This is a discussion thread titled "Do I buy Lug centric or Hub centric wheels??", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 07-15-2008, 07:06 PM
Dealer : Glass Toyota
2002 Toyota Tundra
Computer Tech's Photo Albums
Last Online: 11-23-2008 11:46 PM
Computer Tech is on a distinguished road.
Default Do I buy Lug centric or Hub centric wheels??
I have a 2002 TRD Tundra V8 Access cab limited 4X2. I wanna install some Pro comp 1069 wheels with some 285/75/16 BFG all terrain tires. Should I order the Hub centric or lug centric wheels. Lets settle this once and for all which do I order?? Also the bolt pattern is 6 on 5.5 right??? Im thinking of ordering 16 X 8 with a 4" backspacing I hoope it will look good and not sticking out a lot of the fenders. My truck is leveled out.
MANNY.
Old 07-15-2008, 09:16 PM
Dealer : South Bay Toyota Scion
2006 Toyota Tundra 06 Tundra,DC,TRD,Ltd
showtime33's Photo Albums
Last Online: 11-29-2008 06:46 PM
showtime33 is on a distinguished road.
Default Re: Do I buy Lug centric or Hub centric wheels??
you want lug centric
Old 07-15-2008, 11:15 PM
Boosted27606's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2006 Toyota Tundra,
1998 Lexus GS300 Silver,
- Other - 93 MITSU Eclipse
My eBay Boosted27606's Photo Albums
Last Online: Today 09:27 AM
Boosted27606 is on a distinguished road.
Send a message via MSN to Boosted27606 Send a message via Yahoo to Boosted27606
NO, NO, NO !
Hubcentric is what the stock wheels are and Hubcentric is what the new wheels should be !
You don't want Lugcentric wheels as they are hard to "center" on the hubs and end up putting a lot of shear stress and torsion on the studs. If you go mudding and a stud breaks off you will find out the hard way that the other studs won't hold the wheel for long.
The lip on the hub is what keeps the wheel located at the center of the hub and that lip controls the wheel position in the X and Y directions. The studs are designed to hold the wheel in the Z direction only and expecting them to do the job in all 3 directions is asking for trouble,
Boosting happily ...
List of mods ( growing Daily ): L.E.D.s inside , Camper Shell with inside lights, Back up sensors and Camera , Subwoofer and Amp , Scangauge II , Hellwig Rear Bar , Billet Rear windows hinges, K&N Air Intake , Heated Seats, Tailgate assist bar, Westin Bull Bar and Skid Plate, Under hood lights, 1.25" Spidertrax spacers in Front, 1.50 " wheeladapter spacers in back, Ultimate window tint.
Old 07-16-2008, 12:39 AM
Dealer : Heyward Allen Toyota Scion
Raider Man's Photo Albums
Last Online: Yesterday 10:20 PM
Raider Man is on a distinguished road.
The stock alloys on my 01 were hub centric. I purchased lug centric wheels and could never get them balanced correctly. Sold them and purchased aftermarket hub centric and no more balancing problems.
Old 07-16-2008, 12:41 AM
2002 Toyota Tundra
so to double check with you guys are these the right wheels for my 02 to clear 285/75/16
1069-6838* 16x8 6x5.5 -11mm 4"
2200lbs 20lbs $104.93the asterisk is for hub centric wheelsss... is that the right bolt patters and backspacing?? these should have no clearance issues with brakes right??
Old 07-16-2008, 08:24 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
TundraSurfBum's Photo Albums
Last Online: Today 03:19 PM
TundraSurfBum is on a distinguished road.
hub most definetly!!!
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
265 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
Old 07-16-2008, 08:25 AM
2006 Toyota Tundra,
6 X 5.5 " is the correct stud pattern. I do not know the backspacing off the top of my head.
Since I only have used the stock size tires I cannot tell you if the 285s will fit.
In the worse case you might have to use spacers like the SPIDERTRAX to bring the wheels out about 1.25 ".
I would do a search if I were you to confirm fitment. There are many threads about larger tires and such right here at TS.
Old 07-16-2008, 08:27 AM
they have a 4" bsp you will be fine
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
Old 07-16-2008, 10:49 AM
Dealer : Fred Anderson Toyota of Sanford
rc05293's Photo Albums
Last Online: Today 02:57 PM
rc05293 is on a distinguished road.
Hub centric is absolutely the preferred choice. I had a set of Classic II's on my 01 for about 6 months. I could never get them balanced, even using the Haweka adapter. I had a constant steering wheel shimmy. I tried numerous torque settings, having them road force balanced, taken off the balancing machine & put back on and spun to check for true zero condition, and nothing worked. I finally got rid of the wheels and put the tires on a set if Ivan Stewart TRD wheels. Those too are lug centric, and I had similar issues, but not quite as bad.
