This is a discussion thread titled "ATF drain and refill is this normal", within the 1Gen-Tundra forum, part of the Truck Forums category.
  #16 (permalink)
Old 07-14-2008, 12:20 PM
Dealer : Charles Maund Toyota
2002 Toyota Tundra,
- Other - 2005 infiniti g35 cp
mikeinaustin's Photo Albums
Last Online: 12-01-2008 01:20 AM
mikeinaustin is on a distinguished road.
Default Re: ATF drain and refill is this normal
85k miles? is this the first time you removed and cleaned the pan? if so, i believe this is totally normal wear. transmissions are wear items, thats what they do with every shift, wear.
it is 4qts or close to it.
  #17 (permalink)
Old 07-14-2008, 04:10 PM
Dealer : Ferris Toyota
2005 Toyota Tundra
skinny2's Photo Albums
Last Online: Yesterday 03:29 PM
skinny2 is on a distinguished road.
Originally Posted by kathyricks View Post
Regardless of the year, model or even brand of truck, towing in overdrive is a no-no. Just lock out the overdrive when towing (overdrive = 4th gear) and drive 50-65 MPH in
3rd gear. 3rd gear is direct drive.
Sorry, that's a load of crap. Towing in OD is only an issue if the truck is unable to maintain reasonable speed in OD and is shifting often. If that's the situation, then you should be locking out OD. This keeps the temps down from all the shifting as well as protects the torque convertor. But if the truck is getting down the road fine in OD, all you're doing is wasting fuel by running in a lower gear. The Tundra doesn't do a bad job at all towing within its limits....the only time I've locked out OD completely was when I got stuck pulling a 9,000# trailer.
Based on my experience with changing tranny fluid....the bottom three magnets look about normal. The top one looks a little scary. I have a feeling the tranny is the weak link in theses trucks. Maybe we shouldn't tow anything at all and just hope to hit 100k.......or buy a car
'05 Tundra DC 4x4 (my DD)
'05 Honda Odyssey (her DD)
'03 Ram 3500 Cummins 6-speed dually (for haulin)
  #18 (permalink)
Old 07-14-2008, 11:26 PM
adamjt's Avatar
Dealer : Toyota Of Portsmouth
- Other -,
adamjt's Photo Albums
Last Online: Yesterday 11:48 PM
adamjt is on a distinguished road.
I have never seen metal shavings in my v8's tranny and I have around 140k now. Last changed it at about 110k. Mine as well run it till it goes. I keep AAA Plus just in case, its saved me on another car when it dies 1.5 hrs from home.
As for towing in overdrive, I agree with the guy above. I have always towed with overdrive unless its shifting around. I tow a 3000lb box (enclosed snowmobile trailer) on the highway. If there are a lot of hills on the highway I take OD off and once I get off the ramp I turn OD off. Towed with an 05 Tundra a few years back, the 5 speed tranny is soo much better towing and otherwise
  #19 (permalink)
Old 07-15-2008, 12:18 AM
Dealer : Gresham Toyota
Oregonbuilder's Photo Albums
Last Online: 08-04-2008 10:31 AM
Oregonbuilder is on a distinguished road.
I just dropped the pan on my 2002 and it was clean no metal of any kind. The way it was sealed I am sure it was the first time any one had touched it. It has 116,000 miles
  #20 (permalink)
Old 07-17-2008, 02:01 PM
Newtregger's Avatar
Dealer : Butler Toyota Scion
Newtregger's Photo Albums
Last Online: 07-19-2008 02:23 PM
Newtregger is on a distinguished road.
Well, here I am in Michigan. I made it up here without any issues. But today, when I stopped at a stop sign, the truck stalled like it was stuck in gear. I cannot get the truck to move now. As soon as I drop the truck out of nuetral or park, the truck stalls like I am dumping the clutch on a manual transmission. I am currently waiting for a tow truck to tow my truck 30 miles to Traverse City to a transmission shop. They will diagnose the problem and let me know what the damage is. Anyone with any input on here is anxiously welcomed. I have heard the torque converter may be shot from the dealer and the tranny shp told me it might be a tcc sensor or something like that. I think he said tcc sensor? Anyway, I will keep you posted.
2000 Tundra 4x4 Extended Cab Limited
  #21 (permalink)
Old 07-17-2008, 02:56 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
duffyatkinson's Photo Albums
Last Online: Yesterday 07:38 PM
duffyatkinson will become famous soon enough.
Send a message via Yahoo to duffyatkinson
Unhappy Re: ATF drain and refill is this normal
That doesn't sound like good news. I think it is more than a coincidence that you saw the type of shavings in your pan and this happening to you. Was your tranny exhibiting any of this behavior BEFORE you dropped the pan and did your drain/refill? Are you sure you got the correct volume of fluid back in there?
I feel for ya man...
