This is a discussion thread titled "ATF drain and refill is this normal", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 07-10-2008, 10:07 AM
Newtregger's Avatar
Dealer : Butler Toyota Scion
Newtregger's Photo Albums
Last Online: 07-19-2008 02:23 PM
Newtregger is on a distinguished road.
Default ATF drain and refill is this normal
I am attempting to drain and refill my transmission. This is on a 2000 Tundra with a 4.7L 4x4. Are all of these shavings normal? Also, how many quarts do I need to replace? I read on here 4 quarts but the lady at NAPA told me 2.1 quarts. Thanks.
2000 Tundra 4x4 Extended Cab Limited
Old 07-10-2008, 10:45 AM
Dealer : Performance Toyota Memphis
2004 Toyota Tundra
buglao's Photo Albums
Last Online: 12-01-2008 06:46 PM
buglao is on a distinguished road.
Default Re: ATF drain and refill is this normal
4 qts. put in 3.5qts first then follow the procedure how to check transmission fluid. add if it needed little bit at a time until you get to level specified. DO NOT OVERFILL.
Old 07-10-2008, 10:59 AM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
shall36's Photo Albums
Last Online: Yesterday 11:40 AM
shall36 is on a distinguished road.
There are a lot of shavings in there, but all in all, it looks alright.
http://www.daveramsey.com/
Must See Video: Drive Free Cars for Life
Old 07-10-2008, 12:43 PM
Tundradrenalin's Avatar
My eBay Tundradrenalin's Photo Albums
Last Online: Yesterday 10:56 PM
Tundradrenalin has blessed us with their presence.Tundradrenalin has blessed us with their presence.Tundradrenalin has blessed us with their presence.
Newtregger, check out the Sticky: DIY (Do-It-Yourself) & User Knowledgebase
There are two nice threads in there regarding the ATF. One of them has a dozen pictures to follow.
Searching for an answer to your Tundra or other Toyota question? search HERE! or HERE!
Got a question about TS.com site policy? click HERE!
What is Rep Power? read more HERE!
My Truck:
Old 07-10-2008, 01:48 PM
Newtregger's Avatar
Thanks. I did that. I was just concerned about all the shavings in there.
Thanks everyone for putting my mind at ease. I was very concerned when I saw all the shavings and some fairly large chunks. Two weeks ago I was coming back from Missouri towing a pop-up camper and a lot of weight in the back of my truck. The center console started to get very warm and then after unhooking the trailer, my truck was shifting very rough into overdrive. The problem has since gone away but I wanted to change the tranny fluid anyway being at 85,000 miles.
Old 07-10-2008, 02:20 PM
04DSGTUNDRA's Avatar
Dealer : Toyota of Glendora
2006 Toyota Tundra AC Limited 4WD
04DSGTUNDRA's Photo Albums
Last Online: 10-26-2008 09:58 PM
04DSGTUNDRA is on a distinguished road.
yeah that amount of shavings looks about right for 85k, you might want to drain and refill a couple more times to get all of the dirty atf out, theres alot that stays in the trans and lines.
2006 Black Limited 4WD TRD Tundra
Gibson exhaust, TRD Filter.
2008 BMW 335i Montego Blue Metallic
Vishnu PROcede v2
2004 Phantom Gray Limited TRD Tundra
RIP.
Old 07-10-2008, 04:57 PM
Dealer : Toyota of New Bern
2003 Toyota Tundra
Sandinmytires's Photo Albums
Last Online: Yesterday 04:37 PM
Sandinmytires is on a distinguished road.
I would have a cow if I saw that many shavings in a pan! How many pounds of the stuff is "too much" for Pete's sake!
Friend's dog puked into console.
Something scratched the bejesus out of bed floor.
Lots of bugs on grill.
$6 switch to keep those d@&# cargo lights off!
I'll wash it next week.
Old 07-10-2008, 05:15 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Yesterday 11:28 PM
HOGWILD will become famous soon enough.
the excessive heat and abnormal shifting i would be concerned about, shavings in pan would also worry me, seems to me that is a group of junk! looks like something has let loose?
Good luck! So how heavy of a load was it?
Old 07-10-2008, 06:25 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
- Other - 2001 Tundra V8 AC
Tones's Photo Albums
Last Online: Yesterday 07:10 PM
Tones is on a distinguished road.
Looks excessive to me. I would be worried.
Old 07-10-2008, 06:59 PM
Newtregger's Avatar
The abnormal shifting has gone away. But now you guys have me worried. I am leaving tomorrow for an eight hour trip to Michigan towing my speed boat. Let's just hope I don't blow it up! I'll let you know what happens.
Old 07-10-2008, 07:06 PM
shall36's Avatar
2003 Toyota Tundra
If you see big chunks of metal, then you should worry.
If what we see in that picture is all stuff that would smear between your fingers, you're good to go. Clutch packs wear. I'm more worried when the fluid smells burnt. That's a sign that things have been slipping.
I think the picture makes things look worse than they are.
Old 07-10-2008, 07:11 PM
MOREPOWER's Avatar
MOREPOWER's Photo Albums
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
Sounds like the planetary gear is shaving down, a common problem 2000 to 2002, whatever you do don't tow with over drive on, its that gear that eventually grenades. Plan a new trans $3500 at the dealer.
Do a search on planetary gears exploding, theres lots of pictures floating around.
Good luck.
Old 07-11-2008, 12:46 AM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
duffyatkinson's Photo Albums
Last Online: Yesterday 07:38 PM
duffyatkinson will become famous soon enough.
Send a message via Yahoo to duffyatkinson
Question Re: ATF drain and refill is this normal
Good luck.
Morepower,
Just so I understand, when you say "don't tow with the overdrive on, it's that gear that eventually grenades", is it the 4th (highest) gear that can't take the strain, i.e. take it out of O/D so you are only in 3 gears??
(I have a 2002 2WD A/C; haven't towed anything yet, but a boat is on the drawing board and I want to know what to watch out for...)
DEA
2002 Tundra V8 AC 4X2 SR5 | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box | Baby seat in the back! | All the rest is stock Toyota baby! | 10/2008: 43,500 miles
Old 07-11-2008, 12:58 AM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
kathyricks's Photo Albums
Last Online: Yesterday 07:56 PM
Regardless of the year, model or even brand of truck, towing in overdrive is a no-no. Just lock out the overdrive when towing (overdrive = 4th gear) and drive 50-65 MPH in
3rd gear. 3rd gear is direct drive.
Old 07-12-2008, 06:55 PM
Dealer : Champion Toyota Scion Gulf Freeway
2004 Toyota Tundra SR5 Double Cab,
- Other - 2005 Honda Civic
thinshavings's Photo Albums
Last Online: 11-26-2008 05:23 PM
thinshavings is on a distinguished road.
NO. It is NOT normal.
Your tranny is not long to this world.