As mentioned earlier, the center hub is designed to hold the wheel on centerline. The locating tolerances on the studs are much less, and you'd be trying to precisely locate the wheel using a threaded surface. Again, way too much tolerance variation for a consistent balance. Basically, you may be able to get a decent balance on the machine, but the fact that the lugs may not be on the exact same spin axis as the hub opens up too many variables to get a smooth ride once the wheel is mounted to the vehicle.
Hub centric should be the only choice. The stock rims are 4 5/8" back spacing, with 15mm offset. Depending on the offset and width of the new wheels, you're backspacing may be quite different.
Old 07-16-2008, 11:48 AM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Today 10:38 AM
LOL...you guys...
*edit* Better explanation in the newer post! Everybody was a little wrong, me too . The only really worthwhile stuff left from my original post:
The downsides...I can't think of a downside to either one. I have run both styles of wheel. The lugs should never, ever be required to hold a shear load, as there should be sufficient friction between hub and wheel to prevent shifting. The lugs and nuts provide a clamping force to increase friction between the two parts, that's all. If you shear a lug (almost never happens...that would mean your nuts are loose, and no man should have that problem), and the other nuts are properly torqued, you should be able to limp home without worrying you'll instantly shear the rest (which is what will happen if they're all loose!). Usually if you're missing a lug, it's because somebody ran the impact too tight or on a crossthreaded nut, very rarely is it because you're playing too hard. Some of the desert guys have that problem, some of them.
If my tire shop can balance an 85#, 37" diameter tire on a 30#, 17x10 rim, lug centric, and that tire is smooth in to the triple digits (one tire required only 4oz weight, one took...well, "a lot"), they can certainly balance yours LOL. *Edit note:* It works because they're balancing the combo hub-centric, not lug centric . I just mount it lug-centric on the front axle. Better explanation in the next post.
Also FYI the centering cones on the Tundra are very easily removed, so don't worry about whether your new wheels will clear the "hub"...there's no hub in the sense of a Dana 44 or similar, the rear is semi-float and the front is similar to a FWD car. It just comes off, and there's a dust cap over the main bolt...so get whatever you like, as long as it has the correct bolt pattern.
Caveat...the one potential problem I've noticed with the Toyota lugs is they're very short. That may be the best reason to use the deeper, mag-style nuts and a hub-centric wheel, as you'll have more thread engagement. Also note I haven't swapped the lugs yet on my 00, and I've been running lug-centric wheels with oversize tires for about seven years now without a problem. The key, as with anything on a vehicle, is proper torque and maintenance.
Smaller wheels and smaller tires are easier to balance, as are higher quality and lighter tires and wheels.
Good luck,
Sean
*edit* CT: those wheels should work. Usually it's only certain steelies that don't fit, where the dish isn't great enough behind the center. Your tire shop should be willing to dry-fit a wheel to the front of the truck, to make sure it clears the brake caliper. That way, if it doesn't work, you can exchange 'em. If it works, enjoy!
GFX by FreedomEagle50
Manual Hubs
Old 07-16-2008, 12:37 PM
so in other words get hubcentric
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
Old 07-16-2008, 04:01 PM
It's almost that simple ...
I did a little poking around to see if there was a better explanation. I like to know why vs hearing "do this or you'll hit a busload of nuns" or "do it because the OEM does it."
The short answer is buy whatever wheel you want, and if you're concerned about centricity, buy a hub centering ring even if they're "lug centric" wheels. And the extension to that is, don't worry about centricity if you're buying a modern, quality wheel...which is pretty much everything on the wall at your favorite shop.
Sources were an older thread here with a couple posts by DJ and KLS, comments from an engineer at Enkei, the Pirate 4x4 knowledge database, and a local tire shop I know and trust (about a six year history, same guys).
First thing to understand is that the lugs and nuts are not shear loaded. They simply clamp the wheel to the hub, so the bearings take the load. In other words, anybody saying you need hub centric to take the load off the studs doesn't know what they're talking about...particularly on our trucks, where the FWD-style hub has only a centering cone. The lugs were not designed to be loaded in shear. Heaven help you, if the weight of your truck is riding on that centering cone! You'll hit a busload of nuns for sure.
