I've seen dozens of threads regarding the infamous carbon filter in the stock airbox. Some of them had people cutting out the mesh, some cutting out the plastic, all leaving the carbon filter FUBAR. Here's what I did to remove the thing and have it available to reinstall. Yes, I said, reinstall.
Note: no shameless beer plugs in this write-up
First, some interesting pictures of the filter from two different perspectives.
Here's what it looks like held up to the light.
Here's what it looks like with the light shown from behind the filter.
Ok now, the dissection of the airbox...
Step 1.
Remove the airbox, duh. Or at least the top half.
You'll need the popular 10mm socket and at least a 7" extension to remove the entire box. You need a #2 phillips and maybe a 10mm to remove just the top half.
Step 2.
Remove the MAF. (#2 phillips needed here)
Step 3.
Stick your arm in the hole, Flash Gordon style.
Step 4.
Reach all the way back, these are the easy ones.
Gently push up on one of the plastic corners, not the fabric.
See these little circles?
Push on those from behind. They'll pop out with moderate pressure.
Step 5.
Repeat step 4 on the middle tabs.
Step 6.
Pull the back up, the only two circles still attached are those in the front, where you couldn't reach from the inside. Well, I couldn't reach.
Now you can pry the front two loose.
End result:
A carbon filter that isn't all jacked up and an airbox that requires no scrutinizing cleaning!
Easy huh?
The tabs were melted on from the factory, and if you pulled them off gentle enuogh, you can reattach them. If all 6 are back on, the tension of the plastic frame will hold them back on snug.
Also, don't bother cleaning it, nothing comes out, it never gets white again, and it takes an hour or two to dry.
Re: How-To: Removing Carbon Filter w/o Damaging It
Originally Posted by Brad's Dad
What years/models of Tundra have this carbon filter?
Fred
Good question! Now have me wondering if my '01 has one. I've put in a few air filters but never remember looking in to the top side.
Carbon filters are usually used to keep migrating fuel odors from backing out of the engine during a thing called a "shed test." This is where the entire vertical is put in a shed or sealed bag of sorts and they measure the emission the vehicle puts off just sitting there. The carbon absorbs the fuel vapors and then when it's running they are suck back into the air stream.
Other wise I can't see why you couldn't remove this. I don't believe it does any actual filtering.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein) Moderator Brake Forum
OK, went and checked, 2001 does not have it.
Mike
Nice write-up. I can't tell you if the '03 has this or not as my stock airbox is in the top of the shed, at the back, about a half-day of moving crap to get to it. So one of the other '03s will have to look and see if this is in their airbox. Maybe it came out with the VVTI engines?
BJ
2003 Tundra 4.7L V8 Access Cab Limited 4WD
w/ all factory packages,Black Onyx 202-rebadged. was stock 31K on 5/9/05, now 56K
*Extang Full-Tilt Tonneau * Bedrug*Topline Tailgate Step *Mr. Gille Upper & Lower Billet Grille *WAAG Bumper Guards, front & rear *HT Side Step Nerf Bars *AVS Hood Protector *WeatherTech Vent Shades *JDM Black Taillights *TurnSmart Solar-power Mirror Turn-Signals *Altec 48" Line-of-Fire LED Light Kit *Altec 53" Screamer Amber Side Marker LED *PIAA Backup/Work Lights * 35 % Tinting *BullyLED Third Brake/Cargo Light *
Interior:
*Gentex Auto Dimming Compass/Temp Rear View *Garmin's Nuvi 660 GPS * Scan Guage II *Passport SR7 Radar/laser shifter *
Wheels/Tires:
*Moto Metal M0951 Gloss Black 17 in. Alloys *SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
*Bilstein HD Shocks, F&R *Hellwig Rear Sway Bar & Helper Springs *TCS Poly Steering Rack Bushings *Wheeler's Front Sway Bar Bushings *Timbren SES Kit, Front & Rear *
The filter is pretty non restictive. There is no cleaning ever required. You won't gain anything taking it out except adding to pollution. I accidentally took it out of my 4 Runner while trying to figure out what it was. It was too messed up to put it back in. I checked my 03 Tundra and it has one but I left it in. You never know when emmissions testing will get tighter.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery 5.7 Killer
I know that some of the guys on the 2nd gen Tundra forum are removing the carbon filter and claiming a 2 MPG increase in fuel mileage. I was thinking of removing it from my 05 to see if there might be any improvement. If it is removed carefully it can also be replaced if desired with no harm done.
I removed it. Carefully per Tundradrenalin's good post. Came out easy. Did a intake clean and MAF clean also. I'll fill up tomorrow with top tier and check mileage on a full tank by Thursday or so. I'll reply and post. Intake did sound louder, but my truck also runs faster after a good oil change. . TLC never hurt anything..
