed and all white.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
  #32 (permalink)
Old 07-14-2009, 06:58 PM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: 11-17-2009 03:30 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
hi they sell on ebay a white face.
even if you couldn't fix it, our member's could have given you our reading's.
i'm sure as we read the thread about our #'s we are getting on our scangauge, many of us have different#'s,
in every gauge. so i'm so glad you had a scangauge. another reason for people to buy it.
i think for the price it's a great tool.
wow, you lucked out, bug time, i'm glad.
gorilla
  #33 (permalink)
Old 07-16-2009, 11:30 PM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: Today 02:21 PM
Images: 16
Big_Al1 will become famous soon enough.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
Ok did a test yesterday weather channel app updated 8:06 I checked it at 8:13 outside temp 88 heat index 94.Cruising at 70 FWT 195.intake temp 90So I was 2 degrees above temp but 4 degrees below heat index which is what thermomemter was reading.I have a true flow intake and filter and did the ram air addition using pool hose and shop vac attachments.
  #34 (permalink)
Old 08-12-2009, 09:06 PM
shawn74's Avatar
Dealer : Wilder Toyota
2005 Toyota Tundra,
2001 Toyota Highlander Wife's car
Last Online: 11-13-2009 01:39 AM
Images: 20
shawn74 is a splendid one to behold. shawn74 is a splendid one to behold.
shawn74's Photo Albums
So my best friend (the UPS driver) dropped off my SGII today. I can't think of any mod that I've installed that was so easy. I used my wire fish tape and slid it down between the bottom of the steering column and the lower dash panel. Hooked the SGII cable to it and pulled it through. Connect to OBDII, connect to SGII, and voila.
I programed A/F and HP under the Xgauges and set my display for those plus AI and MPG. The HP numbers didn't make much sense so I switched it to MPH +3. This matched my Pioneer Nav numbers exactly. So back to the point of this thread. The truck showed an ambient temperature of 67F and the IA held steady at 78F while driving around town. While sitting in the drive way it got up to about 86F. I did notice that when I started back up about 10 minutes or so later, the temp was at 101F. It came back down into the 80's pretty quick though. It was very interesting to see and keep in mind this is bone stock intake, with the original air filter. I look forward to messing with it some more on my road trip next week.
05 Spectra Blue SR5 DC
14" Magnaflow SISO, 2.5" Tuff Country lift, Helo Maxx6 18" rims on 275/70/18 tires, Doug Thorley 512-C headers, debadged, matching tint on front windows, Pioneer AVIC-D3 w/ front & back cameras, Leer 100XQ, more to come.....(I hope!)[SIGPIC]
  #35 (permalink)
Old 08-13-2009, 02:47 AM
TundraBear's Avatar
Moderator
Dealer : Carson Toyota Scion
2005 Toyota Sienna,
2006 Toyota Tundra 4x2 Limited DC
Last Online: Today 03:37 AM
Images: 6
TundraBear is on a distinguished road.
Send a message via Yahoo to TundraBear TundraBear's Photo Albums My eBay
Originally Posted by shawn74 View Post
It was very interesting to see.....
this is the exact reason i picked up the scanguage. funny as it sounds, i feel that i am closer to my truck more now than ever! knowing how she feels and operates is waaay cool!
check out my thread about the UniChip here. But basically without the chip installed but other listed mods, I'm getting around 250hp @ 4000rpm on a freeway entrance that is approximately a quarter mile.
as for temps
fWT: 190 - 195
fIA: 90 - 110
outside temp: 85 - 100
sometime at long periods of idle with a/c on or typical los angeles traffic, i've seen the fIA hit 145
2006 Tundra Limited DC: UniChip | Ram Air Performance System | TrueFlow Sealed Air Intake | 24" Bassani X-Muffler with Quick Time Electric Cutouts | IS Rims w/ Michelin LTX A/T2 265/70R16 | SkidRow FSP | Hellwig Antisway Bar | Retrax Bed Cover | Bazooka VSE | front/rear parking sensors | power tailgate lock | debadged | tinted windows | 2x baby mod (car seat)
2005 Sienna: Purple Plazma Headlights | de-badged | 2x baby mod (car seat)
  #36 (permalink)
Old 08-28-2009, 06:53 PM
PagalDesi4Life's Avatar
2001 Toyota Sequoia
Last Online: Today 10:45 PM
Images: 2
PagalDesi4Life is on a distinguished road.
Send a message via AIM to PagalDesi4Life PagalDesi4Life's Photo Albums
Hey guys, I'm selling my SG II unit unfortunately. While it is a great device that'll teach you more about your vehicle, I realized I can't afford it at the moment and so I am putting mine up for sale. It is practically in brand new condition, there are no marks whatsoever, everything works fine (check out the link below for pics). I used it on my 01 Sequoia and it showed the HP information, I'm sure you will get more data for a Tundra. It will come in its' original box and manuals (and even the adhesives that I never used) and of course the SG II unit and 6ft cord. If you're interested, please send me a pm. My asking price is $130.
http://www.tundrasolutions.com/forums/1322613-post8/
2001 Toyota Sequoia SR5
Vroom VroomParty Starter
  #37 (permalink)
Old 08-28-2009, 09:49 PM
shawn74's Avatar
2005 Toyota Tundra,
Images: 20
as for temps
fWT: 190 - 195
fIA: 90 - 110
Out of curiosity, are you getting your outside temp from the SG or the factory thermometer? I saw there is an x-gauge for ambient temp but have not been able to get it to work on my 05 DC.
Tags
air temp , scangauge , scangauge2
