This is a discussion thread titled "Brake Proportioning Valve - Where is it?", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 07-17-2008, 11:05 AM
Dealer : Carousel Toyota
2002 Toyota Tundra,
2002 Toyota Highlander,
- Other - Nissan 300ZX,
2005 Toyota Tundra Crew Cab Limited
pdmted's Photo Albums
Last Online: Yesterday 12:13 PM
pdmted is on a distinguished road.
Default Brake Proportioning Valve - Where is it?
I just bought an 05 crew cab limited (w/ VSC/TRAC) and put a lift on it the weekend I got it. This is my 6th Tundra by the way, but first 05, and I don't see the proportioning valve bolted to the rear axle. I already have my bracket and everything I need to relocate it, which I have always done in the past. The mounting point with the 2 threaded holes is on the back of the axle just to the right of the differential just like all my other Tundras, but nothing is bolted to it. Can someone give me some insight on if it is somewhere else or I am missing something?
2005 Tundra Crew Cab 4x4 Limited
Bilstein 5100's set to 2.5"
Spidertrax 1.25" Hub/Wheelcentric Adapters
06 Factory TRD 16" Wheels
ToyTec 1.5" Rear Blocks
ToyTec Diff Drop
BF Goodrich 285/75R16 AT's
Old 07-17-2008, 12:06 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Yesterday 11:28 PM
HOGWILD will become famous soon enough.
Default Re: Brake Proportioning Valve - Where is it?
probably in this pdf hope it helps?
pg 79 shows W/VSC mount? looks like shock tower to me?
Old 07-17-2008, 12:35 PM
MEvang's Avatar
Dealer : Toyota of Cincinnati Co.
MEvang's Photo Albums
Last Online: Yesterday 07:36 AM
MEvang will become famous soon enough.
If you have ABS and some form of stability or traction control, it is likely this part has been replaced electronically.
More advanced systems can eliminate portioning valve and height sensing valves altogether.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
Old 07-17-2008, 12:58 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
pdf shows one next to shock tower on frame? not sure what applications this is for but just from what i see in pdf?
Old 07-17-2008, 01:19 PM
2002 Toyota Tundra,
Thanks for that PDF. I will have to pull it up from home and take a look under the truck and see.
Does anyone know for sure if this has to be relocated when lifting the rear?
ToyTec Diff Drop
Old 07-17-2008, 01:35 PM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
TundraSurfBum's Photo Albums
Last Online: Yesterday 09:07 PM
TundraSurfBum is on a distinguished road.
isn't it on the axle housing???
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
265 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
Old 07-18-2008, 12:20 PM
MEvang's Avatar
It was never on the axle housing always on the frame, though there should be a rod from the housing somewhere.
Mike
