2003 Tundra AC quite working
2003 Tundra, 33k miles
About 3 weeks ago, the Air Conditioning started to not blow air as cold as normal. It seemed as though the system might need a touch of Freon. It was intermittent and mostly at idle that it seemed to be worse.
I had a can of 134 in the garage and dropped it in. Seemed like it got colder but I really didn’t think too much about it.
Just recently, 2 or 3 days ago, I completely stopped making cold air. The compressor was cycling on and off which led me to believe that I was low on Freon again. Time to look for a leak. So I grabbed another can of Freon and tried to put it in. Did not want to take it. Checked the hoses and everything, all fine but still did not want to take it.
Then today, I noticed that if I put the AC on, I hear a “clunk” or kinda a rattle when the AC pump kicks on. Only once in a while. Still no AC and getting hotter every day.
So has this happened to anyone?
Does anyone have any ideas?
When I read other threads, it talked about the condenser on the right side when you open the hood. Is that the right side sitting in the truck or looking at the engine. I think the condenser is on the left side looking at the engine and there are no signs of leaking, loose or disturbed wiring.
My truck is a 2003 but only 33k miles on it. Like Brandy new. Would there be a warranty on the pumps based on mileage?
Any input would be appricated!
Thanks
