This is a discussion thread titled "My Truck Trys To Kill People. Please Help", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 06-27-2008, 02:06 PM
peterfarhangi's Avatar
Dealer : Boulder Toyota
2002 Toyota Tundra
peterfarhangi's Photo Albums
Last Online: 12-02-2008 11:35 PM
peterfarhangi is on a distinguished road.
Default My Truck Trys To Kill People. Please Help
Alright so my truck has had this problem all summer and I don't really know what is goning on here. I have a 01 Tundra with the RCD 6" lift no sway bar. I'll be driving down the road then press on the brakes and it seems that the lift side will start to stop before the right side or the other way around. This makes my truck want to pull really hard to one side then the other. It really sucks when I have to come to a hard stop in traffic. Please try to help me fix this problem.
Air bubble in the brake line?
Need new brake pads?
Bad wheel bearing?
Thanks all!
2001 Tundra V8 4x4 Limited -6" RCD lift -4.88 Gears w/ rear locker -Rockslider -35"x12.5"x20" Nitto Muds -20"x9" KMC Dimes -Flowmaster Super 40 -5% Tint - Hybrid Emblem
Old 06-27-2008, 02:09 PM
OntheRox's Avatar
G.I. Jane
Dealer : Mountain States Toyota
2007 Toyota Tundra,
- Other - 2003 Subaru Leg GT
OntheRox's Photo Albums
OntheRox will become famous soon enough.
Default Re: My Truck Trys To Kill People. Please Help
No pulling when driving? Bad tire? Caliper problems? (lube slides)
2007 Tundra DC 4.7 SR5 TRD 4X4
Pyrite Mica
Clear Bra
ARB Bumper w/hidden winch &
added 2.4" Ready Lift
Line-X
325/60/18 Nitto Terra Grapplers
18" KMC XD Hoss Black
ARE CX Series Topper
KC Rally 800 long range lights
Tinted windows
Wet Okoles Frt & Rear
Weather Tech rain deflectors
Weather Tech floor liners frt/rear
Garmin GPS
Bel Vector 995 Radar Detector
Cellular booster
Debadged except TRD sticker
Roxy Sticker
____________________________
Wish list:
Horn Blaster train horn, ARB rear bumper w/guards (if they ever make one), TRD sway bar, Winch and a TS tank top
__________________________________________
Old 06-27-2008, 02:25 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
dsrtrcr01's Photo Albums
Last Online: Yesterday 04:14 PM
dsrtrcr01 is on a distinguished road.
I have seen this on some long travel trucks we worked on. It ended up being that when we turned the caliper would hit the A Arm so when you hit the brakes one side was ready to stop you and the other was to far apart due to hitting the a arm so once you let off then hit the peddle again it was good. check to see if your brake calipers hit anything at all. When straight or turning. Just something you can check
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 06-27-2008, 03:05 PM
ICON's Avatar
Dealer : Lia Toyota Of Northampton
ICON's Photo Albums
Last Online: Yesterday 03:26 PM
ICON is on a distinguished road.
It's weird that it pulls to one side then it could pull to the other, typically it's only one side. There could be many reasons for this to happen such as contamination on the pads/rotors, sticking pistons in the calipers, air in the lines, slides hanging up(but that'd also show up as unevenly worn pads), collapsed flex lines or pinched flex lines, master cylinder issue, worn pads, etc. At the very least i'd check each caliper to make sure it's nothing obvious. It probably wouldn't hurt to flush/bleed the system. And lube the slide pins to make sure the calipers are sliding properly. That's the basics and things after that might take special equipment to test or start replacing parts with hopes that was the problem.
'01 Tundra Reg Cab SR5 V8
'05 Honda Foreman 500S 4x4
'04 Honda Shadow Sabre 1100
Old 06-27-2008, 05:26 PM
Boosted27606's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2006 Toyota Tundra,
1998 Lexus GS300 Silver,
- Other - 93 MITSU Eclipse
My eBay Boosted27606's Photo Albums
Last Online: Yesterday 11:23 PM
Boosted27606 is on a distinguished road.
