Help to disable automatic door locks
+ Reply to Thread
Results 1 to 15 of 15
Thread: Help to disable automatic door locks
  1. #1
    Join Date
    Oct 2007
    Location
    Waynesboro, TN
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Default Help to disable automatic door locks
    I work on a ranch and everytime I get in and out of the truck and restart it locks my doors automatically. Too much trouble for passenger. Anyone know how to eliminate this bothersome feature? It's a 2000 Tundra.
    thanks
    Stan
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Boosted27606's Avatar
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    1,071
    Liked
    6 times
    Images
    12
    Rep Power
    1044
    Default Re: Help to disable automatic door locks
    I would love to eliminate that on my 2006 as well............
    If anyone has the solution, PLEASE SHARE !
    Enjoying the awesome 5.7 L engine
    TRD rear Sway Bar, Billet Grille, Heated Seats, Westin Bull Bar and Skid Plate, HELLA driving Lights, Chrome handles and mirrors,
  4. #3
    veteran member Big_Al1's Avatar
    Join Date
    May 2005
    Location
    Lake Charles,LA
    Age
    34
    Posts
    1,755
    Liked
    11 times
    Images
    16
    Rep Power
    1099
    Mine must have been broke since new cause it has never done that.Only locks if I hit the button.
  5. #4
    Join Date
    Jul 2008
    Location
    South Jersey
    Age
    34
    Posts
    20
    Liked
    0 times
    Rep Power
    7
    My 05 DC SR5 doesn't do it, either.
  6. #5
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    19 times
    Rep Power
    1673
    Quote Originally Posted by aspidites View Post
    thanks
    Stan
    Your alarm system has passive alarming set on. If it is the Toyota RS3000, see RS3000 Toyota Vehicle Intrusion Protection
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  7. #6
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    1,071
    Liked
    6 times
    Images
    12
    Rep Power
    1044
    Thanks for the info PARROT
    I still wonder if "passive arming" in those instructions means that if I unlock the door with the remote the truck will re-lock the doors after 30 seconds. ( which it does now ) and if I turn that feature off, will it still turn the alarm ON after I lock the doors and walk away ?
  8. #7
    Supporter UnSub's Avatar
    Join Date
    Mar 2007
    Location
    Mesquite, TX
    Age
    63
    Posts
    992
    Liked
    1 times
    Images
    6
    Rep Power
    37
    On my 03 I reprogramed the alarm so the doors do not lock when I start the truck. They only look and unlock when I press the remote buttom. My truck however has the newer alarm system but I would bet someone can tell you how to do it on yours.
    03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
    Scion Head Unit 08600-21802,
    Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
    Rhino Liner, Die Hard Platinum P5 battery
    5.7 Killer
  9. #8
    Join Date
    Mar 2007
    Location
    Mesquite, TX
    Age
    63
    Posts
    992
    Liked
    1 times
    Images
    6
    Rep Power
    37
    This is in the info nh sent. You can turn this feature on or off. Just go to the instructions this refers to.
    AUTOMATIC DOOR LOCKING / UNLOCKING
    The RS3000 is programmed to automatically lock your doors when the ignition switch is turned to "ON" or "START", and unlock them when the ignition switch is turned to "LOCK" or "ACC". This feature will operate only once (AUTOMATIC LOCK then AUTOMATIC UNLOCK) before a door is opened and closed again. The AUTOMATIC LOCKING feature will not work while a door is open.
    NOTE: The factory preset operation of this feature is AUTO DOOR LOCK / UNLOCK "ON". If you would like it changed to "OFF", refer to the PROGRAMMING AND ADJUSTMENTS section.
    5.7 Killer
  10. #9
    Join Date
    Oct 2007
    Location
    Waynesboro, TN
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    thanks for the info, but would you be so kind as to provide me with a link to get this info? I'd appreciate it. This feature drives us nuts on the farm!
  11. #10
    Banned
    Join Date
    Sep 2000
    Location
    in timeout
    Age
    37
    Posts
    8,335
    Liked
    2 times
    Images
    100
    Rep Power
    0
    Quote Originally Posted by nhparrot View Post
    Glen and I know this folk's But ill share some bit's I know
    00-02 (rs3000) Toyota Vip alarm system...
    03-06 (rs3200) Toyota Vip alarm system...
    04-06 Double cab's don't retain the same system used on the access cab's so forget this information being used on the DC since the programming is different on each Model.
    Erik
    I do have the rs 3000 Manual in front of me..
    Programming and Adjustments Page 20 on the Toyota rs3000 security system
    Mode automatic door locking and unloacking off mode
    programming step
    close the driver door then open and close it one more time >>>>>>>Turn the ignition switch to the "Lock" postion ( The Piezo chirper sounds twice and the exterior lights flash twice...
  12. #11
    Join Date
    Sep 2008
    Location
    oconomowoc
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I went through the vip programming to turn off the auto door locking feature. The beeps sounded indicating the programming was done but the locks still locked when I started the engine. Also the doors don't unlock when the key is turned to off. Every time I need to get out I have to press the door unlock button. Any suggestions.
  13. #12
    Join Date
    May 2010
    Location
    Tennessee
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Smile Re: Help to disable automatic door locks
    I have a 2000 Tundra with the VIP RS3000 System. I followed the instructions on page 20 of the manual and it worked just fine! I even started the engine and the doors did not lock. Working just fine. If you can't find you manual, here is the procedure:
    1) Sit in the driver's seat with the driver door open. 2) Insert the key in the ignition switch, and turn it to "ON" (not ACC) 5 times (ON-LOCK-ON-LOCK-ON-LOCK-ON-LOCK-ON) within a 10 second period. The STATUS MONITOR'S LED turns on, and the piezo "Chirper" sounds once.
    YOU MUST PERFORM THE NEXT STEPS WITHIN 30 SECONDS!
    3) Select the operating mode:
    MODE
    Auto lock/unlock ON
    Programming step: Close the driver's door
    Programming Completion:Turn the ignition switch to the "LOCK" position (the chirper sounds once and exterior lights flash once)
    Auto lock/unlock OFF
    Programming step: Close the driver's door, then open, and close it one more time.
    Programming Completion: Turn the ignition switch to the "LOCK" position (the chirper sounds twice and exterior lights flash twice)
  14. #13
    Supercharged Member WhiteLiteNin's Avatar
    Join Date
    Sep 2009
    Location
    Nashvile, TN
    Age
    52
    Posts
    3,074
    Liked
    202 times
    Rep Power
    192769
    Quote Originally Posted by jamc View Post
    MODE
    Auto lock/unlock ON
    excellent first post my tennessee brother! and now you are the recipient of points too!
  15. #14
    Join Date
    May 2010
    Location
    Tennessee
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Whitelinnin, Thanks for the good words. We are all in this together and need all the help we can get!! Take care.
  16. #15
    Join Date
    May 2010
    Location
    Tennessee
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Sorry 'bout the name error... Whitelitenin, thanks for the good words. Fellow Tennessean!!
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
