This is a discussion thread titled "fat bob's", within the 1Gen-Tundra forum, part of the Truck Forums category.
Ya i was going to ask about that too. I been reading for the 1 gen tundra 3 " might be a bit higher then the back and 2.5 was better. Is that correct. and also is it true if you use a leveling kit like these CV joint might have a problem????
I don't have any experience with that site, but I can tell you that a 3" suspension lift on the front will set the front higher than the rear. If you're set on doing a 3", then go with a 1.5" rear lift to level it out. the 2" lift is the closest to a true level lift if you don't want to lift the rear.
Whether you go with a 2.5" or 3" front lift, you should also do the "hose clamp" mod on the cv's. it cheap and easy and will keep the grease from spewing out. you can pick up the clamps at any harware store ( Lowe's, Home depot) and clamp them on over the existing cv boot clamps.
tHANK YOU so much, however I can't seem to find any leveling kit with a 2" lift. everything out there is a 2.5 or most of them are 3" lift. You know where i can go and get some. I don't wanna lift the back cuz i still load bikes and stuff in there.
I know i can go Coilovers but they are like 600 some dollars. Do coilovers have the same problems with the CV joints. Maybe i can go billsteins 5100 maybe????
I was reading a thread in the Supension and Handleing forum that made the claim that the coilovers are the best way to go unless you also do the upper control arms. The spacer above and below put an excessive amount of wear on the ball joints (the write-up even had pictures of the damaged ball joints).
After reading all that info, I feel Bilstein 5100 is probably the safest, cheapest way to get that 0-2.5" lift and I thought WheelerOffRoad.com had a decent price.
BJ
2003 Tundra 4.7L V8 Access Cab Limited 4WD
w/ all factory packages,Black Onyx 202-rebadged. was stock 31K on 5/9/05, now 56K
*Moto Metal M0951 Gloss Black 17 in. Alloys *SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
*Bilstein HD Shocks, F&R *Hellwig Rear Sway Bar & Helper Springs *TCS Poly Steering Rack Bushings *Wheeler's Front Sway Bar Bushings *Timbren SES Kit, Front & Rear *
I been reading a bit, i have to say leveling or lifting you truck is alot of work and you might have alot of bugs. Man i was excited about leveling out my truck and now don't know what to do....
I had a 2.5" daystar installed yesterday along with a 1.5 AAL and the ride didn't change all that much. I was pleasantly surprised...it only cost me $250 to install and I'm getting my tires in about 3 minutes!
I know what you mean, but I a not worried about the performance. Its the CV boots and other suspension bugs that comes with it that I am worried about.
I installed a 3 inch spacer on a friends double cab and it sits just about level. I installed 3 inch springs on my Doublecab and it sits about level. What I always suggest is for people to do the front lift then if you do not like the stance then do the rear. Better then doing both and paying for it if you would have been happy with the back being stock.
Coilovers will give you the best performing/riding lift but it costs more. The spacer or springs give you a stiffer ride and when you hit speed bumps it is kind of violent but I got a 3 inch spacer for $70. SO he wanted to spend 70 and deal with the stiffer ride instead of 600+.
__________________ '05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Like you I have a 06 DC TRD 2wd. So far do you have any problem, with your 3 inch spacer lift. Is your CV boot leaking shiet????
If you have a 2wd like me then we do not have CV boots to leak. that is only on 4 wd models. No issues so far to report. All is good