Send a message via MSN to Boosted27606 Send a message via Yahoo to Boosted27606
I agree with ICON. Check the easy stuff first:
I doubt it is an air bubble as you simply would have a mushy brake pedal.
I think it is likely a stuck caliper ( lube the sliding mechanism ) or a detached pad ( pad is still there, but the contact material is un-glued )
I would not wait much to fix this as you don't want to experience a major brake failure in an emergency ! We hate to lose TS members, and we try to keep as many alive as possible !
Boosting happily ...
List of mods ( growing Daily ): L.E.D.s inside , Camper Shell with inside lights, Back up sensors and Camera , Subwoofer and Amp , Scangauge II , Hellwig Rear Bar , Billet Rear windows hinges, K&N Air Intake , Heated Seats, Tailgate assist bar, Westin Bull Bar and Skid Plate, Under hood lights, 1.25" Spidertrax spacers in Front, 1.50 " wheeladapter spacers in back, Ultimate window tint.
Old 06-27-2008, 06:16 PM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Today 01:04 AM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
Mine use to pull hard to the right when braking. Turns out one of the slides was bent on the driver side front caliper. Remember, these are F-250 brakes, I don't know if the tundra uses the same style caliper (i doubt it does). But I fixed it for only $30.
SAS Tundra
Build Thread-
SAS on 02 Tundra
Old 06-27-2008, 06:17 PM
2002 Toyota Tundra
Ok thanks guys, I'll check it out tomorrow. I don't drive the truck too much anymore because I just got a 05 Yamaha R1! Gas has been killing me in that thing.
Old 06-27-2008, 07:22 PM
dsrtrcr01's Avatar
OK I just thought of another issue I ran into that did this. Check the bolts holding your upper A Arm on as well. I had them come loose which would cause the tire to flop forward and back and would cause it to pull one way or another when braking. Just another thing for you to check. Of coarse most of this stuff I speak of happen on off road trucks with lots of vibration and bouncing to cause bolts to come loose.
Old 06-29-2008, 10:30 PM
MEvang's Avatar
Dealer : Toyota of Cincinnati Co.
MEvang's Photo Albums
Last Online: Yesterday 07:36 AM
MEvang will become famous soon enough.
If the pull moves left to right it's likely a suspension problem not brakes. Check the bolts as dsrtcr01 describes and all other suspension parts also could be a lack of castor. Check the wheel alignment or a wear pattern on the tires.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
Old 06-29-2008, 10:42 PM
Dealer : Haley Toyota of Farmville
Tundra94x4's Photo Albums
Last Online: 12-01-2008 08:06 AM
Tundra94x4 is on a distinguished road.
I have had this problem before it can be one of two things or both......your brake lines need to be replaced b/c of not holding pressure....or that you are running low on brake fluid.
Old 06-30-2008, 02:23 PM
2002 Toyota Tundra
I'm going to check it out today. Thanks for all the input I have a lot of thing to go over.
Old 07-02-2008, 03:25 AM
2002 Toyota Tundra
Wow so it was the lower control arm bolts... I also need new brake pads, I almost have 35K miles on the truck.
Old 07-02-2008, 12:42 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Today 12:35 AM
Pete did you get everything sorted out? Lemme know if you want a hand.
-Sean
GFX by FreedomEagle50
Manual Hubs
Old 07-03-2008, 05:03 AM
2002 Toyota Tundra
I think I got it. Gonna do the brakes tomorrow and get her ready for the weekend road trip.
Old 07-07-2008, 02:08 AM
2002 Toyota Tundra
OK so that didn't really work. I was under there today and it looks like my steering rack may be lose. Could that cause it? I thing the bushings are bad. Any poly ones out there?
