This is a discussion thread titled "help - what's on this circuit?", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 07-02-2008, 08:02 AM
Dealer : Toyota Of Turnersville
2005 Toyota Tundra
lee_greco's Photo Albums
Last Online: 08-26-2008 03:37 PM
lee_greco is on a distinguished road.
Unhappy help - what's on this circuit?
What's on the Tow circuit on an 05 SR5 V8 AC w/o tow package? My battery is dead after leaving the truck sit for 3 days . Traced the problem to a 1/2 amp draw on the circuit labeled TOW on the fuse panel under the hood. It's a 20 amp fuse. Any ideas on what could be causing the draw (other than a wire short or corrrosion at the connector)? Can I safely pull this fuse and leave the circuit dead? Thanks in advance.
Old 07-02-2008, 05:40 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
UnSub's Photo Albums
Last Online: Today 11:21 AM
UnSub is on a distinguished road.
Default Re: help - what's on this circuit?
I am looking in my book and I don't see a fuse for 20 amps labeled "tow". If you will double check to see what it says again and also list the name of the fuse on each side of it, I will look at the schematics tonight and try to help.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Nav system, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Line, 5.7 Killer
Old 07-02-2008, 06:26 PM
Dealer : Camelback Toyota Scion
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
tempetom's Photo Albums
Last Online: Today 12:55 PM
tempetom is on a distinguished road.
Yeah, I checked also and there seem to be several fuses with tow in their titles. I'd pull the fuse and see what happens?
Old 07-07-2008, 08:10 AM
2005 Toyota Tundra
I'm really sorry but earlier I posted the wrong details. This is actually a 2003 Tundra and it's a 30 amp fuse labeled TOW TAIL. The fuse is in the foremost bank between several empty slots. It is perpendicular to and between the 5 amp ECU-B and the 15 amp PWR OUTLET 1 fuses.
When removing/replacing the fuse, the TOW TAIL relay throws. I've tried other relays in that location and they all give the same behavior. This truck does not have the tow hotch or package but does have the bumper that can take a ball.
Thanks again.
Old 07-07-2008, 11:54 AM
2005 Toyota Tundra,
My manual only shows the circuit going to the relay then to the trailer connector "tail" pin. Can you look under the back and see if the connector was removed and maybe the wire is shorting? It should be a brown and/or green wire.
Old 07-07-2008, 12:05 PM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
shall36's Photo Albums
Last Online: Today 02:00 PM
shall36 is on a distinguished road.
Try this:
http://www.daveramsey.com/
Must See Video: Drive Free Cars for Life
Old 07-07-2008, 12:15 PM
2005 Toyota Tundra
Thanks much!
Old 07-07-2008, 12:27 PM
BAD BONEZ BJ's Avatar
Click Username, View Profile!
Dealer : Priority Toyota
1993 Toyota Truck,
2006 Toyota Sienna XLE in Pear White,
2003 Toyota Tundra AC Limited 4WD,
1998 Toyota 4Runner Trade-In,
2004 Toyota Sienna Trade-In,
2004 Toyota Prius Trade-In,
2006 Toyota Highlander HV Trade-In,
1998 Toyota Celica Sold,
- Other - '81 Tercel - Sold
My eBay BAD BONEZ BJ's Photo Albums
Last Online: Yesterday 10:47 PM
BAD BONEZ BJ is on a distinguished road.
Send a message via AIM to BAD BONEZ BJ
Ahhh! A 2003 Tundra. There is a TSB that covers that year model which has a wiring error. If you use the Auto-Off feature with your headlights, you are leaving the trailer circuit active. Manually turn your headlights off to kill this battery drain.
I have posted about this before, follow this link for the fix and a copy of the TSB.
http://www.tundrasolutions.com/forum...83/#post922383
BJ
Rep Points?
