Old 08-01-2008, 01:26 PM
Dealer : Charles Maund Toyota
2002 Toyota Tundra,
- Other - 2005 infiniti g35 cp
Last Online: 11-12-2009 12:11 AM
mikeinaustin is on a distinguished road.
mikeinaustin's Photo Albums
Default 2002 tundra v8: coolant type
Currently have toyota red. however, i was wondering if i could switch to toyota pink. if so, would i have to do a complete flush before doing so? have any of you switched from red to pink coolant?
Old 08-01-2008, 01:40 PM
Dealer : Doxon Toyota
2002 Toyota Tundra mica green trd
Last Online: Yesterday 11:28 PM
sr5mike will become famous soon enough.
sr5mike's Photo Albums
Default Re: 2002 tundra v8: coolant type
Why go through the hassle. I just replaced my with the original toyota red.
At least they have circled the problem.
Old 08-01-2008, 05:36 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra AC V8
Last Online: 10-10-2009 09:59 PM
Tones is on a distinguished road.
Tones's Photo Albums
I have been changing mine with the red. You're supposed to change it every two years. There is a TSB stating the pink can be used. Just drain all of the coolant from the radiator and the two block drains. This will get you all of the capacity of the system so mixing will not be an issue. A flush wouldn't hurt but would not be necessary if removing all of the coolant this way. If you do flush it, make sure you drain all the water from the system also because the pink is premixed.
Old 07-07-2009, 07:37 PM
2000 Toyota Tundra 4X4 SR5 AC 158,000
Last Online: Yesterday 06:40 PM
packeroni is on a distinguished road.
packeroni's Photo Albums
Is there any difference between Toyota Red and Toyota Pink? I have a 2000 Tundra and manual says to use Toyota Red, but my truck was built before the development of Toyota Pink.