Next is that any modern, quality wheel is finished on a lathe, with the center bore as the locating dimension...not the lug holes , which are cut later. The tire shop uses a centering cone to attach that wheel to the balancing equipment (hopefully a Hunter machine with road force balancing ), vs the lug nuts which would take forever. Ever notice they don't mess with lug nuts on the balancer? That's why...a variety of centering cones means there's one to fit every wheel, and whether your wheel requires studs with a tapered or flat clamping surface, it's being balanced hub-centric on the machine. In other words...your new rims are 99.9% guaranteed to be both hub centric (tho not necessarily to your hub) as well as lug centric. The tolerance allowed for screwing up the location of the tapered lug holes is a fraction of a millimeter (0.3mm, IIRC) or it's considered out of round and a defect. I suspect, if you were to measure (with a machinist's centering tool and other devices) the non-tapered holes on a stock Toyota alloy rim, you'd find it was within that tolerance, and that my wheels have the same tolerances but with a different center bore.
The exception seems to be wheels that are only lug-centric...I didn't ask about 'em because all the quality wheels I can think of are either started or finished on a lathe (or both, for some welded steel rims). If you have rims which are only lug-centric, they require a lug-centric adapter, and it is apparently a colossal PITA for everyone involved . Get quality rims and you don't have to worry about this.
Interesting note, I have two sets of rims, both require a tapered nut. On the front, where I no longer have a centering ring, they are completely lug centric during installation. On the rear, they are hub centric to the Dana 60 bodies but still require a tapered nut. Also worthy of note, they're a helluva lot easier to deal with on the rear axle because they center on the hub . Finally, I'm willing to bet that once installed, the front wheel and tire is concentric with respect to the vehicle hub...otherwise I'd certainly notice, with a tire this large!
So how do you take any random wheel requiring tapered nuts and make it hub-centric (ie make life easier for yourself and the tire shop)? Ask the seller or manufacturer about getting a centering ring for their rim to your vehicle...it'll be just like the centering ring Toyota uses, only to fit the new rims.
Why? Instant reduction of the PITA factor associated with lug centering. It is a huge pain in the *** to take a 115# wheel/tire combo and juggle it around while you get six deep-set nuts seated, and then there's all the playing around turning the tire to make sure nothing's being pulled around while the wheel is being seated against the hub. Of course, I'm really anal about it...the tire shop is just gonna blast it on, and their way works just as well, if a little sloppier and more likely to break a stud. If you have a centering ring, you slide the wheel on, and it sits there while you kick back with a brew and take your dear sweet time installing the nuts.
Where does that leave you, buying wheels? Get whatever you want. If you want to make life easier for yourself, get a set of polycarb centering rings. FWIW if you get aluminum, your hubs are steel and you'll have a helluva time getting that ring off once it's corroded to the hub. Don't worry about the plastic because all it does is center the wheel, not hold it up...friction does that, by way of the clamping force provided by lug and stud.
Always, always, always! put the wheel on the axle and tighten the lug nuts while it's still in the air. If you drop it down loose with a lug-centric rim, it'll shift and you'll read 83ft# torque on the wrench, but it won't be properly fastened at each lug. You're also risking shearing a lug. If you drop it down loose on a hub-centric rim, you're likely to break off the centering cone. So always get it centered and tight in the air, and it'll work no matter what rim design or lug nut shoulder you're using.
That's about all I could find, hopefully it helps. I didn't bother to link any of the sources for centering rings, ask your tire shop...they oughtta be able to get them through the manufacturer if you want them.
Bottom line...your new, quality rims are hub centric. Whether you like it or not, whether you have the right centering cone/ring or not, they're hub centric . If they have tapered seats for the lug nuts, you shouldn't need the centering ring. If they have flat seats, you must use the centering ring. Centering rings/cones are available all over the place.
...Come to think of it, my American Racing wheels came with centering cones even though I didn't request them, and the wheels have tapered seats. I stopped using the cones to seat the front wheels when I converted to manual hubs...so likely both sets of wheels I have are both hub and lug centric.
So have fun with your new rims and let your tire shop worry about centricity . Either lug nut style can work on your vehicle.
I also went back and edited the garbage out of my previous post and left a note regarding why my wheel/tire combo can be balanced so well.
-Sean
Manual Hubs
Old 07-16-2008, 04:21 PM
So in other words...... LOL
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
Old 07-16-2008, 04:46 PM
Yes. You're better off worrying about which beer you're gonna drink while you wait for the tire shop to finish.
I like Alaskan Amber. It goes well with my lug-centric rims, which are apparently also hub-centric and I didn't clue in until about half an hour ago.
Manual Hubs
Old 07-16-2008, 04:47 PM
agreed....
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