2003 Tundra 4.7L V8 Access Cab Limited 4WD
w/ all factory packages, Black-rebadged. was stock 31K on 5/9/05, now 56K
Performance:
* UNICHIP (broken) * AEM Brute Force Intake * AEM DryFlow Filter * K&N DryCharger * AirRaid TBS * JBA Titanium-Ceramic Headers * JBA Y-Pipe * Gibson CAT-Back Dual Extreme Exhaust * PulseStar Pulse Plugs * Fitch Fuel Catalyst System * Optima D35 Yellow Top * Argus Battery Bug * Fumoto F103N Oil Drain Valve * RP Oils *
Exterior:
* Extang Full-Tilt Tonneau * Loading Zone Cargo Divider * Topline Tailgate Step * Mr. Gille Upper & Lower Billet Grille * WAAG Bumper Guards, front & rear * HT Side Step Nerf Bars * AVS Hood Protector * WeatherTech Vent Shades * JDM Black Taillights * TurnSmart Solar-power Mirror Turn-Signals * Altec 48" Line-of-Fire LED Light Kit * Altec 53" Screamer Amber Side Marker LED * PIAA Backup/Work Lights * 35 % Tinting * Bully LED Third Brake/Cargo Light *
Interior:
* Gentex Auto Dimming Compass/Temp Rear View * Garmin's Nuvi 660 GPS * Scan Guage II * Passport SR7 Radar/laser shifter * Passport G-Timer GT2 * P.I.E. Adapter
Wheels/Tires:
* Moto Metal M0951 Gloss Black 17 in. Alloys * SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
* Bilstein HD Shocks, F&R * Hellwig Rear Sway Bar & Helper Springs * TCS Poly Steering Rack Bushings * Wheeler's Front Sway Bar Bushings * Timbren SES Kit, Front & Rear *
Brakes:
* TRD Big Brake Kit (front) *
BAD BONEZ BJ
Old 07-07-2008, 12:37 PM
shall36's Avatar
2003 Toyota Tundra
But the OP says he does NOT have the tow package. Interesting...could this still be the problem? Looking at the diagram, I don't see what else would be causing the draw.
Old 07-07-2008, 02:53 PM
Tundradrenalin's Avatar
My eBay Tundradrenalin's Photo Albums
Tundradrenalin is a splendid one to behold.Tundradrenalin is a splendid one to behold.Tundradrenalin is a splendid one to behold.
What about the TSB for the parasitic draw from the JBL amp? lee_greco, you have the JBL audio system?
Searching for an answer to your Tundra or other Toyota question? search HERE! or HERE!
Got a question about TS.com site policy? click HERE!
What is Rep Power? read more HERE!
My Truck:
Old 07-07-2008, 06:39 PM
1993 Toyota Truck,
Yeah, I caught that too. But if he has the circuits and fuses for Towing, then he has the same problem I had with the Circuit being left on (only applies to the AUTO-Headlight Off Feature), manually turn your headlamps off and see if that circuit still has the draw. If not then the TSB doesn't apply to this situation.
TSB for the amp. More details please, I don't know anything about this one.
BJ
Old 07-07-2008, 06:49 PM
Sorry, I just read the TSB, it's for the '04-'05 DCab Tundra. TSB-AU001-05.
Production VIN dates before: 5TBDT441#5S480009.
...also for ’04 – ’05 4Runner, Prius, RAV4, Sienna, Solara, ’05 Corolla, Matrix, Sequoia, Tacoma
Some customers may intermittently experience a pop noise while turning the ignition key ON or OFF due to the JBL amplifier staying ON when the ignition key is OFF. This could result in a dead battery after an extended cold soak. An updated JBL amplifier is available to address this situation.
My Truck:
Old 07-07-2008, 08:54 PM
1993 Toyota Truck,
Thanks for that clarification, and for covering who it does apply to.
I think all the '03s have this problem, and it's only when and if you went to the dealer that they might tell you about it. In the meantime, you drain your battery every time you use the Auto-Off Headlight feature and leave the lights on. It leaves that trailer circuit on, as if the headlights were still on. But, I'm not sure there should be any draw if there is nothing connected to the circuit or, not enough to drain the battery
I noticed this the first time I hooked up the trailer and had the headlights on when I turned the truck off and jumped out. Lights went out everywhere but the trailer. It was if I still had all the lights on.
Do a search on the forum for that TSB and you'll find lots of discussion on this problem. I have the harness, but have never taken the time to install it. I just manually turn my lights off - old fashioned.
BJ
Rep Points?
Performance:
Exterior:
Interior:
Wheels/Tires:
Suspension:
Brakes:
BAD BONEZ BJ
Old 07-08-2008, 06:44 AM
2005 Toyota Tundra
Thanks to all of you on the forum. Turning off the lights cut the current draw dramatically, from over 1 1/2 amps to around 0.3, but the residual still looks like it's more than just the clock and keyless entry. I've got an aftermarket sound system and alarm in it so I may just have to deal with that draw. I'll do some more fuse pulling this weekend. Hopefully I'll be able to start it without a jump after coming back from vacation
Tags
short, tow, wiring
