Re: Transmission howl at low rpm
Just an FYI, you can replace just the bearings since these alternators are very expensive. Not sure if Chinaloy is still around but i printed a post from him a while back where he had the same problem and got the bearings from Toyota. The front bearing part #90099-10192 & rear #90099-10194. He said it went well with only a few specialty items needed such as a small puller to seperate the case halves. The rear bearing was pressed in but not exactly sure how he got it out. And the front is held in by 3 screws and a retainer.
I don't recommend remans from parts stores when it comes to alternators or starters, i've had so many be junk right out of the box that it'd rather replace bearings in an oem one that buy a reman.
Oem alternator: $480
Oem bearings: $20
'01 Tundra Reg Cab SR5 V8
'05 Honda Foreman 500S 4x4
'04 Honda Shadow Sabre 1100
