Re: Do I buy Lug centric or Hub centric wheels??
OK... So I just put a set of Pro Comps on my truck. Given they are not the same size (see my sig), but should be the same as far as lug/hub centric. When I went up to 4wheelparts, this is what they gave me: PXA8089-7983, which are NOT Hub centric.
Edit: My wheels are 17 X 9, -6mm offset
From your original post, I think you will be fine, even without spacers, since your truck is leveled. I don't think you will rub with 285's, but if you do, it will be just a smidgen. Just make sure they give you the 108 Hub bore wheels. You can buy the same rim but with a smaller bore, but that is for Chevy, not Toyota.
2004 Tundra: Scion T1808 head unit, JL Audio component speakers, True Flow intake, air box mod, JBA Headers, Bassani dual exhaust, 285/70/17 BFG All Terrain T/A, Toytec 2.5" lift with Rear Bilstein 5100s and AAL, Pro Comp Xtreme 8089s, leather seat conversion, custom Ranch Hand rear bumper.
