Unichip.com
Old 07-21-2008, 01:15 PM
Dealer : Johnstons Toyota Scion of Middletown
2002 Toyota Tundra
Last Online: 07-25-2008 04:02 PM
MrCamryWagon is on a distinguished road.
MrCamryWagon's Photo Albums
Default Wiper replacement
Questions for wiper replacement on an '02 8 cylinder:
1. Do I replace the whole armature like they sell in the stores? I bought some Anco blades at Sears and I do not see how the new arm replaces the original- or even how to get the original off.
2. Can I just insert a refill? Toyota part looks to be narrower than replacement.
3. Are there non-Toyota inserts available?
Old 07-21-2008, 01:25 PM
imjin's Avatar
ΜΟΛΩΝ ΛΑΒΕ
Dealer : McGeorge Toyota
Last Online: Today 08:30 AM
Images: 63
imjin will become famous soon enough.
Send a message via AIM to imjin imjin's Photo Albums
Default Re: Wiper replacement
I just use whatever refills the local parts store has, like the Anco's, Bosch, or something similar. Most of them come with a generic adapter, so you'll need to leave your wiper arms in, but remove the blade assembly at the pivot point so what you're left with is the armature that has the end shaped into a U-shape. That U-shape fits into the universal (usually plastic) adapter that comes with the refills. There is usually a release lever that lets you slide the old blade assembly down and off of the U-shaped end. Then you reverse the direction, pulling the new refill up onto the U-Shape end until it snaps into place.
Old 07-21-2008, 01:32 PM
2002 Toyota Tundra
Yeah. I see the U-shape on the new blade but am not sure how the old one will come off, and am afraid of breaking it. I do see the little lever at the pivot point but I guess I need a "wiper blade for dummies" diagram to help me understand it.
Old 07-21-2008, 01:35 PM
imjin's Avatar
ΜΟΛΩΝ ΛΑΒΕ
Images: 63
I'm not sure if I even had the originals on when I got my truck early on but I'm pretty sure most of them come off the same way. There's some sort of release lever. Worst case, break it loose with a flat head, but take care not to damage the main arm that's attached to the truck, the one with the u-shaped end on it.
Old 07-21-2008, 02:09 PM
2002 Toyota Tundra
Found a good set of pictures. It's obvious where the U-shape is here- I'd say it is more of a "hook".
How to Replace Wiper Blades on 1999 to 2004 Chrysler 300M-Change wipers.
Old 07-21-2008, 02:35 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 02:14 PM
Images: 12
HOGWILD will become famous soon enough. HOGWILD will become famous soon enough.
HOGWILD's Photo Albums
I have had issues getting inserts to match up with factory blade and i messed up and bought new blades to fix issue. BIG mistake, you can buy a whole new blade at walmart made by michelin for the price of the inserts alone!! michelin blades are iam sure made by pylon which has been making blades since before i was born! If ya are trying to find matching inserts for factory blades i would make sure and take blade with ya when ya go and save the back and forth as i did!!
Old 07-21-2008, 02:39 PM
redman733's Avatar
Dealer : Colonial Toyota
Last Online: Today 03:26 PM
Images: 7
redman733 is on a distinguished road.
redman733's Photo Albums
if you look close at the underside of the hook where the plastic insert slides into the hook shape part of the arm you will notice a small plastic nub..
you simply pull the plastic nub away from the hook and it releases the plastic insert and it just slides right out
2006 Tundra DC 4x4 V-8,Bridgestone Revo's,Westin Platinum Series Black Nerf Bars,Wade Vent Visors,Husky Floor Liners, Wheeler Coils..
Old 07-21-2008, 04:29 PM
Boosted27606's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2006 Toyota Tundra,
1998 Lexus GS300 Silver,
- Other - 93 MITSU Eclipse
Last Online: Yesterday 01:36 PM
Images: 8
Boosted27606 will become famous soon enough.
Send a message via MSN to Boosted27606 Send a message via Yahoo to Boosted27606 Boosted27606's Photo Albums My eBay
The longest lasting wipers I ever had were the PIAA ( from TIRERACK ) . The VALEO are also excellent.
Cheaper ones are plenty available out there but they dont last long usually.
Boosting happily ...
List of mods ( growing Daily ): L.E.D.s inside , Camper Shell with inside lights, Back up sensors and Camera , Subwoofer and Amp , Scangauge II , Hellwig Rear Bar , Billet Rear windows hinges, K&N Air Intake , Heated Seats, Tailgate assist bar, Westin Bull Bar and Skid Plate, Under hood lights, 1.25" Spidertrax spacers in Front, 1.75" wheeladapter spacers in back, Ultimate window tint, Multivex Mirrors.
Old 07-21-2008, 05:38 PM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
Last Online: Today 03:58 PM
Images: 2
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch RitcheyRch's Photo Albums
Ditto that on the PIAA wipers. Have them on all my vehicles that have a chance of seeing rain.
I put some Bosch Ions on my new to me 2006 GTO since doubt it will ever see rain but wanted wipers in case it ever gets wet.
Tags
2002 , wipers
