Center Support Bearing worn out?
Anyone have the Center Support Bearing wear out? Mine's got slop in it, and the Toyota shop said it needs to be replaced (is this a diy job? If there's a description of how to replace it, please point me in the right direction)
Also, they said the pinion seal at the front of my rear differential is squeaking, and needs to be replaced, along with the rear U-Joint. I'm not sure about the u-joint, it looked ok to me. The pinion bearing seemed to be squeaking. I've searched here, and read about the Center Support Bearing, and it sounds like it has similar slop (1/2" - 3/4" of movement) as what others are reporting.
-Garth
2000 Tundra SR5 Access Cab 4wd TRD V8 Cold Weather Pkg Drop-in Liner Towing Pkg Captains Chairs AM/FM/CD/Cass Stereo Westin Step Bars ARE CX Cap Remote Start/lock
2002 Audi A6 3.0L Quattro Tiptronic Cold Weather Pkg(4 heated seats) Leather Seats Sunroof AM/FM/Cass/CD Bose Stereo Xpel Clear Bra