2002 Tundra V8 AC 4X2 SR5 | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box | Baby seat in the back! | All the rest is stock Toyota baby! | 10/2008: 43,500 miles
  #22 (permalink)
Old 07-17-2008, 03:22 PM
Dealer : Rountree Toyota Scion
FLTundra06's Photo Albums
Last Online: 12-01-2008 04:01 PM
FLTundra06 is on a distinguished road.
He said he was concerned because last time he towed it was shifting bad and felt hotter than normal. Then he changed the trans. fluid and found the shavings.
  #23 (permalink)
Old 07-17-2008, 06:17 PM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
shall36's Photo Albums
Last Online: Yesterday 11:40 AM
shall36 is on a distinguished road.
Sounds like the torque converter is in lock-up mode and won't come out. It's also possible that the unit is trying to apply two clutch packs at once.
http://www.daveramsey.com/
Must See Video: Drive Free Cars for Life
  #24 (permalink)
Old 07-18-2008, 04:27 PM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
RitcheyRch's Photo Albums
Last Online: Yesterday 10:56 PM
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch
Just did the drain and refill on my '02 Tundra with 72K
At 30K did a flush at the dealer and at 60K did a flush and changed to Mobil 1 synthetic.
Decided to take to my buddies shop and drop the pan for the drain and fill. Took the pan off and found very few shavings. My buddy was actually surprised at how few shaving were found. Cleaned the pan and the magnets and reinstalled using a new gasket. Took 4 1/2 quarts to fill.
Always have been worried about the trans since only use my Tundra for towing my boat to and from the lake and the river.
  #25 (permalink)
Old 07-18-2008, 04:30 PM
Newtregger's Avatar
Okay. I just got off the phone with the tranny shop. The tranny is junk! He informed me that there were "groceries" in the pan. It is from towing in OD.(Shame on me!) I am having a new tranny from Howard Engineering shipped to the tranny shop and it will arrive next Thursday. The cost.....$3500! The tranny comes with a 3 year/36,000 mile warranty good at almost any tranny shop. The other option was a factory tranny for $3200 but only a 1 year/12,000 mile warranty. And the guy at Toyota told the tranny shop the factory tranny is not that great.
I am working on a deadline here and it is a little stressful. Fortunately, I am here on vacation for another week. They said the truck will be done on Friday just in time to pack up and return home on Saturday.
  #26 (permalink)
Old 07-18-2008, 04:40 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Yesterday 11:28 PM
HOGWILD will become famous soon enough.
do not hold your breath on time lines to fix a tranny, you will turn blue!
Sorry to hear about the problems. all that crap that was on your magnets was a bunch of bearing,gears and clutch pack junk which is all magnetic material, the brass junk would be bushing junk! Guess leaving it in OD during towing is expensive! I run a lotta hills here in NM with a 2K Lb boat and lotta times i kick it off altogether!! Good Luck on repair and return trip! Had you ever changed your fluid and how many miles were on your tranny?
  #27 (permalink)
Old 07-19-2008, 12:24 AM
Newtregger's Avatar
Thanks. I have never changed my fluid until after trailing the pop-up camper. The pop-up camper weighs 2500 lbs. My truck has 80,000 miles on it. I thought it had 85,000 miles but it is only at 80k. I have towed a 5000 lbs. enclosed trailer with this truck with OD on and never had a problem. I tow my 5000 lbs boat all the time with OD on and never had a problem. This pop-up camper has now destroyed 3 transmissions. One from the previous owner, one from my brother-in-laws truck and now one from my truck.
  #28 (permalink)
Old 07-19-2008, 10:42 AM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
would not go more than 50K on fluid if pulling trailer and that would be with synthetic ATF but with regular ATF i would go only 30K before fluid change. Toyota says only 30K miles and then fluid needs changed if pulling trailers, could save you some cash!! fluid changes also means complete system not just pan fluid! you have not had very good luck with trannys it seems and i would leave that pop-up on the side of the road if it were causing that much of an issue!! Ya can't even sleep in one of those things here in NM because of the wind blowing them, not to mention the heat!
  #29 (permalink)
Old 07-19-2008, 11:38 AM
2005 Toyota Tundra
I really doubt it was this camper that destroyed the tranny. It just happened to be behind your truck when it finally gave up. Have you towed since this truck was new and never changed the fluid? I agree that if you're towing regularly the fluid should be changed more often. But I still don't buy that towing in OD actually caused the failure. IF you're maintaining speed in OD and the torque converter isn't unlocking regularly and downshifting, there should be no additional wear regardless of whether you're in OD or not. If this transmission has some weakness in the top gear, then I can believe it. But if that's the case then the damn thing shouldn't be rated to tow, period.
Probably could have saved money by having yours rebuilt by a good shop, but being on the road in unfamiliar territory...probably safer to get something with a national warranty.
